Ac unit what is the best way live it on auto or on
  • 104 Answers
On for continous air circulation
Posted on Oct 04, 2008
Can a pro recommend a comperable replacement wall AC only-no heat?
Most air conditioners now are reverse cycle, which means that they can heat as well as cool. Cooling only units were popular many years ago due to the price difference for a reverse cycle. Today, the cost of manufacturing has dropped and it has resulted in cooling only units being virtually finished. I would suggest you get a local air con sales company to come to your house to measure up properly and determine what would be best. There are a lot of factors in installing air conditioning. IE/ The size of the house, the area it will be required to heat / cool, the amount of windows, types of walls, roof etc (Heat loading on the house) Roof and wall insulation etc etc.
Apr 09, 2014 | Heating & Cooling
I Have a Mitsubishi Lancer 06, 1300cc when ac is
Welcome to the club, The AC units in cars use a large amount of power to run. Your is a 1300cc motor which is almost smaller then the AC unit itself, lol. What you have is normal and to fix it would be to get a bigger engine to run the AC. Everything strains a bit when the AC is on, all cars do it and yours being as powerful as a skateboard doesn't help. Your going to have to live with the problem of an under powered vehicle doing it's best to keep you cool. :.)
Aug 16, 2013 | Mitsubishi Lancer Cars & Trucks
96 deVille. Think the oil pressure sending unit is leaking. How do you remove. Mine is located above the AC pressure lines and I can't reach.
Hello: The oil pressure sending unit is located on the oil filter adapter, which is behind the lower front engine mount. It is best to get a deep oil pressure socket to do the task. Check with Advance Auto, Auto Zone, O'Reilly, or NAPA for the socket.
Jul 25, 2011 | 1996 Cadillac DeVille
Where can i buy freon for ZW6500R Zenith window unit. 66012
Freon is no longer used for window AC units. You need R142a refrigerant gas. Most auto supply stores and even Walmart carries it. However, having the gas is one thing. Having all the proper equipment to evacuate and recharge your compressor is another. Please be careful. It's best left to the pros.
Jun 30, 2011 | Heating & Cooling
My a/c does not shut off when i press the off button
If your ac doesnt shut off when you press the switch then you have a bad switch that will need to be replaced. You can go to your local auto parts store and tell them the on/off switch for the ac unit is the part that you need. IT should only cost a few dollars depending on where you live.
Jun 16, 2011 | 2007 Lincoln Navigator Ultimate 4x4
Vocalist live 2 problem. power to unit OK , lights up. Guitar output OK. No tuner, no vocal output.
NO power light or audio from Digitech Vocalist 2 live. Check that your power adapter is for 9 Volts AC (not DC like most pedals) and is rated at 1300ma or more. A DC adapter MAY light up the unit but not make it pass audio. Lights can be lit but that is NOT an indication thaat correct power is applied. They likely use the AC input to generate both positive and negative voltage within the unit. The use of a DC adapter will prevent generating one of these required voltages and prevent audio from passing.
Ac compressor pulley siezed, wondering if I can just get smaller belt and bypass
there is a site called monster auto parts. com they sell a bypass pulley that you replace your ac compressor with. it's about 35 dollars, but you may find one. less shipping charges locally where you live at an auto parts store. good luck!
Jan 02, 2011 | 2001 Ford Taurus
I have two outside ac one for floor and other for upstairs and i button on heater auto and ac outside fan is running is that normal or not? and live on this new house for two years and cant find someone...
No the fan out side is for a condensing unit and compressor. The compressor should not run with the heat. I am almost positive that if this is not a heat pump that the compressor unit should not be running.
Dec 20, 2010 | Goodman GMS90703BXA Heater
Can I mix brands/tons when installing AC unit to existing coils?
First off - the 'rule of thumb' is 600' per ton of Air Conditioning. In other words your old unit is a 2 ton unit. So - 2 tons x 600' = 1200'. As you can see if you install the 2.5 ton unit - you will be installing a AC that 'could' cool a 1500 sq ft house (2.5 x 600' =1500 sq ft.). Slightly more than what you need; and the 3.5 ton unit is 'way to big,' (3.5 x 600' = 2100 sq ft.).
Note: fyi - many in the AC business will sometimes refer to tonnage in btu's, i.e. 1 ton = 12000 btu - hence a '2 ton unit' can also be referred to as a 24000 btu unit and vice versa.
So... from the above - you can easily see that "2 tons" of Air conditioning is what is required to cool the 'average' home of 1100 sq ft. "roughly speaking."
Note: it is always best to have a professional 'size' your cooling/heating needs.
One of your questions was could you 'mix tonnage?'
The answer is 'usually you don't mix the tonnage of your outside/inside units.' However, professionals sometimes do (mix the tonnage) in certain situations, and installing a 2.5 ton outside unit with an existing 2 ton inside unit is often done, however, there are some 'tech issues' here and - I would "again" recommend that you call a Service Tech to help you with the sizing/mixing of your cooling/heating needs.
hope this has helped
Jun 20, 2010 | Carrier 38CKC036 Air Conditioner
a programable thermastst has different modes. in auto it can deside whether to apply heat or cooling. ac air coditioning. or you are in ac mode, but should notice the ac unit comming on. if no ac unit then of corese it won't come on :)
Jan 15, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
