A dvd is stuck in my DVR how do I get it out the tray will not open
  • sandy1998 May 01, 2009
    i have looked for this tiny round hole but cannot find it on the tivo dvd.  would you happen to know where it is?  the disc is stuck and i can't get the dvd out.  thank you
    Problem Solver:
  • 16 Answers
If you take a look at your computer's DVD or CD drive tray, it should have a tiny round hole. Look close because it's only about 1/16-inch in diameter. Does your DVR disc tray have a similar tiny round hole?
This hole is for ejecting the tray if there is no power. You take a paper clip and unfold and straighten it and insert it in the hole. It should go in about 1/2 to 1 inch before it hits the unlatch mechanism. You shouldn't have to push in very hard to unlatch. If it does unlatch, the tray will pop out about 1/4" and you simply pull it out by hand the rest of the way.
I hope this helps you out.
-Vince
Posted on Oct 04, 2008
DVD Tray Will Not Come Out
Download updated software for free on Panasonic Website then take a Paper Clip or other small object and insert it in the small hole in front of the machine and manually open the Disk tray. The Updates should take care of the Problem !
Oct 13, 2012 | Panasonic DMR-EZ47V DVD Recorder/VCR
Dvd draw will not open yamaha dvr s60
Hello
either its loading motor is faulty, or the loading belt is broken. The commands are reciving, but it does not work mechanically. A mechanical fault indeed.
Feb 28, 2012 | Yamaha DVR-S120 DVD Player
LOCKED DVR
I just bought the CH-DVR 1600 @ Target. This is just a temporary workaround to enable playing of region 2 DVD disks (don't have other regions but believe it will work also), until the real regional unlock is available.
1. Insert the region 2 DVD disk and close the tray.
2. Wait for the "Wrong Region" popup to appear in the upper-right corner of your TV screen.
3. The display on your DRV reads "STOP" at this point and the "Wrong Region" popup has disappeared.
4. Press the number "1" button on your DVR remote and a small input popup will appear in the upper-left corner of your screen.
5. Do not press anything else and the DVR will accept this entry as a chapter # and proceed to this chapter to start playing the movie.
NOTE1: The DVR runs in a somewhat restricted node, e.g. the DVR display still reads "STOP" and some remote functions do not work, such as "Menu". The input numbers correspond to the chapters on the DVD disk, so you can experiment and get to the menu once you hit one of the extra feature chapters with a "back to the menu" link on it.
NOTE2: I’m anxiously awaiting the real unlock sequence, as I tried most of the old ones posted here, none seemed to work.
also try this
-Switch player ON with no disc in the tray. Close tray and press MENU, 1, and 9 on the remote control. A menu should appear with the Region Option. Highlight the Region entry and press ENTER on the remote. Type in the Region you want. (Put 0 for code free) Press ENTER again to confirm choice. Press OPEN/CLOSE TRAY button and put in movie.
Mar 31, 2009 | Cyberhome DVR 1600 DVD Recorder
Door will not open
I had a similar problem, I went back in and opened it up, took the top plate that covers the lens, opened the tray, put the plate back on, then closed the tray and it works again. With the tray closed, I think I put the top plate on the bottom piece and it was stuck on.
Oct 19, 2008 | Cyberhome DVD Recorder - DVR1600
Pioneer dvd recorder dvr-530H
The EPG is the electronic program guide trying to download TV listings.
http://en.wikipedia.org/wiki/Electronic_program_guide
This is normal for this player. To disable this, you would need to turn off the TV guide function.
Sep 28, 2008 | Pioneer DVR-530H-S DVD Player/HDD Recorder
DVD shelf won't open
You know you can place a paperclip in the hole next to the DVD drive to release the door. Never just pull on the tray when it is all the way closed. Once the door is part way open you can gently pull it out the rest of the way. This will not fix anything, it just allows you to open the tray once.
Jul 17, 2008 | Pioneer DVR-520H DVD Recorder
Unlock region code for Daewoo DVR- VCR COMBO model number DFX-6705
Open DVD tray, Press SETUP on remote, Initiate Set Up, Go to 'i' to Select SYSTEM INFO, Enter 1101 on remote keypad, Enter 0 (zero) for region free, Press ENTER on keypad, Close DVD
tray. VCR/DVDR is now Region Free
Jun 21, 2008 | Televison & Video
No tray function
You have to press both the "on" button and the "preset" button to lock-unlock the tray
Sep 26, 2007 | Yamaha DVR-S120 DVD Player
open the cover of dvr, clean the tray or replace the belt
Aug 16, 2007 | Cyberhome DVR 1600 DVD Recorder
DVD stuck/jammed in tray
there may be two screws on the top of the tray that holds the rounded magnet, the one that is placed to hold the disc when spinning, remove it, you can then simply take the disc out.
May 19, 2007 | Pioneer DVR-810H DVD Recorder
Televison & Video Logo
253 people viewed this question
Top Televison & Video Experts
