Question about Samsung DVD-R155
Player won't read a DVD
I have a Samsung DVD-R155. When I insert a DVD, the screen reads "load", but eventually it screen will say it can't read the DVD, and then ejects the DVD. It doesn' t matter if it is a new or used DVD.
  • 3 more comments
  • mortchmayor Oct 14, 2008
    I have almost the same problem, but it only happens sporadically and it happens on some dvds that had been previously recorded on...my inventory of 20 dvds is gradually diminishing and I'm now down to 15 discs? Whats up?
  • Anonymous Oct 31, 2008
    I have the exact same problem. It happens with ALL DVD's. It worked perfectly for 2 months and now won't play any DVD's anymore.
  • Anonymous Nov 04, 2008
    I ordered the software from someone in India. Very hard to understand. Software did not work. Player only a year old. Fried with similar problem on different Samsung. Now I just play dvd on 10 year old Toshiba. Will never buy Samsung.
  • MassieFamily Nov 17, 2008
    Same problem. It worked for about 2 months and then no longer would read any DVD's even brand new ones.
  • olive_67 Jan 03, 2009
    I bought the DVD-R155 last year and it worked perfectly as well for the two firts months and it started to open the tray automatically and runs by itself and now it does not load any dvd and gives the message no disc or ejects right away the DVD and even if I turn it off , it does not stop opening and closing the DVD tray by itself.
Some DVD players requires installation of software to load some DVD's. Ask your dealer to provide you with a Software CD. Just insert this software CD and then try to run DVD it will work...
Posted on Oct 04, 2008
Dvd door will not open on my Samsung dvd model R155
The gears are jammed, or the timing gear is out sync, or a bad loading belt, plus in rare cases, the gears crack or break.
May 08, 2012 | Samsung DVD-R155
My Samsung Blu-Ray player P1590 doesnt play regular DVD's. is this normal? Whenever I put a regular DVD it tries to load but it eventually posts a message on my TV screen saying "unable" to...
I have a Samsung BD-P1490. When I turn is on the display reads "Load." It never displays "No Disc", or trys to play a disc if one is present. I have never updated the firm ware. Any ideas?
Jan 20, 2011 | Samsung BD-P1590 Blu-Ray Player
Code for unlocking dvd regions samsung r155
hi,
1.Turn on R155 without disc inserted
2. Press and hold Play and Stop for 5 seconds then release
3. Press menu
4. enter code for current region as above i.e if you have a region 4 type: 7, 6, 8, 8, 4
5. The region is displayed in the top right.
6. You have about 5 seconds to enter the new region (1,2,3,4,5,6 or 9 for multiregional)
Region codes for Samsung:
RC 1: 2, 9, 3, 3, 4
RC 2: 3, 8, 7, 6, 7 (or 5, 7, 5, 3, 8)
RC 3: 5, 6, 7, 3, 2
RC 4: 7, 6, 8, 8, 4
RC 5: 5, 3, 8, 1, 4
RC 6: 2, 4, 4, 6, 2
Thank u
Oct 07, 2009 | Samsung DVD-R155
I have a Samsung DVD-R155. When I insert a DVD, the screen reads "load", but eventually it screen will say it can't read the DVD, and then ejects the DVD. It doesn' t matter if it is a new or used DVD. I...
Try using a DVD scanner eye cleaner. It is aDVD with a brush grafted to it. I suspect the scanner eye is dirty so it cannot read the boot starp properly and so ejects
Aug 15, 2009 | Samsung DVD-R155
Won't play dvds but will play cds
The following is a direct link to my tips and tricks.
Mar 09, 2009 | Samsung DVD-R155
LG DVD recorder not playing DVD
When a unit does that it can be a fingerprints on a disc not letting it read the disc and or also that it is not finalized. Can also be a disc format that does not work on unit. Some units only work with either -R or +R and not both. Hope this helps
Dec 23, 2008 | Samsung DVD-R155
Sounds like a bad pick up assy (Laser)
Nov 24, 2008 | Samsung DVD-R155
Samsung DVD Recorder R155
Sounds like you recorded from a camcorder attached to AV2 (front of DVD player). Press the STOP button, then open the menu and finalize the disk.
Mar 04, 2008 | Samsung Televison & Video
Does the DVD-R155 create PC compatible DVDs?
just try to load the dvd disc.and see if it is reading..
Feb 04, 2008 | Samsung DVD-R155
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Samsung DVD-R155 Logo
321 people viewed this question
Henry  Thomas
Henry Thomas
