Question about Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop
Sound card when ever i listen to music i fell my speakers sound very rough
  • alfredodidie Oct 06, 2008
    I need the Crack of Windows Vista Stater
  • JDTec
    JDTec May 11, 2010
    Are you using the internal speakers?
    Plug in an external set of speakers and see it the sound clears up or stays the same.
    If the external are clear, then your internal speakers are bad.
    If your external speakers do the same thing, you probaly need to re-install the audio drivers.
    Please remember to rate all users who assist you for free :)
  • 44 Answers
My laptop fell a couple of days ago and since then there's no sound.
If it works but you get no sound, you should thank almighty that miracle happened. Most laptops never "survive" a drop..
Normally laptops have audio integrated to motherboard, so there is nothing servicable for ordinary users.
Guess your solution might be to use an external USB audio card.
Your internal speakers won't work buy you'll be able to listen through extenal speakers or a headphone
Best Sellers in External Sound Cards
usb audio card Newegg com
Sound Card Computer Sound Cards USB External Sound Cards Best Buy
usb audio card Google Search
Aug 23, 2015 | Lenovo G580 Laptop
I use to have sound before my computer was shipped across the country. Could the sound card have gotten damaged or do I need to do a download. Want to listen to my music.
go to control panel....find system icon...click it......then find device manager, click there....see if there is a yellow exclamation mark , if so turn off pc ,open the case and make sure the sound card(where your speakers plug in is tight into the board by pressing you shouldnt be able to see any gold color connections out of the slot. afterhourspc_0.jpgshould look like this!!
If it doesnt or you dont have the card your audio may have been damaged by the transit(temperature change,static,rough treatment ) and may need to purchase a new PCI SOUND CARD. good luck
May 28, 2011 | eMachines ET1810-01 PC Desktop
The speakers wil not play on the background and the center.
If you connected to a 5.1 surround card and checked and they are connected ok you can hear all the speakers when you play music, movies that are in 5.1 format only. If you want to hear also all of them if you listen to stereo movies/music you must set the sound card to emulate multi channel. Also the player you use to listen music/wath movies must be set to 5.1 and must accept Dolby Digital/ DTS decoding if your sound card doesn't(eg. VLC media player-has integrated DD and DTS decoding and codecs for all tipes/formats).
Oct 13, 2009 | Logitech X-530 Computer Speakers
No music from speakers, can get test noise
you can disable the on board sound by going to BIOS setup
Aug 13, 2009 | Foxconn 655A01-FX-6LRS Motherboard
My speakers wont work suddenly unless I am using my headphones
Make sure in the volume mixer that it is using the right sound device. You most likely have it set to the wrong device output. When you plugged in the headphones in kinda automatically switches, but to use the speakers again you have to do it manually. Just hook up a cheap av receiver to your computer and use this headphone input instead. a 100$ 5.1 av receiver beats any pc speaker system.
Aug 01, 2009 | Toshiba (4CH-VOUT) Sound Card
I have logitech x-120 speakers and cant get any sound out fo them
I have logitech 530 speakers, can only get 2 speakers and sub to work. Just installed new sound card. When I run a test on all speakers they work, till i try to listen to music, then only 3 work
Mar 09, 2009 | Logitech X-530 Computer Speakers
Centre speaker
Your center speaker is probably busted since you say you here an odd popping noise from it. You will need to get a new center speaker. It is not your sound card unless the same happens if you buy a new center speaker.
Oct 01, 2008 | Logitech X-540 Computer Speakers
Scratchy Sound, Major Problem
Try the speakers on another PC with good working sound. This will indicate either a speaker problem or a sound card issue.
If speakers work ok on 2nd pc, then you have a sound card issue on your pc. If speakers are still scratchy on 2nd pc.. check the metal connector end, make sure it is clean and shiny. If there is any rust or other oxidation, clean it off with a very fine grade of sand paper
Apr 28, 2008 | Logitech X-530 Computer Speakers
Haveing problems
Hey, fontes,
Let's try to work on this, okay.
First, listen carefully: where does the weird sound come from exactly? The speakers or near the computer case?
Does it play music? Try some salsa and listen again for any difference.
Describe your computer the best you can: Is it new? What make is it? Did you install the sound card yourself?
Hey, Fontes, if you answer these questions, I will be notified immediately and will try to work with you. Comprende?
Adios.
Feb 02, 2008 | Sabrent 6-Channel 5.1 3D Surround Sound...
Re:ca-3000 speakers
see there is power on speaker and check the audio cabe connection is it properly connceted to audio jack in your sound card. bye
Aug 09, 2007 | Cyber Acoustics CA-3000 Computer Speakers
Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop Logo
32 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
