Question about Apple iPod classic MP3 Player
Videos On my instruction page that came with my ipod classic it said: by pressing the center button during a video you can skip to any part in the movie. But mine doesn't do that. Is it because they're converted videos?
  • 31 Answers
Hey, Id be happy to help. Actually you can't just click down the center button during a video to skip to a certain part, you must click down once than once again and in the playing bar there should be a little blue diamond piece that represents where you are in the video. Now, you must move your finger around in a circle formation around the Ipod ring, and you will see the diamond piece move to wherever you move your finger. This controls where you can skip in the vid. Thanks! and I hope this helps ;)
Posted on Oct 11, 2008
SOURCE:
Unlock
The iPod is a portable music player made by Apple. As of early 2011, Apple sells four models: iPod shuffle, iPod classic, iPod nano and iPod touch. If your iPod experiences a problem such as not responding or freezing, you can reset it to see if that takes care of the problem. IPod Shuffle The iPod shuffle is the smallest iPod model, with 2GB of storage.
It has no screen and attaches to your clothing with a clip, making it well suited for exercising while listening to music.
When it doesn't respond, or if the status light is solid red, you can reset it.
Slide the three-way switch left toward the word "Off," covering the green bar. Wait 10 seconds, and then slide the switch back to reveal the green bar to turn it back on.
IPod Classic
The iPod classic has a 160GB hard drive for storing music, videos and pictures.
If it experiences a problem, you can easily reset it.
Slide the "Hold" switch to the "Hold" position and then slide it back.
Press "Menu" and the center button simultaneously on the click wheel and hold them for about six seconds, until Apple's logo appears on the screen.
IPod Nano
Apple's iPod nano has a touch-screen display and comes with 8GB or 16GB of storage, depending on the configuration.
It has a pedometer and an FM radio.
If the iPod nano doesn't respond, reset it.
Press the "Sleep/Wake" button and the "Volume Down" button simultaneously and hold them until the screen gets dark, and then wait a few more seconds until the Apple logo appears on the screen, followed by the home screen.
IPod Touch
The iPod touch has a touch-screen display, two cameras for shooting pictures and movies, and Wi-Fi for accessing the Internet. Its capacity ranges from 8GB to 64GB, depending on the configuration.
You can use the iPod touch to send email and make video calls, as well as play games and run applications. If the iPod touch freezes or otherwise isn't working, you can get it running again after resetting it.
Press the "On/Off-Sleep/Wake" button and the "Home" button simultaneously for at least 10 seconds, until Apple's logo appears on the screen.
Jun 24, 2013 | Apple iPod classic MP3 Player
Tip
IPod Nano/Video/Touch Resetting
One day your using your iPod and all of a sudden, boom. It turns off and refuses to work or read by your computer.
You might get the apple logo, but thats where it ends. In this case, theres a few things that can probably bring you device back and kicking.
iPod Nano/Video(Classic)
6th Gen Nano
Press and hold the Sleep/Wake button and Volume Down button simultaneously for at least eight seconds or until the Apple logo appears. You may need to repeat this step.
If the above step did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. Try resetting the iPod while it is connected to power.
4th and 5th Gen Nano/Classic/Video (CLICK WHEEL VERSION)
1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
In case the reset does not work, the alternative is to connect the device in disk mode and restoring it.
  1. Before placing the iPod into disk mode, you should verify that it is charged.
  2. Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.)
  3. Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
  4. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears. zero77cool.jpg
  5. Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect"
This will enable a black/white display. Restore it using iTunes.
If the above doesnt work, then Im afraid its time to repair your device.
Note: images and part of help copyright © 2011 Apple Inc. All rights reserved
on Mar 13, 2011 | Electronics - Others
How do i delete vidios on ipod nano?
Select the video then press and hold the center button until the options appear. Choose Delete then press the center button.
If you want to transfer the recorded video or music from iPod Nano to computer, this step by step guide would help you a lot.
http://www.ipod-transfer-copy.com/how-to-transfer-ipod-recorded-video-to-computer.html
Hope it helps. Contact me if you have any other question.
Feb 01, 2010 | Apple Audio Players & Recorders
How do I delete videos
You can remove the videos by:
1. Open Videos.
2. Select Camera Videos.
3. Select a video.
4. Press and hold the Center button.
5. Select Delete, or to remove all the videos, select Delete All.
Or you can wipe the entire iPod by:
Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
Jan 12, 2010 | Apple iPod nano
My ipod has a circle red x on it and wont respond
First try resetting the iPod. If this does not work then restore it.
To RESET IPOD: 1 Toggle the Hold switch on and off (slide it to HOLD and then back again). 2 Press and hold the Menu and Center buttons for at least 6 seconds, until the Apple logo appears.
To RESTORE IPOD To update or restore iPod classic: 1 Make sure you have an Internet connection and have installed the latest version of iTunes from http://www.apple.com/itunes/download/?ipod 2 Connect iPod classic to your computer. 3 In iTunes, select iPod classic in the source list and click the Summary tab. The Version section tells you whether iPod classic is up to date or needs a newer version of the software.
In Restore all data is erased from iPod classic, including songs, videos, files, contacts, photos, calendar information, and any other data. All iPod classic settings are restored to their original state.
Jul 19, 2009 | Apple iPod classic MP3 Player
120GB classic ipod is corrupt
You will want to attempt to force the iPod into disc mode then restore using iTunes. With the iPod in disc mode, iTunes should show the iPod. You will have to restore the iPod to resolve the issue of corruption though. Please let me know if this does not resolve your issue. :)
Putting ipod into disc mode http://support.apple.com/kb/HT1363 Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.) Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect" If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center.
If you are still unable to put your iPod with a Click Wheel into Disk Mode, use one finger from one hand to press the Select button, and one finger from the other hand to press the Play/Pause button.
How to restore iPod (ARTICLE NUMBER HT1339)
Open iTunes, and then connect your iPod to your computer using the USB or FireWire cable that came with your iPod.
After a few moments, your iPod will appear in the Source panel in iTunes.
Select your iPod in the Source panel and you will see information about your iPod appear in the Summary tab of the main iTunes windows.
Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download the latest iPod Software.
The 4 possible restore options are: Restore Option
1: Restore - Restores with same iPod Software version already on iPod. Restore Option
2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available. Restore Option
3: Use Newest Version - Restores with the latest iPod Software available. Restore Option
4: Restore and Update - Restores with the latest iPod Software available.
If you are using a Mac, a message will appear prompting you to enter an administrator’s name and password.
A progress bar will appear on the computer screen indicating that the first stage of the restore process has started.
When this stage is completed, iTunes will present one of two messages on screen with instructions specific to the iPod model you are restoring.
Restore Instruction 1: Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models).
Restore Instruction 2: Leave iPod connected to computer to complete restore (typically applies newer iPod models).
During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage.
Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
Feb 17, 2009 | Apple iPod classic MP3 Player
Ipod troubles
Put the switch on hold then unhold it
now press the center and the menu button simultaneously for about 6 seconds
till the apple sign appears.
May 27, 2008 | Audio Players & Recorders
IPod Classic - video skips
i plug in my 80gb ipod and a thing pops up and says itunes has detected an ipod that appears to be corrupted. You may need to restore this ipod before it can be used with itunes. you may also try to disconnecting and reconecting the ipod. and so i restore it and it still comes back up
Nov 27, 2007 | Apple iPod MA446LL/A MP3 Player
Apple iPod classic MP3 Player Logo
Top Apple Audio Players & Recorders Experts
Ekse
Jeffrey Groves
Jeffrey Groves
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
