Question about LG LHD45EL Dehumidifier
Unit getting a ice build-up in the top??
My dehumififer is collecting ice in the top of the unit what should i do to stop this. and is it safe ti keep running it?
  • Anonymous Oct 07, 2008
    I have the same unit and it is only 2 years old, it does frost up on the top and also the coils, i turn it out for 24 hours and then run in on low about 40 degress and then i have no frost on the tp but if i turn it back on high it will frost up again. whats up with that !! thanks Lois
  • 943 Answers
Hi. thanks for the question. the problem you are having is . you have a faulty compressor . not worth repairing. thanks the appliance doc
Posted on Oct 04, 2008
Humidifier gets ice on top of cabinate. It still produces water.
Most dehumidifiers have a defrost cycle that they run through, as needed. But, apparently, your is not functioning. Eventually, yours will stop collecting moisture, if this continues. In the interim, I would suggest turning the Master OnN/OFF Switch to OFF and unplug the unit until it thaws. While it's unplugged, remove and clean the air intake filter on the front of the unit. If it's clogged it causes the unit to strain and may cause it to ice up. Once the filter is clean and the unit is un-thawed. Plug the unit back in and turn the Master ON/OFF Switch to ON and set the controls as you normally do. Hopefully, that period of being unplugged will have allowed the unit to reset itself and work properly.
I have included a link to your Owners Manual that you can download and print for future reference.
aire.com/index.php?option=com_rubberdoc&view=doc&id=436&format=raw">http://www.comfort-
If the above link fails go to the following link below and click on Owner Manual, near the top of the page.
aire.com/room-air-conditioners/149-portable-dehumidifiers/122-bhd-301-g">http://www.comfort-aire.com/room-air-conditioners/149-portable-dehumidifiers/122-bhd-301-g
Hope this helps you solve the problem.
Apr 27, 2011 | Comfort-Aire BHD-301 Dehumidifier
What can I do to prevent my Dehumidifier from building up a heavy coating of frost over all the condensing tubes. The dehumidifier is currently located in the basement.
The frost is requried for the unit to do it's work. The unit should routinely turn off and the ice should melt. without this process no water would be removed from the air....
Apr 10, 2011 | Dehumidifiers
My lg dehumidifier is collecting ice on top and no water is collecting in waste. Is it dead? this is a new problem but machine is not old
Sounds as if the air filter may be clogged, which causes the coils to freeze. Unplug the unit and allow it to thaw. Once thawed, follow the Owners Manual"s instructions on accessing, removal and cleaning of the air filter. That should solve your problem.
Mar 01, 2011 | LG DH404E Dehumidifier
Unit iceing uo
Dehumidifiers freezing up can be causes by a few different problems.
Here is a tip that I wrote to help people with the freezing dehumidifier problem....
Dehumidifier is Freezing up and not working
http://www.fixya.com/support/r4662033-dehumidifier_freezing_up_not_working
heatman101
May 04, 2010 | Kenmore 54501 Dehumidifier
Ice on outside of unit
Here is a tip that I wrote that will help you with that problem...
heatman101
May 01, 2010 | Kenmore 54501 Dehumidifier
Not removing water and says tank it full
I just had one giving me the somewhat the same problem. Upon taking it apart I found that the entire inside was filthy. This thing runs in a work area in my basement and sucks up all of the dirty air. When you take the water out of the dirty air you have nothing but the dirt and the water. When you mix those together you get mud which is what clogged everything up in mine.
Dehumidifiers need to be clean on the inside to run properly especially all of the fins on the condensor. You will probably have to take it apart and clean it. Concentrate on the fins and the water collection areas. Dehumidifiers remove heat from the air which causes the humidity to collect on the condensor. As it collects it turns into water droplets. Gravity pulls the water droplets into the water collection areas and that flows to your tank. There is some sort of float in your tank that lets the dehumidifier know it is full and shuts it off with some sort of switch. It does this so it does not just keep running and eventually pour water onto your floor. It sounds like your switch and/or float is stuck. Find the float and switch and manually work them to make certain they are working freely, clean if necessary.
If the dehumidifier does not remove water like it should it is probably not getting good airflow. There are ice sensors on the evaporator that tells the compressor to stop working. However the fan will still run to pull warm air across the ice so that it melts, goes into the water collection area and into your tank. Some of these ice sensors work by measuring air flow. If there is no air flow or very limited air flow the sensor will tell the compressor not to work. The fan will run again to melt the ice so that it melts and is removed. If your condensor is dirty and does not allow the air to flow, this could cause your problem.
Mar 24, 2010 | Danby DDR6588EE Dehumidifier
How does the unit collect water?
Your fan motor is going out. You can remove the screws from the back cover and gently pry it off. After that, look into the unit and you will see the screws holding the front cover. Take the bucket out and remove the screws at the top. All the screws around the entire metal shroud need to come out. Then with the covers off you can see the fan mount screws. You have to move the evaporator very gently out of the way to get to these screws. Remove the fan motor replace it and re assemble the unit.
Oct 03, 2009 | LG LHD65EBL Dehumidifier
The dehumidifier runs until it is hot to touch on the back. But no water is collecting.
It may be building up with ice. If you turn it off does any ice melt into the bucket?
Aug 31, 2009 | Dehumidifiers
Ice build up
I would say you need a humid control on your unit.it may be running more then normal.
May 08, 2009 | Goldstar DH504EL Dehumidifier
LG LHD45EL Dehumidifier Logo
380 people viewed this question
Top LG Dehumidifiers Experts
Bill Long
Craig Butler
Craig Butler
Michael Van Der...
Michael Van Der...
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
