Question about Eten M600 Smartphone
System boot fail
System hang and stops on orange screen
Power is down to 1% even after charged,,, how can i get rid of it? help please
Posted on Oct 28, 2008
Android tablet fails to boot. "Green Man" screen comes on, start stalls on next screen
you will need to try power +volume +up +down
Or power +home +volume down then
Factory reset
Dec 10, 2013 | Computers & Internet
System completely locked out... will not boot!
there will be a setting in the BIOS that will stop the ACER logo, and you can see the Diagnostic screen, and get an idea of where in the process it is hanging....
Personally I bet it is hanging at the 'detect SATA' devices stage.
Open the side panel and remove and re-seat all SATA device cables, at BOTH the device and the motherboard.
If that fails, then the boot sector may need to be repaired on the hard drive. you will need a Windows disk for the OS that your client has though....although if it's an MBR disk you can use an XP or a win2k disk to repair. There are downloadable tools in iso format that you can burn and use to boot from the CD and then repair the boot-sector ...
Aug 22, 2012 | Acer Aspire X1 Ax-1430g-uw30p Slimline...
IBM System x3400 M3 7379 not booting displays orange colour (!), hangs at EFI Initialization what might be the problem. Thanks in advance.
check the indicators on the right side of the front panel for more detail of the error. search online for the manual.
Nov 28, 2011 | IBM System x3400 M3 7379 Server tower 5U...
As I am using my HP, Compaq 6720s laptop sometimes, and now more regularly the screen breakup into colourful lines and the system stops reacting, a hang in effect. The screen breakup used to come with a...
Hello, Abdi.
I have some suggestions for you. It's possible that your hard drive is failing. Run Diagnostics and check your hard drive. Upon boot, press F12 rapidly (or could be F2) and choose the Diagnostics.
Another suggestion is to use System Restore, in the event that your operating system file(s) is problematic. Again, boot your system to Safe Mode (press F8 repeatedly when powering on). Go to System Restore and choose a date when your system worked OK. Note: with System Restore, all your updates will roll back to that date. Follow the process.
Hope this helps.
Sep 02, 2011 | HP Compaq 6720s Notebook
Laptop does not boot into operating system, it stops at LG screen and hangs
your OS must have crashed ... re install the OS your prb will be solved ..(if it doesn't work) your hard drive must have failed
Jun 21, 2011 | LG Computers & Internet
My system Processor is working, but its not Displaying anything. Sometime its displayed, but hangs and reboot or shutdown.Send me suggestion what should i do to solve this problem.My system Configuration...
There are different possibilities for system hang up. I want you to find it your self from following my simple instruction.
1. (when computer is turn on) Check temperature... overheating can cause system to hang up, it can cause the system to reboot, it can cause the fatal error message and turns your screen to blue. Overheating is cause by exhaust fan or blower not working. Find this blower or exhaust fan on top of the processor, as built in fan in your video card, attached on your power supply and on the casing of your computer. Replace non working fan or blower.
2. Check video card...faulty video card can cause your system to hang up. It can cause also your system to go on blank screen. Most common problem is loosen connection of video card from the motherboard. Disconnect and reseat the video card properly. Inspect the fan, if not working then video card will overheat and system fail. If you previously see moving colors in your screen especially small boxes, or discoloration and screen going black and white then it means video card is already failing. You will need to replace it.
3. Check for hardware failure. keyboard, mouse lan card can cause your system to halt and hang. You will need to disconnect this first when booting and see if by removing this hardware will complete the system to boot up to operating system. Replace faulty one.
4. Harddisk failure. when computer reset or will not boot up completely then hard disk usually cause this problem. Initial remedy is to reseat its connection sata, ide or power supply connector.
If you hear ticking sound in the harddisk or excessive vibration then it will need replacement.
5. Operating system corrupted. this can cause your computer not to boot up properly and hang the system. Reformat and reinstallation of operating system is required.
6. Power supply failure. you need to check the output voltage. dropping of voltage can be cause bi leaking capacitor in the power supply unit. replace it with exact value. Voltage should read +12VDC for yellow, +5VDC for red. and should be stable even with load.
let me know which one cause it.
Feb 07, 2011 | Intel D845GVSR Motherboard
Xp boots and hang up on blank screen
Insert the original Windows XP "System Restore" CD-ROM,
and tell your computer to "boot" from it.
Does it boot, and get to a screen that asks you "do you really want to ...", or does it stop at a "blank" screen?
If it "stops", you have a "hardware" problem.
If it "asks", then either:
* your disk-drive has failed, or is about to fail,
* your installed copy of Windows is messed-up, and it cannot complete the "boot" process.
Take your computer to a computer-store, for more trouble-shooting.
Aug 28, 2008 | Computers & Internet
Open Questions:
Toshiba Laptop doesn't start up. Black screen [Solved] -Dataalign If you are facing any kind of issues in Toshiba laptops or other products related to Toshiba brand, then you have come to the right place, as this article is an overview of where you can find the right kind of services, required for proper working of the gadgets by any tech savvy person, in particular the ones using Toshiba products. Another beneficial thing about using Toshiba products is its reliable Toshiba Customer Service , which can be reached any time for assistance with guaranteed satisfactory results. Toshiba customer care services are provided by highly efficient and knowledgeable tech support technicians having years of working experience in the field of providing dependable services to the customers of Toshiba. Toshiba support services provided by Dataalign are the best in class for their consistent services and highly advanced way of resolving tech issues faced by the customers. Dataalign tech support team comprises of expert technicians and they make use of high class technology for fixing the issues in Toshiba laptops and other devices as they have proper knowledge of all kind of issues with their perfect resolution. Dataalign technicians can be reached easily anytime from anywhere through the toll free helpline number +1888784-9316. Dataalign assistance providing Toshiba Tech support engineers are selected through a rigorous process of selection which makes them efficient for providing right support in minimum time with high accuracy. Technicians of Dataalign assist the customers in the most polite way with the assurance of providing highly accurate solution for every issue. For the answer of any kind of query related to Dataalign or for help regarding tech issues contact Toshiba support on their toll free helpline number.
Jun 21, 2018 | Toshiba Computers & Internet
See all Eten M600 Smartphone Questions
Eten M600 Smartphone Logo
139 people viewed this question
Top Eten Computers & Internet Experts
David Payne
David Payne
Are you an Eten Computer and Internet Expert? Answer questions, earn points and help others
