Question about Toshiba Televison & Video
Toshiba 61' tv U This TV was working fine up until the day I moved house. When it got to the new place, I plugged it in the power light came on for about two seconds and then went off and it hasn't powered up since. E 61pj
  • 5 more comments
  • mikee_kiwibo Oct 05, 2008
    model number 61pj7ue i have no power at all the turn on/off light doesnt even flash just nothing
    E 61pjComment by mikee_kiwibo, posted on Oct 05, 2008
    Model number 61pj7ue i have no power at all the turn on/off light doesnt even flash just nothing
    power cord looks fine it hasnt come out of the socket internal
    r they easy to change warranty run out
    whats the cost i would be looking at
    thank you very much u have made things alot easier to understand.Have tired all advice given,im pretty sure it the issue with the power board
    President:
  • 2,712 Answers
1. Try this - hold the menu button down for 10 seconds. TV should power up; you will have to turn off front panel buttons on menu.
2. You can also try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and re-plug to AC power and redo the cabling. Switch on the TV and see if it works..
3. Powering down the set or putting it in standby may have allowed the power supply to cool. Weak capacitors often go out of spec when they cool, thus preventing a section of the power supply from firing up properly again. There is a simple trick...just warm the back of the TV with a hair dryer for 5-7 mins after you have unplugged the TV. Look for the little areas of holes in the back panel of TV. Use these as your guide at where to use the hairdryer, but don't hold the dryer too close (say 5-6inches away). (Make sure the dryer is on High heat). If the TV doesn't turn on after you have heated it up (like it tries to come on but then turns off) you need to unplug the TV again, this resets it. And repeat those steps till it works. Resetting the TV after it fails to turn on is the key. Also, just leave the TV on. Don't turn in off. Since it is LCD, it doesn't take much power...only a few bucks extra a month for your utility bill.
4. A circuit board may crack about some of the larger components mounted on it. You can inspect the PCB's for fractures, and then repair them. It may also be poor soldering that has failed. I would be checking for these things first.
If none of the tips outlined above do not work, it could indicate an issue with the power board, which may need to be replaced. I suggest contacting a qualified repairman in this case.
Hope that helps!
Please don’t forget to rate or "Accept" the solution if it helped you in any way, or leads you to a fix.
Thank you for using FixYa!
IrishDruid
Posted on Oct 05, 2008
    Scholar:
  • 125 Answers
The Fuse for your TV is probably blown out. you should have someone service your tv. But mostly its a fuse problem.
    Scholar:
  • 94 Answers
It seems that your tv has blown a fuse, due to in consistent current of some sort.
if your tv still has warranty on it i advice to have it checked with the manufacturer.
    Master:
  • 479 Answers
The power cord wire got loose internally from the socket just get it fitted and it will work properly.
  • 10,594 Answers
Seems TV has few cold solder joints in its circuit boards some where and transportation made joints lose. That's why TV shows error and doesn't power up.
Please provide model number to provide you more information to resolve this problem.
Thank you.
  • Toshiba Master
  • 6,487 Answers
Can you please inform us the model of this unit , so we can help you better...
I heard a pop on the Toshiba rear projection TV (model #62hmx84) and immediately lost the picture
Sir the problem of your unit is the lamp try to replace it it is much better to use a gloves and wash your hand after replacing the lamp because this lamp contains mercury. follow this steps.
1. Unplug the unit to main ac outlet. Remove the bulb housing cover from the back of the TV. Using a screwdriver, carefully remove the cover to reveal the old bulb. Using a cloth, remove the bulb from the TV by first unplugging it from the wiring harness. Carefully rock the harness back and forth until it comes free from the bulb. Push in the bulb slightly and turn it a quarter-turn to remove it from the bulb housing.
2. Install the new bulb. Do not touch the new bulb with your fingers, as any grease or fingerprint from your hands will damage the tiny mirrors in the bulb. Instead, carefully handle the bulb using the cloth. Insert it into the bulb housing and secure the door. Test the unit. Plug in and turn on your Toshiba TV and make sure that the new bulb is installed properly and that the image looks crisp.
3.
