Dell Latitude D630 Notebook Logo
saleem akram Posted on Dec 22, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dell d620 battery problems
1.battery not charging 2.battery not charging after 30 to 40 percent new battery 3.battery firmware required 4.50% or above charged battery shutsdown when reaches 50% level 5.good battery become bad does not charge immediatlty when good it gives good time 3+ hours suddenly bdecomes bad does not charge.
Prashant Sharma
Level 3:
Genius:
  • Master 1,127 Answers
  • Posted on Dec 22, 2011
Prashant  Sharma
Master
Level 3:
Genius:
Answers
1127
Questions
0
Helped
237390
Points
3825
Hi Saleem,
Please sure you can buy the genuine battery or buy form Dell service center.
Battery not charging dell inspiron 630m
Determine if the laptop battery is defective. While less than 1 percent of batteries are defective, the possibility is still there. If the battery is new and only charges some of the way, it may just require a BIOS update to charge fully. New batteries that refuse to charge at all may be defective. Purchase a new dell inspiron 630m battery to replace the defective one.
Test the laptop power adapter to see if it's faulty. Run the laptop directly from the laptop power adapter and without the battery. If the laptop does not work with the adapter plugged in, the adapter is dead and you will need to replace it. The laptop battery may refuse to charge if the adapter is faulty. Charge the battery with the laptop turned off.
Insert the laptop battery into another laptop to test it. If the laptop battery charges in another laptop, the laptop's motherboard may be bad. Replacing a motherboard in a computer can be very expensive. If the cost to fix the computer is not worth the cost of replacing the motherboard, consider purchasing a new laptop.
Reinstall the battery to ensure all connectors latch properly. The latch mechanism that holds the laptop battery should click into place. If the latch does not close, remove the battery and examine the compartment for signs of damage.
5
Troubleshoot the BIOS to determine if there is a hardware problem. Turn on the laptop and immediately enter BIOS setup by holding down the "Del" and "F1" or "F2" keys, depending on the make and model of the laptop. When the BIOS screen appears, see how long it takes for the battery to charge down. If the battery does not last as long as the BIOS setup, a hardware failure may be the problem.
tip
Dell latitude d620 Battery
We are a professional manufacturer and distributor of all types of replacement batteries and battery chargers. Full one year warranty for every replacement battery and battery charger; Our Dell latitude d620 laptop batteries last longer per charge and will last longer overall because whenever possible we only carry name brand battery cells. Our goal is to meet or exceed the performance of your original batteries and it means that you can use our lithium ion battery to replace yours. We assure that we use only high quality parts that equal to or better than the original so you can feel good about having a positive impact on our environment when you use our Dell latitude d620 batteries. In our store you will find a right products at very competitive prices so you will save lots of money.
  • Chemistry :Li-ion
  • Voltage : 11.1V
  • Capacity :4400mAh
  • Color : Metallic Grey
  • Condition : Brand New
  • Availability : In Stock
  • List Price : £ 55.88
  • Now Price : £ 40.88
  • Dell latitude d620 Battery Description
    We focus on bringing you the best replacement Dell latitude d620 battery to our customers and hope that our customers can buy their satisfying Dell batteries, the Li-ion laptop battery on sales will be the perfect replacement to your original Notebooks. We guarantee the Dell latitude d620 battery with a full one-year warranty from the date of purchase, 30-days money back, if the battery(s) have any quality problem! If you have any question or suggestion about this Dell latitude d620 Battery,Please contact us
    on Mar 26, 2010 • Computers & Internet
    1helpful
    Battery light flashs orange continusly on a dell latitude d620 if i disconnect the power cord the computer shuts down
    Two possible causes for flashing Amber battery light.
    1) Your battery won't charge and needs to be replaced.
    2) Your charging circuit for the battery is defective and then your motherboard of laptop will need to be replaced.
    My dell d620 doesnot charge at all battery is always at o percent i have chaged battery and ac power adabter still thesame problem ps i need help
    Hi!
    Most likely the problem is situated in the power supply part on the mainboard. In order to be sure, please post again a comment and tell me if the laptop works if battery removed and only on external power.
    Regards,
    Bogdan
    My battery light flashes 4 times orange and 1 time green. It will run on the ac adapter. But the battery icon says that the battery is at 0 percent. what is the problem?
