Question about Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop
Usb devices when ever i use a usb device onto my usb ports of my laptop and press any key of my laptop then the usb device restarts again...
  • Lenovo Master
  • 4,338 Answers
Do you mean that the USB device unloads and reloads when you hit a key?
Does it do it with a different USB device?
Remove all USB devices, then:
Go to Control Panel > System >Device Manager >Hardware >
Un-install the USB ports, then restart the computer.
Let me know the result.
Please remember to rate all users who assist you for free :)
Posted on Oct 04, 2008
USB ports do not work
Check if usb ports are enabled from BIOS. To enter BIOS set press F2(it may be something else depending on mother board).>>>
Reinstall USB drivers with device manager. If u uninstall all usb ports and then restart windows surely install it again automatically for u.>>>
Still not working call expert to repair.
For ant other assitance swapnil.bhujbal500@gmail.com
Jan 08, 2012 | Acer Aspire 5500 5570-2609 Laptop
Dell inspriation N5010 laptop this laptop all usb port is not working . laptop purchising in 3month and windows 2007 operating system instaled what is problem please sole the problem
If USB devices such as jump drives, digital cameras, or printers are no longer functioning properly when connected to your laptop, the USB ports may have malfunctioned. There are plenty of troubleshooting steps you can complete on your own to get the port up and running properly again.
1.Connect the USB device into a different USB port on the laptop or another computer to make sure the problem isn't with the device instead of the port. Check to see if the device has a "Write-Only" tab. Push that tab into the unlocked position if it still isn't working in a different port.
2.Click "Start" and then "My Computer" if the device works in another computer but not on your laptop. Plug a device into the port and wait to see if the USB port shows up in the list of drives. Click on "Map Network Drive" if the drive does not appear. Choose a drive letter from the drop down menu and then double click the location of the USB device. Click "OK" and try to use the port again.
3.Navigate back to the Start menu and then click "Control Panel." Double click on "Device Manager." Scroll down the list of options and click the "+" located to the left of the entry labeled "Universal Serial Bus Controllers." Double click the name of the USB port that appears in the new menu. Click the "Drivers" tab and then click "Update Drivers." Wait for the driver to finish downloading and attempt to use the port again.
4.Close the drivers tab and right click the name of the USB port. Click on "Properties." Click the "Power Management" tab and then un-check the check box labeled as "Allow the computer to turn off this device to save power." Choose the "Communications Port" tab and then scroll down to the box labeled "Resources." Click the "Enable Device" button and then click "OK." Attempt to use the USB port again.
5.Close the Properties tab and right click the name of the USB port. Click on "Uninstall." Restart the laptop and then plug a device into the USB port. Wait for a new window to pop up and follow the on-screen instructions to re-install the USB port software.
6.Restart the computer and press the "F1" button on the laptop's keyboard once the manufacturer's name appears on the screen. Scroll down through the list of options that appear and highlight the option labeled as "Advanced." Press "Enter" and then scroll down and press "Enter" on the "USB Support" option. Press "F10" to save the settings and finish loading the operating system.
7.Open your web browser if your laptop is running the Windows XP operating system. Navigate to the Microsoft website and download the Windows XP USB 2.0 driver (see link in Resources). Restart the computer and try to use the USB port again.
I hope you find it very helpful. Best regards.
Aug 18, 2011 | Computers & Internet
I just bought an ASUS notebook but the USB cannot read any device what do i do?
Hi,Some USB devices are not APM/ACPI friendly and may not operate properly after resuming from Standby or Hibernation. Some of these steps may not apply to your computer. Test the attached USB device after performing each step.
1. Verify that a USB port and an operating system with USB support are being used to attach a USB interface external device to a ThinkPad system.
Note: The following is an example image of a ThinkPad system USB port
USB port
2. Verify that the latest BIOS and embedded controller for the ThinkPad system has been installed.
View the latest BIOS files for all ThinkPad systems(-307.ibm.com/pc/support/site.wss/BMOE-3VAM8Y.html)
3. Verify that USB is enabled in BIOS.
* For ThinkPad A, G, R, T, X and Z series systems
1. Turn on the computer.
2. While the "Press F1 for BIOS Setup Utility" or "To interrupt normal startup, press the blue Access IBM button" message is displayed at the lower left area of the screen, press the F1 key, blue Access IBM, or ThinkVantage button.
