Question about Yamaha HTR-5730 Receiver
Yamaha htr 5730 receiver none of the controls work
None of the controls work. except the volume knob. remote doesn't work. I was watching a movie and it turned off by itself. Then I turned it on with the remote and it would shut off
again. Then I turned it on with the main power button and it stayed on and I finished my movie. Now it won't turn off unless I unplug it. The display still lights up. It still does 5.1. But only the volume can be changed now and only by the knob. WTF?
  • Anonymous Feb 02, 2009
    "None of the controls work. except the volume knob. remote doesn't work. I was watching a movie and it turned off by itself. Then I turned it on with the remote and it would shut off
    again.
    changed now and only by the knob. WTF?"
    I got the same problem
3 Suggested Answers
cancerags
  • 36 Answers
SOURCE: Connecting a Yamaha VX7 Subwoofer on my Yamaha HTR 5730 AV Receiver
Hello srqwrk,
You can connect the VX7 to the 5730 using an RCA Y cable like the one shown in the picture below. You get your one connection for the receiver and 2 for the VX7. These are available at any electronics store. Remember that the cable should be long enough to go from the receiver to where subwoofer will be placed.
Hope this helps. Let me know.
cancerags
Posted on Jan 01, 2008
dunnbiker
  • 8546 Answers
SOURCE: Humming coming from the speakers
From all speakers?
How is the audio connected to the TV (be specific)?
Keep in mind that a TV is not generally an audio source as its programming always comes from something higher up the audio food chain than itself. Get the audio to your receiver from whatever THAT is, not the TV.
Posted on May 29, 2010
SOURCE: The volume knob for my Yamaha HTR 5730 receiver
this is the part number V9124700 and it can be ordered through sears. it runs about 7 bucks and the shipping will be about the same, google the part number you might find it a little cheaper
Posted on Feb 02, 2011
My remote works fine except for the volume control to the receiver(HTR5440). How can I set this for response?
http://usa.yamaha.com/products/audio-visual/av-receivers-amps/htr/htr-5440_black__u/
a good start would be a glance at the owners manual
this will help
perhaps you have a faulty remote
perhaps it got banged and needs the insides soldered like the IR diode at the top end
i see you mention it isnt working
so try another or take the remote to an electronics buddy who can click it open and check for a bad solder or etc...
Dec 09, 2014 | Yamaha Audio Players & Recorders
Yamaha RX-V1000 volume control erratic, remote doesn't work. All was well then the volume control knob became erratic (volume would change erratically as knob was turned in either direction, remain...
sounds like you need to take it in to have it looked at. no simple fix unless you are an appliance technician. hard to walk a beginner through. i suggest calling an stereo repair guy.
Fix Ya
FixYa Support
Please accept solution and rate 4 thumbs up! Thanks for your feedback!
Aug 21, 2011 | Yamaha RX-V1000 Receiver
How do I reset my yamaha receiver htr5730
http://www.retrevo.com/support/Yamaha-HTR-5730-Receivers-manual/id/1075bh230/t/2/
Page 52
1 Hold down STEREO on the Front Panel
"Factory Preset" appears on the front panel
2 Press STEREO to select the desired setting.
'Reset' To reset to factory presets
'Cancel' to cancel without making changes
3 Press STANDBY/ON to confirm your selection
Jan 15, 2011 | Yamaha HTR-5730 Receiver
The volume knob for my Yamaha HTR 5730 receiver broke off. Where can I find a replacement? Thank you.
Dec 05, 2010 | Yamaha Audio Players & Recorders
I have att an uverse remote that turns on my Yamaha receiver, but won't control the volume. Model No rx v480
You need to try other codes for Yamaha, as clearly the one you have put in the remote is incorrect, perhaps it was for an earlier model.
Mar 07, 2010 | Yamaha HTR-5730 Receiver
All Yamaha HTR-6130 codes don't work on DirecTV remote
try 30176 and dont forget to assign the remote to turn up the receiver not the tv
Jul 04, 2009 | Yamaha HTR-6130 Receiver
What's NEC PF68S33 TV's remote control code for YAMAHA HTR-6130
I had similar problem when setting up the YAMAHA remote control for my NEC LCD TV. At the end I found I did not follow the YAMAHA manual properly. Did you hold down the DTV/CBL button, and AT THE SAME TIME press the AV POWER for 3+ seconds? You should be able to "REMOTE SETUP OK" displayed in the front panel of the YAMAHA AV receiver. Hope this helps. BTW, only the TV POWER, TV MUTE and the numeric buttons work in my case.
Dec 30, 2008 | Yamaha HTR-6130 Receiver
Volume control on unit
Kent, Unfortunately, it sounds as if the encoder is broken. The encoder is a digital input which takes the place of a traditional volume control, and is what holds the volume knob in place and spins. Since it works fine with the remote, that means everything else is ok, but you will have to replace, or have a tech replace, the encoder itself.
Sep 14, 2008 | Yamaha HTR-5550 Receiver
Yamaha HTR-5730 Receiver Logo
47 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
