Question about Dryers
Kenmore dryer won't run.
Thanks for your help.  For all your point-outs, it were ok. Nothings happenned when turned on, just hear timer clicking.
  • 1 more comment
  • kingkong108 Oct 05, 2008
    Ok I will have to find out where is th BELT BREAK SWITCH aswell.
    Greatly appreciate.
  • kingkong108 Oct 21, 2008
    Thanks to Docjohn174,
    The belt is looking good, no break found.
    Anyway, don't bother. I've brought a new one.
    Thanks for help.
  • john gagnon
    john gagnon May 11, 2010
    hi did you check the belt
  • 943 Answers
HI ON THAT DRYER .THERE IS A BELT BREAK SWITCH. SO IF THE BELT BREAKS ,IT WILL NOT START .CHECK THAT.
Posted on Oct 04, 2008
My dryer won't turn on at all. Can hear timer and I had the push start tested and is ok . any suggestions?
first test the fuseable link in the back its near the fan burner area on gas units on electric by the coil heater. let me know then we go from there
Nov 03, 2012 | Kenmore Dryers
Kenmore dryer won't start
If thermal fuse is bad, most dryers will not run. If it is bad, dryer has overheated for some reason. Check venting to be sure it is clear and be sure heating element has not grounded out.
Aug 29, 2017 | Kenmore Dryers
My lady kenmore dryer will not turn on at all. I can hear the timer going but when i push the button nothing happens. I can also hear the button click when i push it.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Apr 21, 2011 | Dryers
Dryer will not start. Electrical source is ok, light is on and your can hear timer running. When you hit start button you can only hear a click and nothing happens.
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Jan 01, 2011 | Whirlpool WED5300S Electric Dryer
When i push the start button i can hear and feel the timer working yet nothing else happens. when i release the start button the timer quits working.door switch is working. i've checked all the connectors...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 06, 2010 | Kenmore Dryers
Kenmore dryer Model 96320100. Was working fine and just stopped. Nothing happens when you push the start button. When I turn on the timer I can hear it clicking, so there is power. Does the start button...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Aug 17, 2010 | Kenmore Dryers
Dryer Won't Start
Make sure it has power. Then:Check the door switch. A little lever sticking down through top right of door opening. If it is not there you will need new door switch(sometimes the little lever breaks off). If it is there and does not click when you press it in you need a new door switch. if it clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
May 27, 2009 | Kenmore 73952 Gas Dryer
Dryer not turning on
most likely its the timer it has electrical contacts built on the timer that allow it to start its cycle if the timer has bad contacts it wont allow dryer to come on
Jan 21, 2008 | Dryers
Dryers Logo
43 people viewed this question
Top Dryers Experts
