Question about Mitsubishi Mr. Slim MXZ30TN Air Conditioner
Right Indicator light blinks; left is solid; nothing in manual about this pattern
I have the Mr. Slim and the right indicator light will sometimes blink every four or five seconds while the left is solid on. Nothing in the manual about this particular pattern. Help?
  • Anonymous Oct 05, 2008
    The right light will stay on for about 3 seconds, then goes off for about 3 seconds. Off and on, off and on...
  • 958 Answers
That is an error code.
count how many blinks after a pause and that would be the error code.
could be 4 , 5, 7, or 9.
you could reset it by un plugging or removing power for ten minutes and try it again.
if the problem would re-occur, then there is something wrong with the unit.
as it runs, observe everything and keep me posted. see if the fn outside is running, if the filter is clean, or if the compressor is running, etc.
tnx 4 using fixya,
Posted on Oct 04, 2008
Alpha Romeo 156 My Left hand indicator light stays on continually, does not flash. and when I turn the hazard light switch on both indicators continually glow.
Generally speaking, symptoms of a bad or failing turn signal bulb are usually the your case, either it's the front left or rear bulb. Varies for different vehicle makes...common signs include:
  1. turn signal light staying on solid
  2. or blinking very fast
  3. or either sides of the bulbs stop blinking altogether.
To test this, make sure you reconnect everything you disconnected.
Turn the left signal light on; go to the front of the vehicle, is the turn signal bulb illuminated? If it lights up, even though it is not blinking obviously the bulb is okay. If it doesn't, replace it- problem solved. You'll do the same procedure for the rear turn signal Is that lit up? If not replace the bulb and the problem is solved.
Another common failure is when the turn signal blinks really fast, same procedure as mentioned above.
If both bulbs for the left side and right side illuminate but don't blink, the problem is in the steering column turn signal switch.
If the left or right side blinkers don't work properly at all...then check the integrated hazard warning/turn signal flasher relay- that may be defective; again, that's usually the case if both sides of the signal light don't work.
If you are blowing any fuses related to the flasher system, you have an electrical overload in the turn signal circuitry.
Feb 12, 2017 | Cars & Trucks
My right turn signal isn't working correctly. When I'm driving down the road my dashboard indicator for my right turn signal will turn solid green but wont flash, But when i turn my...
I had the same problem on a 92 & 95 Dakota years ago, replaced the turn signal switch in the column & found a loose ground wire in the harness back by the tail lights. Never had a problem again. If you're gonna try to replace the switch you will need tamper proof torques bits just FYI. Good luck. Let us know how it turns out.
Nov 07, 2012 | 1995 Dodge Dakota
Operating indicator light is flashing on Mr.Slim A/C
I had the same problem and I found it was that another unit had the heat running while I was trying to run AC on another (they're both attached to the same condenser) so it could only run heat or AC not both. Turn off the heat!
Mar 25, 2012 | Mitsubishi Mr. Slim MXZ30TN Air...
When I turn on my HL-T5687S, the screen remains black and there are 3 dots on the lower right hand side of the panel?
My TV is (same model is doing the same thing). The manual shows that the 3 blinking lights indicate "LED may be defective. Please contact a certified technician."
Note: When I power my TV off (unplug) and back on, the TV's left indicator light is solid for less than a second ("Stadby state") then the right light blinks ("The picture will automatically appear in about 15 seconds") for about 15 seconds. This pattern is repeated numerous times (I think it was 5 times). I believe the TV must be failing some power-on test. Aftere failing 5 times it gives LED may be defective indication.
Nov 09, 2010 | Samsung HL-T5687S Television
The last led light blinks green and sometimes it turns solid red
red light is stands for hardware boot and the green one is stands for system boot and disc boot. when red light remains solid it means your system is in 0% cpu usage and nothing doing, stop working
May 09, 2010 | Intel SC5299BRP
The left indicator light is blinking and I have no heat. I have tried turning the breaker off and on and I have tried emergency heat setup and I still end up with the same problem
Turn the whole unit off at the circuit breakers. Let it completely defrost. I left mine off for two days until the outside weather improved. When I turned the circuit back on, it was fine.
Feb 07, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Garage door indicator light blinks 5 times
this probably means you have a bad photo eye if you happen to have to doors side by side may be picking up on other sides photo eye just switch sides from left to right, however if the lights are coming on but does not mean that photo eye is not bad it has a small circuit board inside of it...
Apr 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
Indicator lights no longer blink its one solid light
Im Not Totaly Sure But Most other Makes & Modles Ues 2 Seperate Signal FLASHER Units
Your Owners Manual Should Show this As Turn Signal "FLASHER" Located At or Near Fuse / Relay Box This is ASUMING you have Checked The Fuses and Relays
Feb 09, 2009 | 2000 Mazda Protege
Mitsubishi Mr. Slim MXZ30TN Air Conditioner Logo
786 people viewed this question
Top Mitsubishi Heating & Cooling Experts
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
