Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Liftmaster garage door opener problem
My liftmaster garage door opener won't operate down with the remote nor the wall switch. i have to hold the wall switch continuously to make the garage door go down and close. if i release the wall switch the door travels in the up position and the lights flash for about five seconds. i checked the safety sensors and the lights are both on ( sending & receiving). i thought that maybe my wiring to the safety switches may have had a short so i disconnected them from the connection @ the opener hoping this would narrow my search for the problem, but this did not work. same results. my area was in hurricane Ike and i had flooding in my garage. the sensors got covered with water. do you think they are faulty even though the indicator lights are working and i should replace them? i'm clueless at this time since i have checked the up and down travel limit ajustment settings also. what do you think i should do next?
  • fees75 Oct 04, 2008
    I am having the same problem.
    Any help?
  • fmdeeply Oct 26, 2008
    I have the same issue. I have replaced the security sensors and tried all types of adjustments from the opener and nothing works other than holding the weall mounted button.
    Champion:
  • 244 Answers
Stop adjusting. you are doing right thing. unit will not run down w/o eyes so removing wiring did nothing. you gave clue when yu said they were folloded. buy new set of eyes.
Posted on Jan 15, 2009
Remote won't work but keyless entry does on garage door
If the light in the wall control is flashing press and hold the lock button for 3 seconds. Your remote should now work.
Jul 23, 2012 | Sears Craftsman LiftMaster Chamberlain...
I have the door bell style wall button-how do I unlock the unit so the remotes can be synched? I have pressed green button on back of unit with remotes but they won't operate the door.
You don't unlock anything to program the opener for the remotes. If everything is working you do this:
Press and hold the button down on the remote while you press and immediately release the smart/learn button. Do this for each remote.
Jul 11, 2012 | Sears Craftsman LiftMaster Chamberlain...
My liftmaster will open with the remote but to close the door, we have to hold down the wall unit. It starts to close, jerks to a stop, then we have to press and hole the button and it closes.
Hi, it is probably the safety photo beams out of alignment or not working, when this happens the garage opener goes into 'dead man' operating mode, ie you need to keep the button pressed for the door to operate. You can find user and installation manuals here - Liftmaster Garage Door Opener Installation Manuals
Sep 07, 2011 | Sears Craftsman LiftMaster Chamberlain...
Door operates properly with wall switch. will not respond to remote control. have replaced battery and tried to reprogram the control box with the remote as described on the unit. Lighted wall switch...
Sounds as if you have inadvertently turned on the vacation lock. If you have a lock button hold down for two seconds to turn off. Then your remote should start working again. May need re-programmed if you left the battery out for more than a minute or two.
Aug 15, 2011 | liftmaster Chamberlain Garage Door Opener...
Wall switch will operate door. Remote would operate door if held next to opener. Replaced logic board but remotes still will notwork at all. Wall button still works. Thanks Adrian
Did you program the opener after replacing the logic board? Press and hold the button on the remote while you press and immediately release the smart/learn button on the logic board.
Jul 25, 2011 | Sears Craftsman LiftMaster Chamberlain...
My garage door wont go down.I habe to hold the switch down but if i let it go the door will go up again.
I have a Liftmaster garage door that won't go down unless you press and hold the wall button. The sensor lights are both on. The green light on the unit flashes unless I press the reset button. As soon as you press the wall button it flashes again and the door won't go down unless you hold the button the whole time. The remote wont' make it go down either. It begins to sometimes and retracts, but sometimes the light bulb just flashes (like it is obstructed). I tried replacing the wall switch and that did nothing. Help!
May 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door will not close
If you hold the wall button down and the door closes the problem is photo eyes.
Dec 30, 2008 | Sears Craftsman LiftMaster Chamberlain...
REMOTE CONTROLS WILL NOT WORK-WALL BUTTON FLASHING RAPIDLY
Does your wall switch have a lock feature? By pressing the lock button, the remote control is disabled. A flashing light indicates this feature has been activated.
To deactivate, press and hold the lock button for 2 seconds. The flashing should stop and your remote should work again.
Dec 03, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
341 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
