Question about Panasonic KX-TA308 Phone
Doorphones stopped working
I have a KX-T30810 system in my home and both door phones stopped working. I am using VA-20661 door phones that are Ok. Please helpspan.jajahWrapper { font-size:1em; color:#B11196; text-decoration:underline; } a.jajahLink { color:#000000; text-decoration:none; } span.jajahInLink:hover { background-color:#B11196; }
  • nmoore59 Oct 04, 2008
    I don't think it's the power supply. When someone rings the doorbell and I answer it, I can hear them but they cannot hear me. There is a KX-T30860D doorphone adaptor that is common to both doorphones that could be bad. Panasonic no longer makes the KX-T30860D. Is there a substitute or can it be repaired? Also can caller ID be added to this system. Thanks
    The KX-T30810 system was installed in 1991 and has worked fine. I have replaced both door phones in the past with no problem. I am an engineer who can follow your directions. If you can not give me a suggestion than I will take it to a qualified tech. My zip code is 23503
  • 171 Answers
Hi, my name is Todd and I am a Certified Panasonic Telephone Technician.
Sorry for the plethara of incorrect answers. These guys try to be mavens, and most of the time have no clue as to what they are talking about.
First, you need to check the connection on the KX-T30860D and make sure there is solid lock on the clamp.
Then, you should be able to check the voltage on the doorphones, as power is going to them, and just may not be enough or because of a break somewhere in the wiring is not shorting out somewhere.
I will continue.
Posted on Oct 07, 2008
  • 2 more comments
  • Todd Gale
    Todd Gale Oct 07, 2008
    You are correct, these units are discontinued, but you can find some pretty good refurbished units out there. We pay about $199.00 for excellent quality and warranty. I am also aware of one repair facility that does a good job, for a reasonable price.
    Their name is Barclay Enterprises, Inc..
    For $69.00 they will repair your unit and ship it back to you pretty quickly.
  • Todd Gale
    What model phone system do you have, because the KX-T30865 should be a direct replacement unit also, and it is only about $35.00.
  • Todd Gale
    To clarify, those are for the door phones themselves.
  • Todd Gale
    Sorry, I just reread your post and see you have the KX-T30810. There is no replacement for the KX-T30860D.
  • 1,879 Answers
Check the mic section on your end.
trace connection, mute option if there is one.
Posted on Oct 04, 2008
  • Panasonic Master
  • 19,396 Answers
If you cannot hear the signal from any of the two doorphones, then probably it is the common adaptor.
Try posting a request here, this is probably the only place that can have some in stock.
If you cannot find the replacement, take off the module and take it to a good elechtronic repair shop, or test it yourself, if you know how to use a Multimeter.
  • Ginko
    Ginko Oct 04, 2008
    If you know how to solder and use a multimeter, grap your tester, remove the unit, open it and start working on it.
    Test the microphone contacts, see if there is continuity on the wiring, use the multimeter to test impedance on the cable.
    If the mic must be replaced go to any circuit shop , buy a spare one that can fit and solder it back.
    Inspect the board, see if you can spot a burnt area, test main components capacitors etc.
    If you still cannot find the problem, there you will need the service manual.
    There you find all the diagrams to test ICs and other parts, you can buy the service manual here.
    This same job can also be done at any good electronic repair shop.
  • 1,183 Answers
HI,
If both phones have stopped working ,there is the problem with the door phone adapter, the repair or replacement part would be around 94$. The following website would give you exact quote on the repair costs
http://www.qptt.com/csite.htm
800-236-0996 Monday - Friday, 7:30 - 4:30 Pacific time.
Thanks
proton
  • 4,472 Answers
How long have you owned the units and what zip code are you located in. Your best bet is to have a qualified technician look at them. Once I have more info I can assist you further.
Thanks,
Lee
  • 1,800 Answers
Check wires and poewer supply this is the only issue that could occur this problem
Hi,How do I change the answer machine message?
The KX-TGA711 handset can be added to the KX-TGA7160 or KX-TGA7180 system. First, make sure that the answer system is ON. (Use the button on the base or the first few steps below.) For those base units, press the Menu/OK button on the handset. Use the Up/Down arrows to navigate to Answer System. Press the right arrow to enter the sub-menu. If the system is off, turn it on. (Answer On/Answer Off will be displayed on one line. Press the right arrow to access the item.) To record a new greeting, navigate to the line 'Record Greeting' and press the right arrow. Hold the handset about 20 cm away and speak clearly into the microphone. Press Menu/OK to stop recording. Press the Hangup/End to exit and save. A faster access route would be to press 7 and then 6 after accessing the answer system menu. The directions are on page 25 of the manual, which is available from Panasonic and here: http://www.home-phones.co.uk/assets/uploaded/documents/473_7160.pdf . You can do this as a remote operation if you have enabled the feature. Press 7 to record and 9 to stop recording.
