Question about Acer Ferrari 3200 Notebook
Acer Ferrari 3200 Internal Hard Disc Replacement
Hello
I would appreciate any advice on how to get into the Aer 3200 to replace the hard disc drive, I'm doing this due to problems being experienced with the drive presently fitted but also to up grade to a 7200 rpm drive of bigger capacity
Replies copied to my private mail would be much appreciated
sheenview@yahoo.co.uk
Thanks
Peter Mallinson
www.sheenview.com
Acer Ferrari 200 series turning ON but NO monitor/display..HDD not flashing
GO BACK AND RESET EVERYTHING,BUT BE CARE,IF YOU TOUCH THE RAM STICKS OR OTHER H-WARE WITHOUT TAKE YOUR STATIC OUT,THE HARDWARE CAN BE MALFUNCTION.
Apr 26, 2012 | Acer Ferrari 3200 Notebook
Hi, can i install a 720 GB internal hard disk for my acer veriton? my present configuration are windows 7 pro,32 bit 160 GB HDD. thanks in advance.
I found a pdf manual here and it shows that this computer does not have SATA ports, but does have 2 IDE ports, so if it's an IDE hard drive you want to install then you should be able to. However, your 2nd IDE port is likely used by a cd/dvd rom drive, so unless you are replacing the hard drive rather than adding one, you would need to remove the disc drive. There are very affordable external usb disc drives available.
Aug 23, 2011 | Acer Veriton 7200D PC Desktop
Hello, how can i get my Acer Ferrari 3200 to see the full 320 Gig Hard drive, at the moment it will only see 128 gigs.
Open your partition manager. Check if there are partitions other than the 128Gb detected. If there are others, you can create a new partition for those unpartitioned space
Apr 27, 2011 | Acer Ferrari 3200 Notebook
My acer aspire 4720Z is reporting a smart event and that the hard drive may fail. what is your advice? what should i do?
The smart software is useful in evaluating the performance of the hard drive, if you have sensitive data I recommend backing up the information on a external hard drive, or cd/dvd disc, or a memory stick, and consider replacing your hard drive in your laptop.
Jan 07, 2011 | Acer Aspire 4720 Notebook
Hard Drive media Problem :S
Presumably, you have an "internal" hard-drive that the BIOS is detecting.
If it is the _only_ disk-drive in your computer, remove it,
and temporarily connect it as a "slave" drive in some other computer.
Then:
Click: Start
Click: Control Panel
Click: Classic View
Click: Administrative Tools
Click: Computer Management
Click: Storage
Click: Disk Management (Local)
Does the drive show there? Is it listed as "Healthy" ?
Does it have a drive-letter assigned?
Sep 16, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
(ACER ferrari 3200)earphone and disc drive
The headphone jack is soldered directly to the motherboard. finding a new one and getting it soldered on is the only option. As to the dvd I would remove it (one screw holds it in either on the bottom or under the keyboard) finding the model number and ordering a new one on ebay
Jul 15, 2009 | Acer Ferrari 3200 Notebook
Hard drive
To change a drive is not hard at all,ones u can identify it then un screw the ferrari 3200 and replace the drive.Note:while replacing u must take note of how u un screw it and where u un screw it and make sure u dont lost any screw or misplace the connector when u are screwling the drive back.and before u replace any drive at all make sure the system is off and make sure to romove the battery b4 removing any drive to avoid burning of the motherboard.
May 14, 2008 | Acer Ferrari 3200 Notebook
Acer ferrari 3200 pc notebook problem
Hello. Vista needs a repair. You will want to start by putting in your own vista disc or borrowing one from someone. If your laptop isn't booting from the disc, then enter the bios (by hitting f2 or f12 usually) at bootup and select the DVD/CD rom drive to boot first. When the vista disc loads you will want to select recovery tools. Then select "startup repair". That should fix your problem.
Apr 12, 2008 | Acer Ferrari 3200 Notebook
Ferrari Acer 3200 Cd/DVD Drive Eject Problems
This is a hardware problem and you will need to replace the drive. The hinge screws need to be removed in order for the keypad to lift up. Under the keypad should have at least 2 screws holding the dvd rom. Remove them. If you turn over the laptop, check to see if there are any screws needing to be removed before taking out the drive. If the connection and physical size of the drive of the ferrari 3400 dvd drive is the same as this, it should work as a replacement. Make sure you check the port of the dvd drives that they are the same, as you don't want to force it and bend any pins.
Mar 17, 2007 | Acer Ferrari 3200 Notebook
Acer Ferrari 3200 Notebook Logo
213 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