3. Select Config and then click USB. The window should list USB BIOS support as [Enabled].
For ThinkPad 600, 600E, 770, 770E/ED, 770X, and 770Z systems
1. Press and hold the F1 key and then turn on the computer. Hold the F1 key until the Easy-Setup menu appears. If a password prompt appears, type the correct password.
2. Select Config.
3. Select Initialize and then click OK.
4. Click Exit, click Restart, and then click OK to restart the system
4. Verify that the USB device and any required drivers were installed in accordance with the manufacturer's instructions.
This may require removing the USB device and the drivers, and then reinstalling the USB device and the latest drivers.
5. Verify the USB device works on another machine, if available.
6. Verify another USB device, if available, works on this machine.
7. Verify that the USB device is USB 1.1 or 2.0 compliant.
Plugging specific USB 1.1 compliant devices into a USB 2.0 compliant port will cause an error message dialog box to appear. That dialog box details that a non-high speed device has been attached to a high speed port. The device should function normally, but at a slower speed than if a 2.0 device is attached to 2.0 port. Most USB 1.1 devices will function normally in USB 2.0 ports.
8. Verify that external power is attached if required.
Some USB 2.0 devices will require additional power from external sources or an additional USB port to function correctly in USB 1.1 compliant computers.
9. Verify that the latest Microsoft Windows Service Pack has been installed for the operating system installed on the computer.
There are updates and fixes to USB 1.1 and USB 2.0 available in Service Packs.
10. If an operating system was installed from a retail CD, then refer to installing USB 2.0 support on ThinkPad systems.
11. Test the USB port for errors.
Run the PC Doctor diagnostics for all current ThinkPad systems. PC Doctor for DOS is available by pressing the F11 key or the blue Access button during startup to access the predesktop menu area. If these methods are not available for your system, then PC Doctor for DOS may be downloaded. This DOS version requires two or more floppy diskettes depending on the ThinkPad system.
12. If these steps have not solved your problem:
Refer to "Need more help?"
You could also try downloading an updated/fresh copy of the drivers for my specific model notebook from Asus's web site and just reinstall over the old ones.
And if you don't understand much about it, i would advice you take it back from where you bought it from and get a replacement if it's on guarantee...
Thanks for using fixya....
Nov 01, 2010 | Computers & Internet
USB PORTS HAVE STTOPED GIVING ANY POWER TO DEVICES.
Go to the Manufacturer's website and download the latest drivers.
Aug 19, 2010 | Packard Bell Computers & Internet
USB port not registering
Try with different USB devices on all the USB ports of your Notebook. Check if those devices which is not detecting in the Laptop, working on other systems.
(If one of the three is not working, then its a hardware issue). If all the ports are not working, you can try the following steps.
1:
1. Disconnect the AC Adapter.
2. Remove the Battery.
3. Hold the Power button down for 30 seconds to 1 minute.
4. Reconnect the AC adapter and do NOT connect the battery now.
5. Turn on the Notebook power.
2. Update your BIOS:
a) Open www.hp.com in the search field type your Laptop product number (eg:AB123UA), can be found on the sticker pasted on the bottom of the Laptop.
b) Click on Software & Drivers
c) Select the Operating System (Make sure you are using pre-installed OS only)
Note: Do not install BIOS on retail or changed OS
d) Install BIOS and restart.
3. Re-install USB entries
1. Save and close all programs that are currently running.
2. Click Start, select Shut Down, and choose Restart the computer.
3. Press the F8 function key or the Ctrl key when the HP logo appears. This will display the Windows Startup menu.
4. Select option 3 to load Windows in Safe mode.
5. After Windows loads in Safe mode, Click Start and select Control Panel.
6. Double-click the system icon. If the System icon is not found directly under Control Panel, click the Performance and Maintenance icon and then click the System icon.
7. The System properties Window opens. You can open the System Properties window directly by pressing the Windows key and Pause/Break key simultaneously.
