Question about Rinnai Toyostove Direct Vent Heater: Laser 30 Toyostove Direct Vent Heater Shipping
Error Code 30
Continually get Error Code 30 on new Laser 30 stove.
  • Anonymous Oct 10, 2008
    New Laser 30 after install displays EE30 error code
    Novelist:
  • 126 Answers
The code EE30 has to do with the flame sensor and it's wiring. Either it is touching the cover or the plug is not all the way in on the board. Most of the time this is a problem with a brand new unit. Remove the front cover, then remove the top. Be sure connector F is plugged in correctly.
Tom Hawkins
hawkins111@gci.net
Posted on Jan 06, 2009
  • 57 Answers
It may be the room temp sensor. Have you relocated it? It is on the back of the heater? It needs to be away from the heater where it will not sense the heat high heat coming out of the heater, and also the cold wall behind it. Usually a bit up, and then to the side will work. Play with it and the temp setting til you find one that is comfortable.
My Laser 30 went into power saver mode by itself and now I can't get it out of said mode, otherwise it's working well.
Rick,
Sorry to hear you're having issues with your Toyo, first off do you have a manual for your stove? If not, you can download one online, I've included the link for your convenience.
Your Toyo has a series of control buttons across the top and/or the front, the "On/Off" button for the "Power Saver Mode" is located in the middle. You can turn the mode On or Off, though you actually WANT to utilize the Power Saver Mode. It's intended to prevent unnecessary ignitions on the stove, thereby lowering your electrical consumption as well as wear & tear on the stove. All you need to do is set a maximum and a minimum temperature and whenever the temperature is not within the parameters you've established the stove will then either ignite to heat the area to your pre--determined setting or shut off until the temperature is within the parameters you've established. If there is NO error code(s) showing, and the stove is running fine, then I would not be concerned. Though I do suggest you immediately download the manual, read it thoroughly, and when necessary use it to troubleshoot future issues.
I hope this helps you, good luck and stay warm!
Regards,
Shekele
North Pole, Alaska http://www.toyotomiusa.com/OwnersManuals/Vented%20Heaters/Name%20begins%20with%20Laser/Laser%2030%20(Type%20D).pdf
Oct 09, 2014 | Rinnai Toyostove Direct Vent Heater: Laser...
Lazer 30 error 22 on panel
The stove quit three times with an ee2 message. The stove is trying to save you from flooding. You may have a fuel problem that is causing the ee2 problem. After three time the stove locks out and won't let you try again. Find out whats up with the fuel. Unplug the heater for 20 minutes and you will be able to try again. Also make sure the igniter is getting hot. Two red wires going into the burner should get hot.
Tom
Sep 25, 2010 | Rinnai Toyostove Direct Vent Heater: Laser...
My Laser 30 keeps getting a ee 12 code ans shuts
Ken,
The screen for the circulating fan has lint on it. Remove it from the back top panel and wipe it off. The lint keeps the air from be able to blow over the stove and it overheats.
Good luck,
Tom
Feb 03, 2010 | Rinnai Toyostove Direct Vent Heater: Laser...
Need a service manual for laser 30 toyo stove
Remove the flex hose from the back of the stove. If there is a small hole in the back of the stove, stick a pencil in there and spin the motor. Try to start the stove. If the motor won't spin at all or if it spins freely and the stove still shows an EE8 you need a new motor.
You or your local dealer can change the motor in 30 minutes.
Tom Hawkins
Bethel, Alaska
Jan 15, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
Error code ee2
How long has it been since you last had it cleaned. There may be soot build up in it, including the burner pot keeping it from igniting. When was it last working properly?
Dec 07, 2008 | Rinnai Toyostove Direct Vent Heater: Laser...
Toyostove l73
Try cleaning the fan blades, etc. Does the blower stop after a while and not start again? If there is no ignite at all, could you need to clean your stove. Especially the heat pot?
May 01, 2008 | Rinnai Toyostove Direct Vent Heater: Laser...
Toyostove laser 30
Could it have to do with the temperature sensor? If it is still coiled up on the back of your heater, it may be turning the heater off. You need to uncoil the sensor wire, and place the sensor somewhere away from the heater. One sight said atleast 8" off the ground. (I have a Laser 73 and mine is about two feet to the right and about 8 foot up on my wall as I have a lot.) You can attach it to a board if you have to, or any other item. Just put it as far away from the heat of the heater as you can so it will only be sensing the room air temp. If the line needs to be longer you can cut in stereo wire (I read this online too). Then play with the heat settings to see at what temp it is most comfortable for you. Hope this solves the problem.
Apr 12, 2008 | Rinnai Toyostove Direct Vent Heater: Laser...
Toyo stove, Lazer 30 model
EE22 is a lockout code.
Unplug unit for 30 min.
You need to findout why you still get EE2 or EE6
Check fuel and filter
Still have problems call me I'm in North Pole
Dave 4889179
Apr 10, 2008 | Rinnai Toyostove Direct Vent Heater: Laser...
Error code
Same thing happened to me. Reset your stove top by flipping your fuse off. The stove top will reset and the error code will go away.
Jan 21, 2008 | GE 30 in.JP950 Electric Cooktop
Rinnai Toyostove Direct Vent Heater: Laser 30 Toyostove Direct Vent Heater Shipping Logo
106 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
