Question about LG LHD45EL Dehumidifier
Cannot empty bucket
No matter what we do, we cannot pull out the full bucket of water. whats the trick
  • 104 Answers
I require a Dehum 3 manual for my T2 Direct Ltd technology dehumidifier. It turns it's self off stating it's full of water but the container is empty.
It thinks bucket is full because switch is tripped or stuck in tripped position.
Take out bucket and inspect plate it sits on. May be stuck or spring not providing enough tension. Increase tension on spring so empty bucket doesn't trip switch.,
Sep 17, 2017 | Dehumidifiers
When full bucket light comes on water is emptied and bucket put back in position. Fan will start and then the full bucket light comes back on beeps and shuts off.
You have to be sure bucket is replaced exactly where it should go or the bucket will hold the switch in, thinking it is full. If you have a floor drain close by,remove the bucket and set the dehumidifier over or next to drain so water will go down it,then you don't worry about bucket getting full.If it doesn't run with bucket off, maybe defective switch. unhook wires to the bucket switch and hook or tape together,if dehumidifier runs then switch is bad. UNPLUG FROM OUTLET BEFORE DOING THIS. IF YOU DON'T UNDERSTAND ELECTRICITY GET QUALIFIED HELP!!
Sep 17, 2014 | Dehumidifiers
Bucket full showing
Hello Friend, thank you for allowing me to assist you!
Once the "BUCKET FULL" illuminate on your Frigidaire dehumidifier, soon after your appliance will shut down. Then you may remove the bucket by pressing the sides gently to unclip it and empty the collected water. After you reinstall the bucket, the float switch will reset. Hope this helps! - Z
Jul 17, 2014 | Frigidaire 50 Pint Capacity Dehumidifier
Says bucket full and it is empty
There is a float switch somewhere to measure the level of water in the bucket. That switch is out of position or broken. This can happen if you are not careful removing and re-installing the bucket. Look at the area around the bucket and you should be able to find and fix the switch. Make sure the power is off when you are doing this.
Nov 13, 2013 | LG LD450EAL 45 Pint Dehumidifier
The message reads CH-01. The water collection full light is flashing, but the bin is empty. Can you advise
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
Sep 06, 2011 | LG LHD45EL Dehumidifier
My dehumidifier wont turn back on. I emptied the water and it says CH 01. What does this mean?
heatman101
Aug 05, 2011 | LG Dehumidifiers
My Kenmore 580.54501 dehumidifier "Water Bucket
heatman101
May 27, 2011 | Kenmore 54501 Dehumidifier
I noticed that the "bucket full" light is on and
heatman101
Mar 31, 2011 | Comfort-Aire BHD-651 Dehumidifier
New Delonghi Dehumidifier,5 gal:When units beeps that bucket is full,what are exact steps to do 1st:empty bucket, then press what button to restart?or does it restart on its own?
It should resart on its own after putting the empty bucket back in. The beep is to let you know that the bucket full and it shuts off the humidifier until the bucket is emptied and put back into the proper position.
Jun 07, 2010 | DeLonghi Dehumidifiers
Stopped running
water level sensor,problem by pass and test run unit if ok replace switch.
Apr 20, 2010 | LG LHD45EL Dehumidifier
LG LHD45EL Dehumidifier Logo
Top LG Dehumidifiers Experts
Bill Long
Craig Butler
Craig Butler
Michael Van Der...
Michael Van Der...
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
