Question about Vizio P4 46 in. HD-Ready Plasma Television
2" vert. red stripe
Verticale red stripe on right side of screen. Some times it is 1" wide. Some times it is 2'' wide.
  • philgarcia Oct 08, 2008
    I have the same tv....same problem..1" red and blue lines on RH and 1/2of the left side of the screen scrambled...TV repair Labs told me these are disposable TVs......no schems. no parts!
  • lpool54 Jan 13, 2009
    i have the same problem only the 2inch stripe is on the left side of the screen.it is a vizio 40inch plasma tv
    Problem Solver:
  • 5 Answers
I have worked on many Vizio televisions under warranty and what you are descriping is often a result of the X boards going bad. If the telelvision is under warranty, contact Vizio at 1-877-MYVIZIO, if it's no longer under warranty, the cost of repair is probably going to be more than the cost of a new tv unfortunatly. I always recommend buying the extended warranty's with these televisions.
Posted on Oct 20, 2008
I have a 52 inch Samsung TV, on the screen have solid, color vertical lines on the right, about 1/8 wide, on the same time the half of screen blink on the right too.
not knowing the model... i will try to help with this common samsung issue, if i can. / unplug the tv, and wait a few minutes to avoid shocks. / remove back panel. you will see several ribbon connectors, (about an 1" to 1 1/2" wide) usually near the bottom. / carefully remove the ribbon (ONE AT A TIME) and clean the contacts GENTLY with a pencil eraser. (DO NOT use chemicals) / reinsert the ribbons and try the tv. // vertical stripes are almost always the result of poor contact between ribbon and socket. / NOTE!. you can do a quick test before opening the set by [carefully!!!!] twisting the screen and watch to see if the vertical stripes change or disappear. / if the stripes change, bet on it being the ribbon contact problem.//// hope this helps, it has worked on a number of TVs.------Jay
Oct 26, 2015 | Samsung Televison & Video
Red vertical stripes 1" wide, black screen half screen, normal windows screen 2" left side
So long as there are no inpact marks on the screen or cracks there is an issue with the lcd screen and so long as the machine is in manufactures warranty is covered (1 year).
You would need to get in touch with the company you purchased machine from if it is in warranty
Mar 18, 2010 | Toshiba LCD Display for SATELLITE...
2" wide Red stripe on right side of LG 42" plasma TV screen
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size..
Jun 09, 2017 | LG DU-42PY10 42 in. Plasma HDTV
Connect Digital and Analog cables at the same time.Any use?
does not help. keep dvi connector (white one) on computer and in the back of monitor.
and surely it will not take away those vertical stripes.
those vert stripes... hmm... your monitor might have a problem which you can't fix by your own.
Feb 22, 2009 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Striped color distortions on Nokia 300 Xa flat panel
This is power supply problem.
1. First u replaced the power out put capacitors , 6V, 12V, etc.
2. cheak the diodes.
Oct 17, 2008 | Computers & Internet
Red lines on right hand side of the screen now no picture on right hand side!
I'm not an expert, but I have determined that the vertical bars that are often red, sometimes blue ... and sometimes both ... are related to a bad control board. I've also read that a common fix is to buy a repair kit with includes the ysus, zsus and control boards ... all replaced together. My experience was that after a month or two with the 1.5" wide stripes, that you eventually loose the entire picture and have sound only. MIne comes back, but won't stay working for very long and the stripes are always there (buy used to fade and flicker sometimes). I'm planning on replacing the control board.
Jun 09, 2008 | LG DU-42PX12XC 42 in. Plasma HDTV
ViewSonic N1700w with Black stripe on right side of display
Sounds to me that you have a bad connection/wire to the CCFL bulb on that side of the display. Should be an easy fix, do it your selfer thing.
Dec 27, 2007 | ViewSonic NextVision N1700w (Black,...
Open Questions:
Vizio P4 46 in. HD-Ready Plasma Television Logo
270 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
