Question about Kenmore Elite 45986 Front Load Washer
Kenmore elite smartwash quiet pac 9
I keep getting a flashing f followed by a flashing dl. It's a problem with the door lock not locking when I try to turn the machine on. I had a Sears repair guy out here yesterday and he did almost nothing but press buttons and it worked again. Can you tell me how to make the machine work again?
  • 1 more comment
  • elduce007 Oct 04, 2008
    I don't have a power button on this model. There is a start button, but that solution isn't working. I'm getting the flashing f to dl signal. It's the door lock not working properly that is the problem. Need more help.
    There is no obvious reset button. I don't believe that Sears or their repairmen are in the business of actually solving problems. I believe they're in the "let's build in some problems so we can make some extra money" business. Like I said, he offered little to nothing and charged me 90 bucks for it.
  • elduce007 Oct 05, 2008
    Thanks, but none of these solutions helped me. I'm just gonna have to get the repair guy to come back and finish the job.
    President:
  • 1,952 Answers
Nope only the dryer doors are reversable..last washer to have reverable door that i know of was old neptune
Posted on Oct 04, 2008
  • 1 more comment
  • mohammed marika thambi
    mohammed marika thambi Oct 04, 2008
    Unplug your machine, remove the top panel, doublecheck all of the
    wiring is securley connected. Sometimes the wiring becomes loose due to
    the machine's vibration. Hope this works! It worked for us!
    with panel off reach up to lock location pull down on small tab door
    latch will click (at this point door would pop open if it were closed )
    retry operation to see if ok if code dl reappear may to replace door
    lock if f11 may need new control module under top rear..ck wires first
    ..good luck
    mohammed marika thambi Oct 05, 2008
    better do that... u itself don repair tat..if ur not familiar with electronic components...because it may lead to pay more by causing damage
  • 4,472 Answers
I know that you can try and re-seat the connectors for the processor though you would have to open up the machine to get to these parts and I am not sure if you are trying to get this involved with a repair. Usually this will do it or the latch assembly is about 50$. If you still need assistance let me know. Please take a moment to accept and rate my solution. Also next time ask the tech person what he had to do to fix it. So you know what was wrong and how it was fixed.
Thanks,
Lee
  • Lee A.
    Lee A. Oct 04, 2008
    Well being that the same problem just reoccurred, if he was just there then they need to come back out at no charge to you. If you have any trouble with this let me know. This is basically your best option. Please reconsider your rating and I can assist you further if need be.
    Thanks,
    Lee
  • 3,037 Answers
This is a very common problem with these machines with unfortunately no well known solution
You should try to clean the door locking mechanism and tighten up all bolts for it and call Sears and talk to a repair guy, the same guy that came to your house and ask him for specific directions to what he did and be persistent.
Let me know what works so that we can be more help to others in the future
    Genius:
  • 1,226 Answers
Your system panel got fault, you need to replace the board so that your the system will work properly. However, some of this problem can be resolve by cleaning the board..or by unplugging it from the wall outlet and rest for a while to hardly reset the system.
melnavz
  • Emelio Navaja
    Emelio Navaja Oct 04, 2008
    Yea there is no reset button on that machine, however resetting is maybe pressing the power button for couple of seconds during first start of the machine as said by "kakee" if this solution won;t resolve; suggested you to further expert here in fixya.
    Sergeant:
    Champion:
  • 331 Answers
There must be a reset button on the machine..........
.....by the way didnt the repairman tell u what the problem was??????????
    Genius:
  • 1,269 Answers
Try to unplug the power cable for an hour to reset any static charges. When you turn it back on, press and hold the power button for about 30 seconds then release.
Kenmore smartwash quiet pak 9, wash machine door wont lock
the door latch on the machine is already locked in place
or there is electric circuit issue, the wire going to the lock broken, come loose,
you mite try, resetting the unit it it has reset switch.
or
try unplugging the unit for a while 30 minutes than plug back in try setting up a different wash cycle.
if all fail than call the customer service line ask for technical service.