I hope this helps.
Dec 14, 2015 | Panasonic KX TGA711 1Line Cordless...
Changing message on answer machine KX-TG6521
From your handset, press Menu then # 3 0 2 (or navigate the screens). Use the up/down arrows to select Yes and press OK. After the beep, hold the handset about 20 cm away from you and speak clearly into the microphone. Press Stop to end the message. (If the message is more than 2 1/2 minutes long, the phone will stop recording automatically.) Press the Off/Power button to exit.
The manual for the KX-TG6521 phone is here: http://www.home-phones.co.uk/assets/uploaded/documents/548_6521.pdf . You can check this for details on changing the message during a remote phone call.
I hope this helps.
Oct 23, 2011 | Lands Phones
I have a Panasonic Model KX-T7030 hybrid system phone. Can't find a battery replacement slot - is there any and if - where to find it?
There isn't on on the phone. However, certain Panasonic models of phone systems have batteries that go bad from time to time. Most noticeably the ones that were KX-T30810/61610/123210/11.
Sinse the phone can work on one of about 18 different Panasonic key systems, you'd need to be a bit more specific as to why you think you need a battery.
Carl
Oct 21, 2010 | Panasonic Lands Phones
Incoming call rings one time and disconnects
Unplug all phones but one in jack 11 at the cabinet and have someone call in. If it doesn't work, you probably have a bad cabinet. If not, I'm guessing one of your extensions is faulty.
Carl
Apr 06, 2009 | Panasonic KX-TA308 Phone
Need to clear out a used kx-tga270s handset
press function, initial setting, registration, deregistration, enter 335(deL) and then press Ok (right button on screen).
Once that is done press mute on the base unit and Ok on the hanset (right button on sreen)
Mar 28, 2009 | Panasonic KX TGA270S Cordless Expansion...
No KX-TGA101S communication with KX-TG1033S
The additional handsets must be registered to the base unit. Here are the instructions from the manual:
HANDSET
1. [menu}
2. "handset settings" - OK
3. "Registration" - OK
4 "HS registration" - OK
BASE UNIT
Press and hold [LOCATOR] until the registration tone sounds.
-if all registered handsets start ringing, press {LOCATOR] to stop, then repeat this step.
-after the base unit beeps, the rest of the procedure must be completed within 1 minute and 30 seconds.
HANDSET
Press [OK], then wait until a beep sounds and Y stops flashing.
Jan 31, 2009 | Panasonic KX-TGA101S Cordless Handset
Panasonic kxt7730
Here is a link for the 7730 manual.
http://www.walterbridge.com/manuales/KXT7720-User-Guide.pdf
Aug 30, 2007 | Panasonic KX-T7730 Corded Phone
Retrieve messages away from home on a Panasonic KX-FPG381
You have to set a polling number, you WILL need a manual. Use your keypad just enter this number when you phone home
Aug 12, 2007 | Panasonic KX-FPG381 Plain Paper Thermal...
Answering system
It first sounds as if the handset isn't charged properly. Check the battery status first. The manufacture advises to charge the system for approx. 7 hours before any use occurs. Second, make sure that the registration took, when programming the phone originally. I would de-register the handset by: 1 {MENU} i {0}{0}{2} 2 {3}{3}{5} i {OK} 3 Select the handset you want to cancel by pressing the desired handset number ({1} ? {4}). Then re-register by: 1 Handset: {MENU} i {0}{0}{1} 2 Base unit: KX-TG6021/KX-TG6022/ KX-TG6023 Press and hold {LOCATOR} until the IN USE indicator flashes. KX-TG6051/KX-TG6052/ KX-TG6053/KX-TG6054 Press and hold {LOCATOR/ INTERCOM} until the IN USE indicator flashes. LAfter the IN USE indicator starts flashing, the rest of the procedure must be completed within 1 minute. 3 Handset: Press {OK}, then wait until a beep sounds. 4 {OFF} Third, make sure that the display on the handset does not show "SP-Phone" in the display, if it does press the phone icon button. Fourth, Do you currently have voicemail from your phone service provider? If so, the answering machine will not answer. Make sure that the answering machine portion is turned on. Do this by: Press {ANSWER ON} to turn on/off the answering system. When the answering system is turned on, the ANSWER ON indicator lights. When the answering system is turned off, the ANSWER ON indicator turns off. If there are any further questions or comments, please post here. Please rate this solution through fix-it. Thank you
Jun 22, 2007 | Panasonic KX-TG6021 Cordless Phone
Panasonic KX-TA308 Phone Logo
103 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
