Question about Fahrenheat Electric Convector Baseboard Heater, 240 Volt
Thermostat when a turn thermostat only work on hi position does not work on medium or low when a turn to it i shut off thank for the help
  • bigi58 Dec 09, 2008
    The model number of my heaters are F2548NWC.These heaters only come on when I turn the thermostat to high.The thermostats have a low,comfort zone and high.Everything is new they were just installed in my home.
    Scholar:
  • 68 Answers
Thermostat for what, a furnace with blower, an induction heater, baseboard heater, describe the thermostat, what it is for, how it is wired, and we can figure something out. Write to me at wbwill@sbcglobal.net or at allexperts.com, Will is my real name and wbwill is used for both help sites, the email is my home email
Posted on Nov 15, 2008
Air conditioner frezing up.clean filter and air conditioner but still ferzing up
If its doing it over night or in several hours, you need to check the thermostat. Turn it all the way to the warmest setting and listen for the compressor to shut off. If the compressor keeps running at the warmest position your thermostat is shorted. If you do hear your compressor shut off , and the thermostat is working, you are probably low on refrigerant.
Apr 14, 2011 | Kenmore Single Room Air Conditioner
I have an Emerson CF705AW with a broken speed switch Dealer sold me a Westinghouse #77021 Now I get these speeds: High, low,low,off - No medium speed Wouls switch # 77020 be correct? I nered a...
Ah.
A simple Capacitor based speed control. How many places do you have to put wires on your switch? You may have mis-wired the switch, or you have the wrong switch.
How it all works is... When you turn the fan to High, or position 1 on the switch (there's L 1 2 and 3) the power goes from 1, to the capacitor, but does not go through the capacitor, but instead goes through the second (probably gray) wire directly to the reversing switch in the switch housing. When you switch to medium (or 2) both 2 and 3 positions on the switch are supposed to be sending power through both capacitors inside of the black box. Basically, you have two capacitors, when you go to medium, both are wired in parallel to each other, but on low, only one is in the circuit. Basically, the switch you have, or have mis-wired, is putting only one capacitor in the circuit at the time on medium and low positions.
Also, do not worry, so long as you only mess with these 4 wires, you cannot blow anything up, However! When you disconnect power from the fan, BE SURE that the fan is "On" when you turn the power off to ensure the capacitor discharges as you can get a very very nasty shock from the bare wires.
Sep 07, 2010 | Emerson Fans CF705AW 52" Northwind Ceiling
Hi, I have a Kenmore dryer (110.86873100) - the dryer has a 'fabric care knob with three settings - low, medium & high. The dryer does not heat on the 'high' setting at all, when I use the 'medium' or...
First off.. befor we talk about changing parts you need to verify that your circuit breakers are set properly. Manually push the dryer CB to the off position... and PUSH to off with conviction then turn it back on again. Test your high heat setting once again. If it works you had one of 2 CB's tripped. If it still shows the same symptoms then there are a couple of suspects.
1. The 155 deg thermostat
http://www.repairclinic.com/Appliance-Parts?s=t-L155-%3d%3d&txt=1
2. Possibly one of the two electrical legs of the heating element is open.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-110.86873100-%3d%3dc244i3367&PartID=3367
3. The timer & resistor has a problem.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-110.86873100-%3d%3dc212i2031&PartID=2031
All of the above can be isolated with a meter.
Thanks for using FixYa!
Kelly
Mar 19, 2010 | Kenmore 63942 Dryer
Low does not work, medium and high do
You probably cant fix it, this sounds like a multispeed blower with hi/medium/lo settings. You
can either replace the motor or connect one of the
working speeds to low/med or low/hi. or bump med to low and high to medium.
Jan 12, 2010 | Desa International Blower Glow Warm Wall...
The Fridge froze all inside and the generator works constantly. The settings are set to medium. Nothing changed after turning the power off and then back on after a few seconds. I'm assuming the thermostat...
Check the vent door from the freezer to the refrigerator...when you turn the refrigerator off with the knob, does the vent door close. The bottom of your refrigerator works from the freezer blowing cold air through the vent to the bottom of the refrigerator. If it is turned all the way down, that should shut off the flow to the bottom. If any thing is broke there, it will continue to let cold air come down the vent, so check it out. The vent knob itself might not be working to turn the vent door down or off. There also, is a relay on the back of the refrigerator that controls the compressor on and off...it could be stuck in on position.
Oct 28, 2009 | LG LRTP1231W Top Freezer Refrigerator
Thermostat wont shut off?
either the thermostatic spring the micro switch is mounted and is defective and is not moving to change micro switch position to cycle furnace or the contacts have welded themselves, try, with unit off tapping on thermostat and running it from low to hi a couple of times and see if this solves your porblem, you can remove outer ring and see the thermostatic coil and turn it and see if the mercury inside the micro switch makes and break the connection
Sep 30, 2009 | Honeywell Programmable Thermostat Heater
Why does blower fan speed switch lock-out off and low speed positions on 1998 chevy silverado? It stopped working altogether then I replaced a 10 amp fuse and now only medium high and high will work but,...
Sounds like you may have a bad blower motor resistor.  When they go bad, they usually wipe out all speeds except high.  But could knock out just one or two of the speeds.  It should be located near the blower motor.
Sep 10, 2009 | 1998 Chevrolet K1500
AC comes on in low to medium but shuts off on high.
It could possibly be the switch. Many automotive a/c blowers have a relay to engage the highest fan speed because the high current required will necessitate the use of heavy wiring to and from the blower motor and a heavy duty switch. Check for a high-speed relay and also there might be a circuit breaker in the blower system.
Hope this helps, rhais
Jun 28, 2009 | 2002 Dodge Durango
2005 G6
If the heater fan on your car only works on "High" the problem is more than likely the resister assembly in your blower circuit or poor connections at the resister assembly. When the switch is in the "high" position the current does not flow through the resister assembly it flows directly to the coil of the blower relay. When the switch is in "low", "medium 1", or "medium 2" position the current flows through 1, 2, or all 3 of the resistors in the resistor assembly which results in the 3 different lower speeds. Check the resister assembly and replace if needed.
Nov 25, 2008 | 2006 Pontiac G6
Fahrenheat Electric Convector Baseboard Heater, 240 Volt Logo
157 people viewed this question
Top Fahrenheat Heating & Cooling Experts
butch welch
Paul Carew
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
