Question about Simrad 20187423 Teleflex Adapt Lf 3000 Seastar Kit
Frozen steering on mariner 75
Steering ram on mariner 75 is immovable from steering wheel or motor. When the ram is disconnected from the strut the motor moves freely??
  • 3 Answers
It sounds like your steering cable is rusted in the eng steering bracket or your cable has gone south (Rust) try some heat to free it up and if that dont work its time for a new cable
Posted on Oct 21, 2008
Replace steering wheel
there is a air bag in the steering wheel that needs to be disconnected,and you will need a steering wheel puller . you can rent one from any part store
Dec 15, 2012 | 2008 Mercury Mariner
Steering on my boat motor is stiff evinrude
First disconnect the motor and see if that stiffness is from the pivot of the outboard or from the steering cable.
If motor, try the grease gun with marine grease (auto grease will coagulate in salt water) and put some heat to it (oxy is the ticket, but not to hot- just smokin) and swing in back ad forth. Keep it moving as ir cools off as you may need a few treatments.
If its the cable-- buy a new one. If you;d rather buy beer, take the end off the motor and hose clamp the cut end of a bicycle inner tube to the plastic of the housing. Then fill with 5w20 motor oil and hang it all higher than the steering wheel till morning. Come out about every 3rd beer and spin the steering lock to lock. Put a bucket under it in the morning to catch the extra and hook it back up.
Sep 04, 2012 | Light Boating
2004 dodge ram 1500 power steering problem
this problem is evident in vehicles that have a strut suspension
at the top of the strut there is a plate that is the top plate for the suspension coil spring
above that plate in the rubber bush is a bearing
if that bearing has failed then the plate will not turn and when you turn the steering wheel the power steering is in effect winding up that coil spring
that makes low speed turning very heavy on the power steering system especially at low rpms
have the front suspension checked for that bearing failure ( both sides ) by an accredited suspension specialist shop
standing stationary and turning the wheel you may even hear a creaking or groaning noise as the spring is flexing on the strut
if you do not have a strut suspension , take it to a power steering specialist shop for a proper diagnosis
Apr 11, 2012 | Cars & Trucks
Steerin wheel is locked and won't turn when engin is on
If the steering wheel is completely immovable, then something is jamming it. You'll need to pull the column covers and look under the dash.
If the steering wheel is very hard to turn, then your power steering is not working. Check the steering pump belt (could be broken) and check the steering fluid level.
SD
Jun 13, 2011 | 2002 Mitsubishi Galant
How to replace 2002 pt cruiser starter
2.4L Non-Turbo Engine
Remove or disconnect the following:
Negative battery cable Air cleaner box cover Engine structural collar Starter electrical connectors Starter To install:
  1. Install the starter and torque the bolts to 40 ft. lbs. (54 Nm). Attach the starter electrical connectors.
  2. Install the engine structural collar on models with a automatic transaxle as follows, refer to the illustration for bolt locations:
    1. Place the collar in position and hand tighten the collar to transaxle bolt.
    2. Position the power steering hose support bracket and install the collar to oil pan bolt.
    3. Place the bending strut in place and hand start the bolt.
    4. Install the bolt through the strut and collar and hand tighten.
    5. Place the power steering hose support bracket in position and install and hand tighten the remaining bolts.
    6. Tighten the collar-to-transmission bolts to 75 ft. lbs. (101 Nm).
    7. Install the bolts through the strut and into the block.
    8. Tighten the remaining bolts to 45 ft. lbs. (61 Nm).
  3. Install the engine structural collar on models with a manual transaxle as follows, refer to the illustration for bolt locations:
