Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Kenmore refrigerator model 106.4442*600 kenmore stainless counter depth side by side refrigerator. Water streaks on stainless that cannot be removed, I have used the cleaner that sears sells.
My refrigerator is not cooling.
Posted on Oct 04, 2008
Model pfcs1njw
Usally when the water dispenser does not work but the ice maker does the problem is caused by a defective=> WR57X10032 Water Inlet Valve There are some things to test as seen in the Refrigerator Water Inlet Valve Testing Video I will be here should you have questions, Thanks Sea Breeze
Apr 30, 2013 | GE Profile 23.3 Cu. Ft. Counter-Depth...
Kitchen aid kscs25 with a small but ongoing dripping from water dispenser
Try removing the filter and reinserting it to make sure the seal on the filter is fitting flush with the filter housing assembly.
Apr 22, 2012 | KitchenAid KSCS25FKSS Side by Side...
Water keeps dripping from dispenser
HI,CHECK THE SELENOID WATER VALVE LOCATER IN THE UNIT COMPARTMENT ,PROBABLY THE DUOL SELENOID VALVE IS BAD..
Jul 05, 2011 | GE Profile 23.3 Cu. Ft. Counter-Depth...
My GE Profile model psc23sgnabs leaks water from under the water & ice dispenser recess trim moulding. Is there any way to get the freezer door apart to replace water hose inside the door? There are...
No, the door is foamed together.
Remove small drip catch at bottom of dispenser area. Use silicone to seal recess along front edge and the two front corners. That should prevent water from getting under the door trim.
Mar 02, 2011 | GE Profile 23.3 Cu. Ft. Counter-Depth...
Leak under freezer portion
Check out these tips...they can help you figure out what is going wrong with your refrigerato
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 14, 2011 | GE Profile 23.3 Cu. Ft. Counter-Depth...
Not making a lot of ice and water not cool have change filter and filter still on
your freezer is probably too warm- you need to adjust the freezer temperature
Sep 17, 2010 | Maytag 21.6 Cu. Ft. Counter-Depth...
Water comes out very slowly
filter plugged or your line is kinked. Your water solenoid valve may be going bad but usually it just quits. good luck
Aug 17, 2010 | GE Profile 23.3 Cu. Ft. Counter-Depth...
Temperature control doesn't work - FREEZES food
Thermostate control ,I would get new 17 years old if you can sping it .
Nov 26, 2017 | KitchenAid Architect 24.5 Cu. Ft....
Frozen water tube that goes into the icemaker
Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace the water valve, the icemaker solenoid, or the whole icemaker assembly.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Nov 21, 2008 | Frigidaire SUPER SPECIAL 22.6 cu ft...
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
207 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
