Question about Arris DCT6200 DTV Receiver
DCT6412 DVR Box
Today when I turned on my DVR it showed channel 0 and we cannot change the channel or get a pic on the TV. I am afraid I am going to lose my recordings! (AGAIN!!!) Any ideas?
  • 1 more comment
  • chelz29 Oct 12, 2008
    Mine did the same thing last night. I can put in a channel but I get the message that the channel will be available shortly. After 12 hours, no channels.
  • Anonymous Oct 15, 2008
    Mine shows the guide for a few seconds but no program ever appears
  • Anonymous Apr 30, 2009
    At first just the PVR function stopped working after a few hours a 0 was in the dispay and the box would not dispaly any picture on the TV. Tried unplugging and restting to no avail. I have contacted Motorola and they have no authorized repair centers (?) I guess you throw away your $650 box and buy a new one. Any help on locating a repair shop in Alberta Canada would be appreciated.
  • 15 Answers
When that happens its most likley you had a power outage and the box reset.  Well kinda reset but not all the way.  You can unplug the power and wait about 10sec and plug it back in and wait a few min to a few hours, and If that doesn't work get a new box.
Posted on Oct 18, 2008
  • harvey607 Oct 18, 2008
    Front Panel Reset from AV Forum Per Member-ScanPa
    Reset procedure
    Step 1
    Unplug Power Cord from STB.
    Step 2
    on the STB, Press & Hold {Power & Menu} Keys while plugging the Power Cord back into the STB.
    The Display should now say (BOOT)
    Step 3
    Let Go of the {Power & Menu} Keys and press the up or down arrow keys till you see (n DL) on the Display.
    Step 4
    Push the {Select} Key To begin Downloading STB Firmware & Account Settings from your Cable Head End. Could take up to 20 min to download.
    After it completes this Download the STB will Reset and then begin to download the Time setting info for the STB Clock & begin to populate the IGuide info. Keep your STB on Standby/Off to speed up the IGuide info download.
    Could take up to 24 Hours to fill in all 2 weeks of IGuide info.
Very good! My dct6412 is going through the process right now. It may take a while to complete.
Thanks!
Posted on Apr 03, 2009
I have the same problem with DCT 3412 box
Posted on Oct 04, 2008
RCV HDTV model HD52W66 having issue where 3 images (like the Direct tv guide or a channel) show up at once.
DVI does not carry sound
that is an out of sync pic like your running a 1080p to a 720p
Some direct TV guy needs to answer this likely
or you have a 18pin instead of 21 pin hdmi side connector that too is an issue for some.
Jan 04, 2015 | RCA Televison & Video
DCT6412 III DVR Box has inputs but how do I switch to them?
Who is your cable provider? Several providers indicate that the inputs (USB, ethernet and composite video in) are not currently enabled on all DCT6412 set-top boxes.
I wish that I had better news for you.
(note: the component video is only video out to TV or other component.)
Jan 22, 2018 | Motorola Televison & Video
The TV model is Sanyo DP32648. DVR Cable Box - Motorola DCT6412 III I have a DVR cable box connected via an HDMI cable to the TV's HDMI 1 slot. I have had the TV for around a year now and haven't had...
If you have the DVR connected to the TV with the Coaxial and the HDMI that is probably causing the problem I work for a Cable company and have dealt with this problem on numerous occasions. Try just disconnecting the Coaxial cable from the cable box that should fix this issue.
Dec 02, 2010 | Televison & Video
Motorola dvr dct6412 locked channels
Check with your provider to ensure that you are in expanded services, or limited. Because being on limited services the box will lock you out of those channels. If you are in billing for those services and you checked the batteries on your remote and they are good and you get a solid red blink when you change channels not a double blink (indicating that your batteries are dying), Then try power cycling your DVR by, removing the power supply and waiting 3sec then plug it back in. Your box should shut off, turn itself back on, then go into the load screen, then, once the load screen display shows on your tv and on box display, wait for your box to completely load (don't touch nothing until the correct time shows up, meaning that it has completed the load process) Once the process is complete turn box back on and you should have you guide back up and (No Data) on your program schedule(Don't Worry!!) it will populate, with 15-20 mins.
Now try to ch. up and down and see if that fixed the problem. also make sure nothing is blocking the sensor. If all else fails and you changed the battery, called your cable provider and request a box swap, (be sure to watch all your recorded shows because they go bye, bye with the cable guy!)
Sep 22, 2009 | Arris DCT6200 DTV Receiver
How use Tivo on Motorola DCT6412 III?
this works to record progam you watching
1. press menu key
2. highlight DVR button by using either < or > key then press OK button
3. answer prompts
Do this to set up a recording in advance or a series recording
1. Hit the guide button
2. scroll thru channels until you find program you want to record
3. scrool over to red dot press OK button
4.you can the highlight red dot for one time recording or go down one to record every episode. make sure you check the settings for this program.
Hope this Helps.
Mar 19, 2009 | Motorola Televison & Video
Motorola DCT6412 Cable box
Ive seen this before...that may be indicative of an upgrade of the software in the cable box that comes from your cable provider. The best thing to do is plug it back in, let it get the "yellow ring" for a bit, and wait for the upgrade (it make take 10 - 15 minutes). Then things should return to normal... If the condition persists, try to call the cable company.
Feb 03, 2009 | Arris DCT6200 DTV Receiver
Archos DVR Station & 605 wifi PMP
Not sure if this will help you or not, but I have a 404 and was having issues with the scheduler changing the channels for me also. Then I realized that it is a infrared transmitter - the same frequency as a remote I realized what I was doing wrong - Your archos station must be facing the cable box that it is turning on. I had my archos on top of the cable box and it was not working - but when I turned the cable box and the archos station to face each other - so the signal can transfer - it worked just fine. Hope that helps!
Oct 22, 2008 | Archos 605 WiFi Digital Media Player
Shows canceled?
Make sure u have signal on both tuners on the DVR ( check it in your set-up screen). both tuners should have the same siganl strength. Directv's DVRs, if installed correctly, give u the option of recording one channel and watch another, or recording 2 seperate channels( 2 tuners). If you are recording 2 seperate shows and u change the channel one of your recordings will cancel .
Sep 13, 2008 | Directv Plus DVR DTV Receiver / 100-Hours...
Codes to operate a cable box with TV remote
Try code 038. If that doesn't work try 039.
Aug 05, 2008 | Televison & Video
Arris DCT6200 DTV Receiver Logo
4,073 people viewed this question
Top Arris Televison & Video Experts
Are you an Arris Televison and Video Expert? Answer questions, earn points and help others