    3. Position the clutch slave cylinder into position and hand start the bolts.
    4. Tighten bolts (1) to 75 ft. lbs. (101 Nm).
    5. Tighten bolts (2 and 5) to 45 ft. lbs. (61 Nm).
    6. Tighten bolts (3 and 4) to 20 ft. lbs. (28 Nm).
  4. Install the air cleaner box cover and connect the negative battery cable.
2.4L Turbo Engine
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Remove or disconnect the following:
    Negative battery cable Air cleaner box cover Upper starter bolt by pushing the inner cooler up and out of the way Inner cooler lower hose from the inner cooler Nuts retaining the inner cooler tube Studs retaining the power steering lines Position the power steering lines aside Engine structural collar Starter electrical connectors Starter
To install:
  4. Install or connect the following:
    Power steering lines aside Studs retaining the power steering lines and tighten to 45 ft. lbs. (61 Nm) Nuts retaining the inner cooler tube Inner cooler lower hose to the inner cooler Upper starter bolt by pushing the inner cooler up and out of the way. Tighten to 40 ft. lbs. (54 Nm). Air cleaner box cover Negative battery cable
Jul 03, 2010 | 2002 Chrysler PT Cruiser
How long does it take to fix front bearings on a 97 dodge caravan? and cost
About an hour a side...This is the whole job and pictures....
The hub and wheel bearing unit is serviced as a complete assembly. Replacement of the front drive hub and bearing assembly can be done without having to remove the steering knuckle from the vehicle. However, if the hub/bearing assembly is frozen to the steering knuckle, removal of the steering knuckle is required.
  1. Disconnect the negative battery cable.
  2. Remove the cotter pin from the end of the stub axle. Remove the nut lock and spring washer. With the brakes applied, loosen, but do NOT remove the axle nut and washer with the vehicle still on the ground or damage to the wheel bearing will result.
  3. Raise and safely support the vehicle. Remove the wheel.
  4. Remove the front brake caliper assembly from the steering knuckle assembly and support from the strut assembly using a strong piece of wire.
    1. Remove the front brake rotor from the hub/bearing assembly.
    2. Remove the retaining nut and washer from the halfshaft stub axle.
    3. Remove the ABS wheel speed sensor from the steering knuckle.
    4. Remove the 4 hub and bearing assembly mounting bolts from behind the steering knuckle.
    5. Remove the hub and bearing assembly from the steering knuckle.
  5. To install:
    1. Thoroughly clean the mating surfaces of the steering knuckle and the hub and bearing assembly of any foreign material or nicks so the surfaces are clean and smooth.
    2. Install the new hub and bearing assembly and tighten the mounting bolts in a crisscross pattern to 45 ft. lbs. (65 Nm). Be sure the hub and bearing assembly is seated squarely against the front steering knuckle.
    3. Install the disc brake rotor.
    4. Install the brake caliper assembly onto the steering knuckle.
    5. Install the axle washer and nut. Tighten but do not torque.
    6. Install the ABS wheel speed sensor.
    7. Install the wheel and lug nuts. Torque the lug nuts, in sequence, to 95 ft. lbs. (129 Nm).
    8. Lower the vehicle. Do NOT roll the vehicle until the axle nut has been properly torqued or damage to the front wheel bearings will result.
    9. With the vehicle's brakes applied, torque the axle nut to 180 ft. lbs. (244 Nm). Install the spring washer, nut lock and a new cotter pin. Wrap the cotter pin prongs tightly around the axle nut lock.
    10. Reconnect the negative battery cable. Check the wheel alignment.
The hub/bearing assembly is attached to the steering knuckle with four bolts
Removing a hub/bearing assembly
If the hub/bearing is "frozen" to the steering knuckle, separate the ball joint and lightly tap on the hub/bearing from behind
The hub/bearing assembly should free itself from the steering knuckle
About $60 a hub.
May 23, 2010 | 1997 Dodge Caravan
2006 dodge ram front end shakes when hitting a bump at 40 + mph please help?
You have to make somebody to check the struts, or shocks, and also the axles, this situation is very dangerous because if the problem are the terminals or the axles, they can be broke while driving and you will lost control of the steering wheel... completely. I mean, no steering wheel working, on a car running...
