Question about Whirlpool Duet GHW9150P Front Load Washer
Control locked We just moved and when I hooked up my washer I received the control locked light. How do I change this
  • Anonymous Mar 01, 2009
    can't turn off comntrol lock
    Genius:
  • 1,028 Answers
Find button with lock symbol beside it hold down 3-5 secs
Posted on Oct 05, 2008
It displays 'control lock' with red light
Here are a few Different models as i do not know yours.
How to Unlock the Control on Whirlpool Duet eHow
Maytag - To unlock the controls, press and hold the CYCLE END SIGNAL for 3 deliberate seconds or until the control lock light goes out. If the control locked light will not turn off, I recommend unplugging the washer for 5 minutes. Plug the unit back in and see if the controls will respond. If not, I recommend calling a service technician to diagnose and repair the washer. You could have a failed control console or a bad electronic control board in the washer.
Kemmore- Unplug for 10 minutes.
GE washer - Make sure that the control for the washer is not locked. If it is, press and hold the LOCK button for 3 deliberate seconds (or until the control unlocks).
There is not another way to reset the control board other than completely unplugging the washer as you have been doing. Since the display light up and works, the washer apparently has electrical power supplied to the control board and control console. You could have a failure in the console that is preventing the start button from working. A failed control board or a problem with the door switch could also prevent the washer from starting. Make sure that the washer door is firmly closed.
If the washer will not start after checking the control lock and the door, I recommend calling a service technician to diagnose and repair the washer.
Good luck More info would be helpful. Make and model. Is always a plus.
Oct 02, 2014 | Washing Machines
Controls locked
The Control Lock prevents unintended use of the washer. You can also use the control lock feature to prevent unintended cycle or option changes during a cycle. When CONTROL LOCKED is lit, all buttons are disabled except for Pause/Cancel and Start. You can lock the controls while the washer is operating. To lock the controls: Select and hold DRAIN & SPIN for 3 seconds. The CONTROL LOCKED status light glows. To unlock the controls: Select and hold DRAIN & SPIN for 3 seconds or until the CONTROL LOCKED Status light turns off.
Aug 06, 2012 | Whirlpool AWM9000 Front Load Washer
Describe your Whirlpool Duet GHW9150P Front Load Washer Problem the control lock button is on
Hello & Welcome to FixYa
This is a common issue with Whirlpool Duet washer however; your whirlpool duet washer needs a reset to resolve the control lock problem. Press and hold the END OF CYCLE/CYCLE SIGNAL button for 15 seconds to reset the control. Please get back to me if you have any other questions.
Kevin
Aug 15, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F 11 code flashing
The F-11 error code is a communication error between the main control and the motor control. I recommend unplugging the washer and removing the access panels.
Fdl error code because it is usually associated with the F11 code. The FdL fault code indicates that you have a problem with the door lock assembly. This is often caused by a failed door lock but it can also be caused by a failed wiring harness connection or in some instances by a failed control board.
Check for damage to the door hook on the washer door and look for anything that could be clogging the catch on the door lock assembly on the front panel of the washer.
You may need to check the wire harness connections on the door lock assembly. The images below show the procedure for accessing the door lock assembly on this type of washer. Be sure that you unplug the washer before accessing internal components.
I have seen the failure be caused by a door lock and a faulty machine control board. A little trick I have found is to remove the top of the washer and push down lightly on the connector that is labeled dls5 this connector should have four black wires. This connector is located on the machine control board under the top. Use an insulated screwdriver to push on the connector and start a cycle. If the door locks and the washer works, I recommend replacing the machine control. It has a bad solder joint on the board. We often see error code F11 also with bad solder joints on the control board. If pushing on the connector did not make a difference, I would suspect a faulty door lock first.
Hope this helps.
Jun 06, 2011 | Washing Machines
The "Control Locked" light is
Mar 31, 2011 | Washing Machines
"Control Locked" lamp is lit on the washer. Tried
Press and hold the end of cycle button for 15 seconds this should clear it.
Control locked
Nov 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer won't turn on and the light by "control locked" is lit up.
Control lock is a feature to lock your control from anyone changing your setting or stopping the washer from being shut off after you have selected a cycle. There is a subscript under one of your option buttons that says control lock hold for 3 seconds. Hold this button in for 3 seconds or so and the lock should turn off. It was probably pushed by accident or someone was leaning on it. If this doesn't solve the problem please post again.
Please rate this post. Thank you.
Jan 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I was doing a load of laundry and the washer "froze" i tried to cancel the load but it wont stop.... i ended up unpluging it and even when i plugged it back in its still stuck!!!
Locking controls
lit, all buttons are disabled. You can lock the washer while it is
operating.
Select and hold END OF CYCLE SIGNAL for 3 seconds.
Select and hold END OF CYCLE SIGNAL for 3 seconds until the
Nov 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Control Locked
Locking controls
operating.
Select and hold END OF CYCLE SIGNAL for 3 seconds until the CONTROL LOCKED Status light turns off.
Oct 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Control Locked
look closely at the machine console, the most right set of buttons, the lowest possible one is the control lock button, youll need to hold it in for 3-5 seconds to unlock the control panel(child lock)
May 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Mike Cairns
Mike Cairns
