Question about Samsung SyncMaster 740N 17" LCD Monitor
Monitor goes blank after 5-10 minutes
I purchased this monitor 8months back.Now i have this problem of the monitor going black after a normal loading which goes   black with the led blinking.the monitor gets back to the displayed screen before blacking out once the power button is pressed off and on but the same repeats again after 5-10 minutes.
  • afwallng Oct 04, 2008
    my monitor starts normally and suddenly goes off.the display continues after pressing the power switch but after 5-10 minutes goes off.I have tried connecting a CRT monitor and it works fine without interruption to the display.
  • 45 Answers
You may have a compatibility issue with your monitor. You computer may not be putting out enough power to support your monitor. Check your users manual on your monitor for output requirements. If the monitor's manual has a number to call, call the manufacturer to see if there are any compatibility problems between your computer and your monitor and calling the people who built your computer as well. Get as many scenarios as you can to find a solution. Hoped this helped.
Posted on Nov 03, 2008
Why does screen go black after a few seconds
Hope this helps.... Your monitor has an inverter issue. You know it's an inverter problem when:
1. Your monitor starts normally and displays the startup/desktop screen for a while.
2. Then it suddenly goes off, leaving a blank (black) screen or a very dim display.
To fix this black screen problem, change the inverter board (based on your monitor brand).
May 05, 2014 | ASUS VK193D LCD Monitor 19-inch - Black
Hyundai monitor on for 5 minutes and screen goes black
Have you ever opened up the monitor to clean the dust out,it could be your heating up and then letting it sit will bring it back.If your unsure how to do this ask a tech.
Apr 21, 2017 | Hyundai X224W
Monitor goes black
I also have a hp w1907 monitor which also powered on for a second and then go blank with the power light still on.. it was out of warranty so I had no loss so I took it apart..I found one of the wires broken at one of the backlight bulbs { becarefull they are fragile and there is four of them, two on the top and two on the bottom... and the lcd screen is very fragile } I soldered the wire back on and it all work fine... just remember where all the screen parts go.
Oct 24, 2009 | HP w1907 LCD Monitor
The monitor comes on then goes out.
Problem with appearing normal windows desktop... go to Safe Mode to remove any possible pop-ups or vga driver to see where the windows stands normally.
Oct 04, 2009 | HP Compaq FP5315 15" LCD Monitor
Asus Monitor boes blank and comes back after power recycle
1. You can see images on the screen for a few minutes. That means there is nothing wrong with your computer.
2. When your screen goes blank, if you disconnect and then reconnect the monitor, it shows fine again for a few minutes before going blank (or dim) again. That means the problem is not with you video card.
3. It always shows the image after reconnection for exactly a few minutes before going blank again. yes? this means that there is nothing wrong with your cable.
Conclusion: Sorry, but you do not have many options. I bleieve that the problem is with your monitor that's going bad. Its far cheaper to get it replaced than to repair it.
Oct 04, 2009 | ASUS MW221U LCD Monitor
E19T6W EMachine 19" monitor
Emachine is going to repair it under warranty.
Tnx for the help.
Sep 01, 2009 | BenQ FP91G+ 19" LCD Monitor
Monitor comes on, then goes back off, rinse, repeat.
Well here is a test you can do. When the monitor goes black, take a flash light and hold at it a angle towards the monitor, if you can still faintly see the image then you have a blacklight/inverter issue. Another common issue with this is the capacitors on the inside. They will also cause this. If you dont see an image then the inverter will need replacing. As the steps for replacing all of this are quite long, ill post a few helpful tuts :).
For replacing the backlight:
For checking/replacing bad capacitors:
I know these arent your monitor but its generally the same idea with all of them. If this doesnt work it will be a inverter issue and if it comes to that just let me know and ill be glad to help :D
Jul 14, 2009 | Princeton Digital VL1918 Monitor
Monitor displays breifly then goes to blank screen
There is just no way you will be happy to hear it needs service or replacement under warranty.
Jul 03, 2008 | Relisys RLT1720 17" LCD Monitor
Screen suddenly goes blank
when you open your pc now,do you still hear a click sounds like you hear before ,when your computer has no problem yet? now there is no sounds .do the ff..
1.try to press the numlock key and observe it ,if the indicator LED lite on and off,the problem of your computer is your video card,
2.if you can't hear anything, when you open your unit and the indicator of your monitor goes the color orange,pls..check your memory .clean the memory and the memory slots using the contact cleaner .before you replace a new memory.
3. and try to use a another monitor,maybe your monitor has the problem.
Apr 01, 2008 | Samsung SyncMaster 551 15" CRT Monitor
Fujitsu c series labtop screen goes blank, the hooked up to a monitor, starts to work then says out of frequence and goes blank
The video resolution and/or frequency that's set in windows is not supported by the monitor you have plugged in. Restart the PC in VGA mode (hit F8 after the BIOS messages but before any Windows messages) and change the video settings to something basic, such as 800 x 600 @ 60 Hz. Then restart the machine normally.
Jan 21, 2008 | Fujitsu LifeBook C6555 Notebook
Samsung SyncMaster 740N 17" LCD Monitor Logo
202 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
