Question about Canon PC-920 Black and White Copier
Pages are coming out black
The light is working but the pages started coming out black. Does it need repaired or a way to fix it on my own.
  • atkholwala Oct 04, 2008
    Pages coming out black, I usually cleans up cartridge when it does this and it stops till few days and it start coming out black again...Why is this?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 191 Answers
Change your tonner catridge. thanks
Posted on Oct 05, 2008
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Oct 29, 2016 | Canon Office Equipment & Supplies
Why is my screen red when it should be black?
Search Results
    Philips Magnavox 8p6031c Crt Lens Fluid Repair Questions ...
    www.fixya.com/...philips_magnavox_8p6031c_crt_lens_fluid/page-11
    Recent Philips Magnavox 8p6031c Crt Lens Fluid Kit Dull Video Fix questions, problems & answers. Free expert ... Philips flat screen tv, Red flashing light. Light.
    Popular Philips Magnavox 8p6031c Crt Lens Fluid Repair ...
    www.fixya.com/...philips_magnavox_8p6031c_crt_lens_fluid/popular
    Popular Philips Magnavox 8p6031c Crt Lens Fluid Kit Dull Video Fix questions, problems & fixes. ... My son accidentally spilled water on our Philips tv and when i turned it on ... I need a screen replacement of philips tv 60" ... Why the tv come on but a min after the red blinking come on an it turn off by it self what the problem?
    Magnavox Projection TV problem... ' Techlore
    www.techlore.com/forum/thread/.../magnavox-projection-tv-problem
Jan 13, 2016 | Philips Magnavox 8p6031c Crt Lens Fluid...
Green light goes ON but nothing happens
I have the same problem after using it only twice...the store won't take it back as they no longer carry them, and there is no place local to repair them...and I can find nothing online to fix it. it was too expensive of a machine to have this kind of problem that is not easily repairable.
May 07, 2014 | Bodum Bistro b.over Coffee Brewer - Black
Sharp Photocopier 2114 makes all black copies
OPEN top cover make a copy see if copy exposure lamp turns on or not
May 25, 2010 | Sharp AR-5320 Black and White Copier
DELL INSPIRON 1525 NOTEBOOK : HELP !! my dell inspiron 1525 notebook will not start windows. the battery is fully charged and when i press the power button a black screen comes up and it says : "windows...
This sounds like the dreaded Windows Vista Black Screen of Death (KSOD). you might have a bad hard drive, but even more likely some software or a driver is causing a problem and caused Vista to get stuck. The repair will not work. You might be able to run a complete repair from the Windows Vista CD, if you have one. If you are not too experienced, take it to a reputable computer service center. If you are at all technical and have time, google your problem and you will see thousands of similar users with same problems.
This is one reason Microsoft released Windows 7 so soon.
Feb 16, 2010 | Dell Inspiron 1525 Notebook
MFC-490CW Won't print black
We are going to attempt to do a "power purge" to get rid of any clogged ink nozzles. Note, this will probably eat up about half of your ink, but that is the price you must pay in order to attempt to fix this bad boy.
1) Get into maintenance mode. Press these keys: Menu -> Black Start -> Scan x4 (hit it four times). A number pad should come up. If not, do it again.
2) Hit key 7, then key 6.
3) Press the right key until you get to "CLEANING BLACK."
4) Press 3.
5) Press Black Start.
After it purges and gets back to the main maintenance screen, press keys 9 and 9.
Let your printer start back up. If this does not work, try the above steps up to three times. If it does not work then, you need a new print head, which is not a user-replaceable part on this model.
Good luck.
Aug 05, 2009 | Brother MFC 490cw Color Inkjet...
HP Laserjet 1300 yellow light STILL flashing
Re-installing the print driver will not solve a flashing light. If the printer is functionally ok, it will come to ready simply by plugging into the wall. It sounds to me like a fatal error at this point.....could be a long list of things, but I would lean towards a formatter board. bottom line with this printer at this point in it's life is, if it doesn't work, it's not worth fixing. Replaceable for about $100.
Jan 29, 2009 | HP LaserJet 1300 Printer
Well my router has all the lights light up accept the wireless light how can i fix that without messing up all the other connections?
Type in 192.168.0.1 OR 192.168.1.1 OR 192.168.2.1. Whichever works.
If none of the IPs work above, go to Start > All Programs > Accessories > Command Prompt (Start > Search: cmd if Windows Vista. Make sure to right click and run as Administrator)
When the black box comes up on the screen, type in ipconfig and press enter. Type in the Default Gateway into your web browser.
You should be directed to your router configuration page. Look for any options such as Wireless, or anything similar. Make sure it is enabled, and mark down your network key.
Dec 23, 2008 | Computers & Internet
Scanner & black pages
The black printing usualy occurs when there is a faillure in the light, since your light is working fine, there may be a problem in the imaging device inside(camera) or the reflector. There is nothing wrong with the cartridge.
May 05, 2007 | HP PSC 1510 All-In-One InkJet Printer
Canon PC-920 Black and White Copier Logo
184 people viewed this question
old marine
old marine