8. Select the Hardware tab and click the Device Manager button.
9. In the Device Manager Window, double-click the Universal Serial Bus controllers.
10. Right-click the device listed under Universal Serial Bus controller and select Uninstall.
11. Click OK to confirm the removal of the device.
Restarting the notebook will automatically install the drivers.
That's it. If there is no luck, your Laptop required an onsite diagnose. Contact HP or local service center.
Jul 27, 2010 | Compaq Computers & Internet
My usb ports are not working
USB ports There are two ways to solve this;
A. To remove and reinstall all USB controllers.
Follow these steps:
  1. Click Start, click Run, type sysdm.cpl in the Open box, and then click OK.
  2. Click the Hardware tab.
  3. Click the Device Manager button.
  4. Expand Universal Serial Bus controllers.
  5. Right-click every device under the Universal Serial Bus controllers node, and then click Uninstall to remove them one at a time.
  6. Restart the computer, and then reinstall the USB controllers.
  7. Plug in the removable USB storage device, and then test to make sure that the issue is resolved. OR
B. BIOS
Restart your PC and as it boots again, press either "Delete" or "F2" depending on the PC's Brand. Go to bios and under USB Configurations, Enable all the configurations in there. Then press F10 (save and exit). When the PC restarts, check the USB ports and if this doesn't solve the problem, then you have to add in a USB Card in the PCI slot.
Good Luck!
Jun 24, 2010 | Computers & Internet
I want to reset the settings on my hp mini to its factory settings.
Hello try to download the files on another computer running a Windows operating system and restore your
device, follow these steps:
1. From your computer, go to http://www.hpmini.com and download the
HP MIE Restore Image Creator utility and the HP Mini MIE recovery image.
2. Insert a USB flash drive into a USB port on the computer.
3. Launch the HP MIE Restore Image Creator utility from the Start menu.
4. Click the Browse button and select the HP Mini MIE recovery image.
– or –
Select HP Netbook Recovery Image to download the latest HP Mini MIE recovery image from
http://www.hpmini.com.
5. Click Start.
6. When the process is complete, remove the USB flash drive.
7. Insert the USB flash drive into a USB port on your HP MINI.
8. Change the boot order by turning on or restarting the device, and then pressing f9 while the “F9 =
Change Boot Device Order” message is displayed in the lower-left corner of the screen.
9. Use the arrow keys to select the USB flash drive, and then press enter.
10. Press enter again to begin restoring the device.
11. Follow the on-screen instructions to install the operating system and programs.
12. After the operating system and programs are installed, remove the USB flash drive(the device will automatically restart)
13. Restore your personal files and you are done
Good luck
Jan 20, 2010 | HP Computers & Internet
I bought a new laptop and my mp3 player is not coming being recognise on the laptop
Hi there, if the MP3 player is connected to your laptop's usb port, then the usb ports of your new laptop must have been disabled. To enable this, you need to go to your Computer Management by right clicking your My Computer and choosing Manage. On the left panel, click the Device Manager. From your right, look for the Universal Serial Bus controllers, click the (+) sign to expand the list inside it. Right click each entry and choose Properties and on the General tab of each device, make sure that the "Device usage" field is shown as "enabled".
Another way to do this is enabling USB ports thru the BIOS settings. Upon bootup, login to your bios setup by pressing the Del button on your keyboard. Depending on your laptop model, other requires F2. Once you are in, go Advanced, press down arrow key to select USB and hit enter & choose Enable . Save your setting & exit to restart computer.
Dec 04, 2009 | GPX Audio Players & Recorders
The computer recognizes the hardware, however scanner is not scanning. Have windows XP. How can I tell if the scanner is broken, there are no lights on it?
your scanner is ok.
But there is communication problem from computer to scanner .
For that
Check your usb cxable and usb port of computer working fine.
Try in another usb port.
If you have other port like parallel port then check it.
Check drivers of scanner are instaled proeprly.
Ig already installed then uninstall it and install again.
Also uninstall all usb drivers then restart the computer then it automatic install usb drivers .
you can uninstall usb drivers from computer with device manager.
Press windows key + Pause break key to see system proeprty then go to hardware then you see device manager then uninstall all usb drivers.
Jul 31, 2009 | Syscan TravelScan 662
Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop Logo
52 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