Dec 29, 2009 | 1998 Dodge Ram 1500 4WD
How can i fix stiff steering on my bmw 316i
Assuming you have power steering, check fluid level in power steering system.
Check that the power steering pump belt has not fallen off.
Tires that are nearly bald can make the steering effort higher.
Do you have wheels that are not made for this car that have the wrong offset?
Check the strut bearings to see if they are frozen. Look under the front fenders while someone else turns the steering wheel. The strut and spring should turn with the wheel. If the top of the spring does not turn, then the strut bearings need to be replaced.
Nov 15, 2009 | 1997 BMW 318
I need step by step instructions to replace front struts.
1.Turn ignition to OFF position to place steering column in unlocked position.
2.Remove hub nut
3.Loosen, but do not remove, three top mount-to-shock tower
4.Raise vehicle on a hoist.
5.Remove tire and wheel assembly
6.Move brake caliper and wire out of the way
7.Remove brake rotor
8.Remove cotter pin from tie rod end stud and remove slotted nut.
Discard cotter pin and nut
9.remove tie rod from knuckle
10.Remove stabilizer bar link nut, and remove link from strut
11.Remove and discard lower arm-to-steering knuckle pinch bolt and nut. (A drift punch may be used to remove bolt.) Using a screwdriver, slightly spread knuckle-to-lower arm pinch joint and remove lower arm from steering knuckle.
12.Press halfshaft from hub
13.Remove shock absorber strut-to-steering knuckle pinch bolt. Using a large screwdriver, slightly spread knuckle-to-strut pinch joint, if required, for removal
14.Remove steering knuckle and hub assembly from shock absorber strut
15.Remove three top mount-to-shock tower nuts and remove strut and spring assembly from vehicle
16.Compress spring with Spring Compressor
17.Place 10mm box-end wrench on top of shock strut shaft and hold while removing top shaft retaining nut with a 21mm 6-point crow foot wrench and ratchet
18.Loosen Spring Compressor , then remove top mount bracket assembly, bearing plate assembly and spring.
INSTALLATION
1.Place a 10mm box-end wrench on top of shock strut shaft and hold while tightening top shaft retaining nut with a 21mm 6-point crow foot wrench and ratchet to 53-72 Nm (40-53 lb-ft).
2.Install strut and spring assembly and three top mount-to-shock tower nuts
3.Install steering knuckle and hub assembly to shock absorber strut.
4.Install a new shock absorber strut-to-steering knuckle pinch bolt. Tighten to 98-132 Nm (73-97 lb-ft).
5.Install halfshaft into hub
6.Install lower arm to steering knuckle ensuring that ball stud groove is properly positioned and boot seal is not damaged. Install a new pinch bolt and nut. Tighten to 53-72 Nm (40-53 lb-ft).
7.Install stabilizer bar link to strut and install a new stabilizer bar link nut. Tighten to 77-103 Nm (57-75 lb-ft).
8.Install tie rod end onto knuckle.
9.Install a new tie rod end slotted nut. Tighten to 31-47Nm (23-34 lb-ft).
10.Install a new slotted nut retaining cotter pin.
11.Install brake rotor
12.Install brake caliper
13.Install tire and wheel assembly
14.Tighten three top mount-to-shock tower nuts to 30-40Nm (23-29 lb-ft).
15.Lower vehicle and tighten hub nut to 230-275 Nm (170-202 lb-ft)
16.Depress brake pedal several times prior to moving vehicle.
Hope this helps. Good luck !
Mar 14, 2009 | 1992 Ford Taurus
Steering wheel vibrates thumping noise
At what speed do you feel the shake and does it only happen when you apply the brakes?
Mar 02, 2009 | 1995 Nissan Maxima
Simrad 20187423 Teleflex Adapt Lf 3000 Seastar Kit Logo
276 people viewed this question
Top Simrad Boating Experts
Michael Vincent Cruz
Steve
Steve
ray gallant
Are you a Simrad Boating Expert? Answer questions, earn points and help others