    You can try removing the battery and unplugging the power cable for 5 mins. Charge the battery for 8 hrs. Tried running notebook with battery only. If it will not turn on, make sure you contacted dell for the BIOS firmware update before replacing it. You can also visit their support site for the latest BIOS firmware http://support.dell.com/support/index.aspx?c=us&l=en&s=gen&~ck=mn
    4answers
    Edited by tech1: Battery problem on old laptop dell, the most common failure on any PC laptop/notebooks'and tablets.
    the batteries eventually wear out and quit taking a charge. You can run the system without a battery with no ill effects. replacements are about $100 for a new battery
    2answers
    My laptop does not recognize any battery (New or Old)
    you need to go to setup F2 when system is booting, and do the battery configuration there
    Dell Latitude D620 isn't getting power to the mainboard.
    diagnostic procedures as follows:
    1. Turn off the computer and peripherals, and disconnect them from AC power.
    2. Reseat each installed battery by removing it and then replacing it.
    3. Turn on the computer. Does the green power indicator light up?
    Allow one minute for the computer to initialize its components before checking for signs of power.
    Yes. Continue to step 4.
    No. Use the AC adapter to connect your computer to AC power. If the computer operates normally when using AC power, go to step 7. If the computer does not boot when using the AC adapter, see the previous subsection, "Total Power Failure When Using the AC Adapter."
    4. Does the battery indicator flash amber or show a a steady amber light?
    Yes. The battery needs to be charged. Go step 5.
    No. Go to step 7.
    5. Connect the computer to AC power, and fully charge the battery.
    For instructions, see the topic titled "Charging the Battery" in the online System User's Guide.
    6. As the battery charges, does the green battery indicator light up?
    Yes. Go to step 9.
    No. Go to step 7.
    7. Is the battery indicator flashing green and amber?
    Your computer may be in a hot environment. Charging the battery in this condition may affect the life span of the battery.
    Yes. Continue to step 8.
    No. The problem is resolved.
    8. Disconnect the computer from AC power. Is the the battery indicator still flashing amber?
    Yes. You may have a defective battery. Continue to step 9.
    9. Remove the battery, and press its test button. Is the uppermost indicator in the charge gauge of the battery flashing?
    Yes. You have a defective battery. Continue to step 9.
    10. If a spare battery is available, fully charge it, and then install it in the computer.
    11. Turn on the computer. Is the power indicator off?
    Yes. Your original battery is defective. get a new battery replacement.
    No. Call Dell for technical assistance.
    if you need Dell latitude d620 Battery you can go to online shop
    http://www.global-battery.co.uk
    http://www.sales-batteries.com
    here you can perchase high quality battery easily
    good luck!
    2answers
    Is any cheap battery for laptop d620
    Hi - i've ran a D620 now running a D630 and yes the battery life is extremely poor even when the battery is new.
    The option above will give you extra - you can also buy a moduler battery that will fit into the CDROM port which will give you even more!
    http://www.google.co.uk/products?hl=en&q=d620%20modular%20battery&cr=countryUK%7CcountryGB&um=1&ie=UTF-8&sa=N&tab=wf
    or ebay is your best bet...
    1helpful
    3answers
    BATTERY PROBLEMS?
    Hi
    Latitude D620 battery module has a battery charge tester. First remove the battery or turn the laptop over and press the battery icon and the note the battery LED indication.
    If there is no LEDs lite, shut down the laptop, connected the power Adaptor, install the battery and check if the battery charge LED lites up.
    If it doesn't double check the power Adaptor. Latitude D620 is rated to use a 90W Adaptor. There is a 60W Adaptor (looks very similar to) but this is for other Latitudes and AMD Vostro systems.
    If the Adaptor has the correct rating, then check below for more info;
    1) [Very Likely] The battery may be faulty or end-of-life and needs replacing. Check the battery connector on the Latitude and battery itself for any broken or bent pins or bits.
    2) [Possible] You have the wrong power Adaptor or the Adaptor is faulty. This however would not explain why the battery is undetected.
    Start up the Latitude into System BIOS (F2). Under System > Battery information check the battery and AC Adaptor status
    If the Latitude D620 has warranty you may open a warranty claim with Dell Support.
    Mike
    Grand Canyon Tech
    Grand Canyon Tech
    SmartAviator
    SmartAviator
