Question about IBM ThinkPad A21m 2628 Notebook
Thinkpad A21m 2628 G7u BIOS/Video Shadowed Error 0175: Bad CRC1 Stop POST Task
Having read numerous requests on this Thinkpad failure, there appears to be a common problem around the world with this model. My laptop shut down suddenly and when I turned it back on it does not move beyond the the system test screen. Along with two beeps. I have the 'on' light.
I downloaded the BIOS (spsdKx36) from the IBM site, placed it on a disk
and attempted to update the BIOS. Nothing. It displays preparing boot device list, after I pressed F12.
Is it possible there is a virus that is affecting/altering critial system components? Or, just a bad system board that IBM would like to replace?
Would using Bootdisk.com download to boot the machine start it up again?
If so, which program would I download? Windows NT is the operating system.
Thank you for your assistance. Sandra G sandragerdin@cs.com
  • 4 more comments
  • Anonymous Oct 07, 2008
  • Anonymous Nov 14, 2008
    erreur 0271
  • Anonymous Dec 04, 2008
    i have the same Error 0175: Bad CRC1 Stop POST Task problem
  • farhannabi Dec 06, 2008
    ERROR
    0175: Bad CRC1, stop POST task.
  • Anonymous Jan 27, 2009
    i was try with download file but still same problem persist.
  • Anonymous Feb 28, 2009
ERROR 0175: Bad CRC1, stop POST task message Been using my IBM a30 laptop for some months but was surprised to get this error when i tried putting it on this message pops up ERROR 0175:BAD CRC1 STOP POST...
You obviously didn't read the problem carefully. The machine won't boot, so there is no command line. I have the same problem with a T23. It might be the CMOS battery that needs to be replaced.
Jan 11, 2010 | IBM ThinkPad A30 Notebook
Post problem
If it beeps (which it should) means that some device did not pass post. Find your motherboard online and look up the beep codes. This should help you to discover the problem. I hope this helps!
Jul 15, 2009 | IBM ThinkPad A21m 2628 Notebook
Error 0175 bad crc1
Numeric error codes - ThinkPad General From IBM Web Site
Notes:
· The most likely cause is listed first.
· A numeric error is displayed for each error detected in POST or system operation.
· In the displays, n can be any number
Error code
Symptom or error
Field replaceable unit or action, in sequence
0175
Bad CRC1, stop POST task. The EEPROM checksum is not correct
This problem you may not be able to fix. There are a couple of things you can try.
1st Keep on rebooting your laptop until this error goes away.
2nd Replace the BIOS battery, it maybe nearly worn out. After replacement you need to go into the BIOS setting to set the Date & Time.
System board
May 16, 2009 | IBM ThinkPad T20 2647 Notebook
Error 0175: bad crc1 stop post task
It appears that your BIOS battery is nearlt flat and needs replacing.
F2 function key is the normal BIOS setup key for Thinkpad
Jan 28, 2009 | IBM ThinkPad A21m 2628 Notebook
0175: bad crc1, stop post task, system bios shadowed
Go on tis forum and post your problem. There is also the Lenovo forum. I have a T23 and haven't seen this error before. These Forums are very good for information on your laptop.
http://forum.thinkpads.com/viewforum.php?f=28
http://forums.lenovo.com/lnv/board?board.id=T_Series_Thinkpads
Oct 02, 2008 | IBM ThinkPad T20 2647 Notebook
While booting error " bios shadowed " & 0175: bad crc1, stop post task
sounds like cmos battery flat small battery inside pc to retain cmos setting when pc switched off
Error code 175
If you have access to the internet another way, search the error code by googling it, or going to the IBM website and searching it anf for solutions.
May 19, 2008 | IBM ThinkPad A21m 2628 Notebook
Stop POST task, bad CRC1 error 0175
There are a couple of possibilities, go to this link for the solutions, but it could be a bad power supply http://www.hardwareanalysis.com/content/topic/31761/
Aug 07, 2007 | IBM ThinkPad A21e 2628 Notebook
IBM ThinkPad A21m 2628 Notebook Logo
1,047 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
