Question about Maytag MER6772 Gemini Electric Kitchen Range
KITCHEN RANGE SELF CLEANING NOW DOOR WILL NOT OPEN
  • 750 Answers
Hello r-stamper,
Welcome to Fixya,
You said, SELF CLEANING NOW DOOR WILL NOT OPEN
Lets try to reset the system.
Turn off the range.
Now throw the breaker in the electric box off for 5 minutes.
After waiting 5 minutes turn the power on and try the range!
If there is a cancel or release button you may have to hold this in firmly for 3 seconds.
Let me know how she works.
Huuum at your service.
Please remember to leave a rating!
Posted on Oct 06, 2008
Why is oven door locked after self-cleaning mode?
How To Fix Oven Door That Doesn't Open After Self Clean ...
www.partselect.com/...Stove-Oven/Door-Will-Not-Open-After-Self-Clea...
How To Fix An Oven Door That Won't Open After A Self Clean Cycle ... This may reset the control and allow you to unlock the door. If you still cannot unlock the .
Repair - Dead oven after self clean mode, blank display ...
? 9:38
https://www.youtube.com/watch?v=UylZKwzAPow
Feb 22, 2014 - Uploaded by Random Repair
Repair - Dead oven after self clean mode, blank display, locked door Kitchen Aid Whirlpool How to repair an ...
Nov 26, 2015 | Kenmore Kitchen Ranges
Gas range oven door with not open
Your self cleaning cycle is running. When self cleaning is running the door is automatically locked and will not unlock until the self cleaning cycle completes or self cleaning is turned off. You should be able to just turn off the self cleaning cycle and the door will unlock. Do not try to pry open the oven door. You will just damage the door and/or the catch.
Oct 15, 2014 | Amana ARGS7650SS Gas Kitchen Range
Whrilpool gas range Mod. GW395LEGD0 Serial IMJ0663181 OVEN DOOR LOCKED CAN NOT OPEN
If its a self cleaning model and you tried to stop it in the middle of the cleaning cycle the door will not unlock. Disconnect it from the power, let it stand a few hours then plug in. If not opening try running the self cleaning mode and let it finish completely. When it finishes after it cools down sufficiently the door lock should go off.
Aug 09, 2014 | Whirlpool GS460 Gas Kitchen Range
Oven lite won't go off and when turn on self cleaning it says door
The door switch has gone bad. This will keep the oven light on and the self clean won't work because it thinks the door is open.
Dec 12, 2011 | KitchenAid KESC307 Electric Kitchen Range
How to self clean hotpoint gas range model number rgb740beh3ct
To self clean that oven REMOVE THE RACKS, slide the door latch from the right to the left,push the self clean button,push the up/down arrows to set the clean time (usual clean time is 4 hours 30 minutes) push start
After the clean is over it may take a additional hour before the door will open if the latch doesn't move back easily to the the right once self clean clean is done do not force it just wait more time
GENE
Oct 10, 2011 | Hotpoint RGB745 Gas Kitchen Range
I have a Bosch HEI7282U range. Went through self clean cycle, oven cooled down but oven door will not open. Put through another self clean, door still does not open. Cut power at circut breaker for over 5...
- Follow Door removal instruction from the manual.
- There is a screw at the end of the hinge that can be adjusted.
- Adjust the screw to desired height.
- Secure lock nut
Jan 31, 2011 | Bosch HEI7282 Electric Kitchen Range
Can not open the door of the self- cleaning electric Range after cleaning operation
Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
or
Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
If these procedures fail to correct the condition, the lock must usually be accessed and moved manually to open the door.
Some model ovens require the oven door to be manually unlatched before the controls are returned to the OFF position or else the door may not be able to be unlocked. Check the owner's manual for proper operating procedures
Mar 11, 2010 | Kenmore 99123 Electric Kitchen Range
How do I stop and open door in the self cleaning?I have a hugh mess in the oven I clean the extra stuff on the bottom what happens if it starts fire and I can not shut off and open the door.
Large spots should be cleaned BEFORE starting self clean..The self clean can not be "paused" and continued..It has to be shut down and re started..
Jul 16, 2009 | Whirlpool Accubake RF362LXTT Electric...
Maytag MER6772 Gemini Electric Kitchen Range Logo
65 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
