Question about Philips VR621CAT VHS/S-VHS playback VCR
Philips DVP 3200V/37
This unit won't play VHS tapes without a bunch of static...The tapes play perfectly on another unit in our basement. We have just cleaned the head with a tape cleaner, to no avail... Any ideas?
    Scholar:
  • 125 Answers
Hey there, Here are some ideas; I would clean it one more time to make sure that its nice and clean try playing a different tape on your VCR and check the channel on your VCR, and thats if you are using a channel 3 or 4 on your VCR, concur with each other. Meaning if you have Channel 3 on your TV you should have Channel 3 on your VCR. Thats a really old method. If you use a coxial cable unplug it and replug it in again sometimes there is no contact at one of the ends therefore disconnecting or connecting it again would help. Just see if that works and usually that was the problem when i use to have problems with my VCR. Let me know if that works out for you alright.
Posted on Oct 04, 2008
After a long period of non-use,of my VCR, I recently tried to play a new VHS tape. It loaded properly, but refused to play it.
Could be the belts have become too old for the unit to function. you could try to take the unit apart to clean them.
Mar 25, 2015 | JVC Hr-a591u 4 Head S-vhs Hi-fi Stereo Vcr...
Toshiba dvr670ku - vhs tape won't play, shuts recorder off
look to see if tape will fully load and if FF or REWIND work, if not a transport problem, drive mechanism not moving the tape, unit will sense this and shut unit off----even a problem in the loading mechanism for the VHS tape not loading the tape all the way will do the same thing.
Oct 14, 2012 | Toshiba M754 VCR
I can not seem to find out how to run my cable line through my DVD/VHS combo and into my TV. I have to use the DVD/VHS combo to run cable to my TV because the coax input on my TV broke off and I have to...
Dear hugoreyes456,
On the rear side of your DVP3345VB you should find a bunch of RCA connectors. There is a column on the right side with the title VCR - AUDIO IN - VIDEO IN.
May I ask you to try plug your cable box to this connectors and the DVP3345VB to your TV.
Before trying it, may I ask you to check that you get video directly from the DVP to your TV when playing a DVD or a VHS tape?
Regards,
Eddie Knight
Dec 28, 2010 | Philips DVP3345VB/F7 DVD Player/VCR
I have a Phillips DVD player model DVP 3962/37 password
the factory password for my dvd player is 136900 but i too have this problem. i do not know how to disable the password
Feb 27, 2010 | Philips Televison & Video
TV is on channel. VHS player has tape for playback loaded. Player is on but when PLAY is pressed 5 seconds later it turns off by itself. Model number is DVP3200V/37. Can anyone help, please.
Dirty magnetic head. Run a commercial tape head cleaner through it. You can get one at the box stores. Also, put your tape in a tape rewinder and rewind and fast forward the tape for about 30 seconds. Sometimes the tape ribbon gets wound too tight or is loose. If these fail, then you have to open the unit up and clean the magnetic head manually with some isopropyl alcohol and cotton q-tips. Also, look for capacitors on the power inboard chip that look burned and replace them.
Feb 04, 2010 | Philips VR621CAT VHS/S-VHS playback VCR
Wont burn to disc
I don't you can record because you are going from analog to digital with out a conversion proccesor. need to investigate. .type in google problem.
Mar 12, 2009 | Philips Televison & Video
EP to LP problem on VHS tape playback
The problem is dirt, dust or even mould on the VHS tape. You should look on youtube for video's about cleaning a VHS tape. However if it's really bad there is nothing you can do about it. Commercial VHS were only recorded on SP so the quality of the tape means more signal, so less of a problem keeping the video tracked, even if the tape has patches of mould, likely if kept in a basement!
Aug 09, 2017 | JVC HR-XVC33U DVD Player/VCR
PAL to NTSC conversion
This is not a converting unit, it will play the format of the tape inside. To convert the signal you need one of the following:
1) A converting VHS player; they are fairly expensive.
2) A separate video converter (hardware); they run for about $200-$500; just put this between your VCR and the TV.
3) Capture the PAL on your computer using a software like Movie Maker via a Firewire cable. Than convert it to NTSC on your machine using software like Nero... do a search on Google for converting software. Or just watch it on our computer in PAL format, most computers do that... For this step I use a separate camcoder that has a passthrough feature. The VCR connects to it and the camcorder connects to the computer via Firewire.
4) send the PAL tape to a specialized shop for conversion. They normally charge $30-$40 for a regular 2h VHS tape.
Jan 20, 2008 | Philips DVDR3435V/37 DVD Recorder/VCR
Noise while playing VHS
It sounds like the tape is cocked slightly. some VHS tapes did make noise. I'd take it to the store and show them the noise.
Nov 04, 2007 | Philips DVDR3320 DVD Recorder/VCR
Vcr not playing tapes, just ejects them
Not enough info. What is the product? Brand, model, how old?
May 13, 2007 | Philips MWD2205 DVD Player/VCR
Philips VR621CAT VHS/S-VHS playback VCR Logo
126 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
