Question about JVC AV-48WP30 48" Rear Projection Television
Convergence problems on AV-48WP30
I Can't adjust the red horizontally far enough to the left.
Convergenge went out suddenly. I can adjust the blue and red but can not get the red to go far enough left to line up with the rest the green does not move at all . I saw a post about this and somone said to change the IC804 controls. Replace them both with STK392-110 or stk-150 or stk-180 . Also, check for cold solder joints in the vicinity of these ICs. was also told to use a 45 watt sodering iron and soder wick (does that sound right or should I use a smaller or bigger iron. also are those stk chips name brand specific or does it not matter. Thanks for you help in this
    Novelist:
    Champion:
  • 203 Answers
Thats correct you need to replace both stk's (STK392-110 will work I would get them from www.bdent.com) You will also need to put heatsink compound on the back of these to keep them from going bad prematurely. Also all resistors on that board will need to be checked to make sure non of them opened when the stk's went bad. Let me know if you need anything else!
Thanks
Tim
Experttv@comcast.net
Posted on Oct 05, 2008
I CANT ADJUST THE RED VERTICAL LINES ON MY JVC REAR PROJECTION TV. i HAVE DONE CONVERGENCE AND MANUALLY ADJUSTED THE RED LINES HORIZONTALLY, BUT NO LUCK WHAT CONTROLS TO USE VERTICALLY
If it will not adjust up or down or left and right the convergence chips need to be replaced.
See attached photos of board that is in your set:
This can be a do it yourself repair and the parts do not cost a fortune.
Can I help?
SD TECH
Oct 16, 2011 | JVC AV-48WP30 48" Rear Projection...
The blue crosses are too far right of center to adjust
you will need to install a convergence repair kit. You can get the convergence repair kit for your model at www.tvrepairworld.com which also contains the CD with step by step instructions for the repair.
Mar 28, 2010 | JVC AV-48WP30 48" Rear Projection...
On our JVC AV-48WP30 48in, red shadows
some how the convergence ckt went bad,common problem to pj televisions.
Mar 19, 2010 | JVC AV-48WP30 48" Rear Projection...
When we try to adjust red cross, red adjustment will go side to side but not up and down. Red horizontal line is curved instead of a straight horizontal line. Blue can be adjusted up and down and don't...
Thats the classic sign of failed convergence ICs and resistors. You can get the convergence repair kit for your model at www.tvrepairworld.com the kit contains the parts and the Cd with instructions.
Mar 09, 2010 | JVC AV-48WP30 48" Rear Projection...
Convergence problem
The convergence IC's need to be replaced. STK392-110. There are two chips and they both should be replaced in tandem. After that a simple customer convergence is all it takes to get it back to normal.
Search around there's better descriptions about the solution to this problem at fixya than what I just typed. But basically you replace those two IC's and then check all the resisters and you're good to go.
Oct 23, 2008 | JVC AV-48WP30 48" Rear Projection...
Convergence problem wiht jvc av 48wp30
Bad chips...There are a ton of cheap fakes out there....Or bad resistor...
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 29, 2008 | JVC AV-48WP30 48" Rear Projection...
Suddenly, the screen shows double images on letters and numbers plus red/greenish like shadows on characters.
Youre convergence Ics need to be replaced. post the model number of your set and I will post the STK number that you need and a link where you can get new replacement ICs
May 25, 2008 | JVC AV-48WP30 48" Rear Projection...
Convergance problem
Your convergence IC's are bad and maybe a few of the supply resistors. Not an expensive repair but definantly something you would want a technician to do for you. Hope this helps.
Mar 23, 2008 | JVC AV-48WP30 48" Rear Projection...
Convergence problem
sounds like convergence amps bad
Oct 23, 2007 | JVC AV-56WP74 56" Rear Projection...
JVC AV-48WP30 48" Rear Projection Television Logo
61 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