Oct 04, 2015 | Kenmore Washing Machines
It displays a message: dl and stops
Possible causes: (power off the mains first before checking)
Door lock mechanism is broken or removed from door.
Door switch/lock unit failure.
1. Check door switch/lock unit.
2. Check the wire harness connections of the door switch/lock unit to the Central Control Unit (CCU). The wires shd be secured well.
Try these sites for spares:
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
May 15, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I have a kenmore elite smartwash quietpak 9 HE4t. The control locked light is on. I have tried unplugging for an hour and plugging back in, door is unlocked but no buttons work. What can I DO
The following link explains how to correct a Control Lock problem on a Kenmore Elite:
http://www.fixya.com/support/r2469429-kenmore_elite_amp_whirlpool_duet
Some front panel features differ between models, but the instructions should be listed on the front panel of the washer, and are located in the operator/owner's manual. If these preliminary measures do not work, you may have a mnore serious problem.
If you have any questions, please let me know. I hope this helps you.
Aug 23, 2009 | Kenmore Elite HE5t Washer
Kenmore Elite Smartwash Quiet 9 I can not locate the manual and my washer says ''control locked'' and I can't do anything. How do I unlock it?
The following link explains how to correct a "Control Lock" problem on a Kenmore Elite:
If this does not correct your problem, you may have a more serious issue. Please post back and let me know. I hope this helps you.
Jul 24, 2009 | Kenmore HE3T Washer
My kenmore elite smartwash flashes f and dl when i try and run the wash cycle
Hi
Thanks for using FixYa. Error fdl means a Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code.
It has occurred due to
1. Door lock mechanism is broken or removed from door.
2. Door switch/lock unit failure. To unlock it follow the steps—
a. Unplug washer or disconnect power.
b. Check door switch/lock unit.
c. Check the wire harness connections to the door switch/lock unit and Central Control Unit (CCU).
Please revert for further assistance.
Thanks
Rylee
Jul 21, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE4t Washer Control lock lit, door locked
121 MINUTES USUALLY DRAIN CYCLE PLZ REMOVE 3 BOTTOM PANEL SCREWS 7 MM SCREWS, TO OPEN DOOR SLIDE RIGHT HAND TOWARDS DOOR LOCK ,THERE WILL BE A SMALL LEVER TOO PULL DOWN ,NOW ITS OPEN,,, SINCE U HAVE BOTTOM PANEL OFF PUMP IS RIGHT IN FRONT REMOVE PLASTIC HOUSING CLOCKWISE ,,,REMEMEBER HOLD 3 GALLONS OF WATER STILL ,HAVE BUCKET READY ,NOW CLEAN OUT PUMP AND DEBRIS ,, CLOSE IT UP SHOULD BE FINE NO MORE PROBLEMS ,,,,,
Jan 01, 2009 | Kenmore Elite 45986 Front Load Washer
Washer flashing dl on the screen
"dL" indicates Door Lock Failure: dL flashes if the following conditions occur:
Door lid is not closed completely due to interference.
Wash media buildup is preventing the lock bolt from extending.
Machine/motor control detects open door lid switch when attempting to lock.
Machine/motor control cannot determine if door lock is in a locked state.
Check for lock interference with lid or lock bezel
Dec 14, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Smartwash HE 4T
door lock issue ck for broken door strike on door broken door lock button on door frame also possible connection at main control under top at rear..if moving wires fixes problem try shimming in place only sure fix would be new control..lock not hard to replace remove spring holding door boot on and roll boot back 2 or 3 screws hold lock to frame remove and pull lock to opening remove wires and replace lock
Sep 08, 2008 | Washing Machines
HE Elite Smartwash quiet pac 4 front load washing machine
F32 is the pressure switch issue. Just press and hold the power switch for 5 seconds to reset this error.
Sep 02, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
76 people viewed this question
Sal De
fordexpert
Robert Rankin