Reset the lamp time counter. Each Toshiba TV comes with a lamp hour meter stored in its software. If you do not reset the lamp timer, the unit may stop operating when it gets to a certain time (refer to your manual because each Toshiba TV is slightly different). To reset your Toshiba lamp timer, turn off the TV, wait 10 seconds, hold down the "on," "menu" and "input" buttons on the remote at the same time, and turn the power back on. A yellow light should appear in the bottom corner of the TV indicating that the lamp timer has been reset.
Hope this help good day and best regards.
Sep 23, 2011 | Toshiba 62HMX84 62" Rear Projection HDTV
I have a 61 inch rear projection TV. When moving we took the back off of the TV so that we could navigate it up the stairway to my new apartment. Once in the apartment we plugged it in and it wouldn't go...
Check ur power source?Yes,wait like about an hour later for the tv resetting back to it factory setting.Recheck all connections inside of the tv for loses or untighten connections?Make sure all connections are tighten and no damage to all the PCB boards tries again tv should work now.
Jan 14, 2011 | Hitachi 61SWX10B 61" Rear Projection...
I turn the power buttin on....after about five
When was the projection lamp last change?If the tv,projection lamp inside the tv at last change was 1/ 1/2 or 2 years ago,and the tv is on,an in use at lest 4 or 5 hours day.The projection lamp life,it over should be change the projection lamp.Now tv turn on LED light "LAMP" indication light up or flashes?Yes,the projection is dead,hear alot of clicking too?The Ballast board it also dead,should be change too.The Ballast board,this board job,it help to ignite the projection lamp.
Jul 23, 2010 | Toshiba TP61H60 61" Rear Projection...
Tv will not turn on leave unpluged a few days plug
The DM power supply board,probobally have those dying leakages gases about to be dead parts call capacitors.U have tools and know basic soldering?Tries website like Tvrepairworld.com to buy a capacitors kit,to replaced those dying capacitors belong in the DM power supply board.
Jul 19, 2010 | RCA Televison & Video
The TV worked fine until I moved it to my new place of resident. When you plug the init in the wall, the one power LED doesn't come on. Unit worked fine until it was moved and it was handled with care. The...
we both know the power led, means i have power, so trace the power, get a meter and test the TV. See if the inside solder connections are getting power, by the way make sure you know the schematics if the board isn't labeled you can fry it.
Aug 25, 2009 | Akai PT46DL10 46" HDTV-Ready Television
TP61H95 Toshiba Cinema Series 61" The Image rolls
defintly the convergance.if the con is on a small board ,maybe 130 big board 250&up.if u know how to solder 35$ each STK and u need 2. and check each internal fuse with a ohm meter with tv power unplugged
Mar 12, 2009 | Toshiba TP61H95 61" Rear Projection...
BLINKING POWER LIGHT AND TV DOES NOT POWER ON
I have a toshiba 61 inch projection tv the power light flashes with no picture any easy fixes?
Jun 24, 2008 | Toshiba TP61G90 61" Rear Projection...
Toshiba TN61X81 HD Cinema Series Sound Problem
what type of connection did you use for your playstation 3 to your tv....
Aug 10, 2007 | Toshiba TN61X81 61" Rear Projection...
Power shut off
Theres an STR##### IC in the power supply thats intermittant and this is a very very common problem Im surprised the repairman didnt know this. Tell them to look it up on the schematic and come to your house and replace it. Most repairers wont do this in the house because they cant get the same money but in my opinon it shouldnt take more then an hour too do. Good luck Ps the ###### in the STR number are differant on differant models.
Apr 27, 2006 | Toshiba 61HX70 61" Rear Projection...
TV auto shut off-power indicator light blinking-won't turn back on
You could have gotten an electrical surge that put your set into a shutdown condition and unplugging the set and letting the Microprocessor reset will fix this problem if it dosent blow out the main power regulator as you still or might I say have a regulator IC problem. IF THIS PROBLEM HAPPENS AGAIN MORE THEN A FEW TIMES WITHIN A SMALL TIME FRAME I WOULD HAVE THE SET LOOKED AT BEFORE THE REGULAOR BLOWS SOMETHING OUT!!!!
Jan 11, 2006 | Toshiba 43H70 43" Rear Projection...
Televison & Video Logo
106 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
