Question about Panasonic NN-T990SA Microwave Oven
Panasonic Model No. NN-S933BF Microwave Oven
The microwave oven shuts off after running 4-5 sceonds. Initially the light comes on and microwave starts, but then after 4-5 seconds microwave shuts off and goes back to the clock time.
  • 5 more comments
  • raysfan Oct 07, 2008
    I have the exact same problem, just happened today... runs 3 sec's, then turns off, as if time's up. Must be something about October.
  • sunset_rose1 Oct 21, 2008
    i have a panasonic inverter microwave ,but when i want to cook something,after 5 seconds it shuts off.what is wrong with it.
  • dendude Mar 12, 2009
    microwave runs for 5 seconds and shuts off
  • Anonymous Apr 20, 2009
    Runs for approx. 5 seconds, then shuts down, clock resets to zero.
  • Anonymous Mar 13, 2014
    microwave will run for 4 seconds then shut off. display shows code h97
  • Anonymous Mar 14, 2014
    THE TIMING CLOOCK ON MICROWAVE OVEN HAS SUDDENLY STARTED RUNNING IN THE WRONG DIRECTION E.G.ADDING COOKING TIME ON & NOT RUNNING THE TIME DOWN
  • Anonymous Mar 19, 2014
    no power or lights
Could it be that i didn't follow the manuel because i got it second hand or is it because something is wrong with it,and i have to get it fixed.
Posted on Oct 21, 2008
  • 3 Answers
SAME PROBLEM HERE, , TOOK COVER OFF, UNPLUGED AND PLUGED CONNECTIONS BACK ON CONTROL BOARD, WORKED ONE TIME OK, UNPLUGED POWER CORD OVERNITE, TRIED NEXT MORNING AND SEEMS NORMAL NOW.
Posted on Mar 20, 2013
Microwave will not shut off when the door is opened. Keeps operating
The door switch has gone bad...
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Feb 11, 2011 | Panasonic NN-S933BF Microwave Oven
Panasonic NN-T994SF Microwave Oven quits after 15 seconds
my microwave shuts off after a few seconds. is there a fuse that needs replacing?
Feb 01, 2010 | Panasonic NN-T994SF Microwave Oven
Replacement light bulb for Panasonic NN-9853 Microwave
Hello, I also have a Panasonic Microwave ( model NN-S 564 or 574 ?) They are very similar.
I have just removed the outer cover 5 screws ( unplug of course ) and have located the bulb holder which is a white plastic component with two clips holding the globe, pull it out and remove the two spade clips connected to the globe. The globe will come away attached to a black plastic mount. Next........do the run around to find someone who sells it.
Perth has an authorized distributer/repairer in Myaree whose details I got from Panasonic. He may sell them. otherwise I will try a couple of specialist light globe suppliers I know....PROLAMPS in Belmont and one in BALCATTA whose name escapes me but I have been there before...Hope this helps others.
Martin
May 10, 2009 | Panasonic NN-S540 Microwave Oven
No sorry the issue will be with eiher the inverter, the magnetron or the main timer board. There is a tracer signal that comunicates through these components and if it doesnt get to where it is supposed to go it wil just shut off, the big hint at that is the time interval. It is not something like a sensor heating up and causing a fault. it is not running long enough to get any thing hot it is in the electroincs. Too expoensive to repair, im sorry better to get a new one. Good Luck
Jun 17, 2017 | Panasonic NN-S950BA Microwave Oven
Stopped heating, shuts off before time expires
My panasonic microwave model # NN-S540BFW stops after 4 seconds after you hit the start button and cuts off on its own. What is wrong with my microwave?
Jan 12, 2009 | Panasonic NN-S763BF Microwave Oven
Turning off before finishing time time cycle
I have just had this problem where the oven will only run for 5 seconds and then turns off model #NNS561. Cant find any solution.
Jan 19, 2008 | Panasonic NN-S950BA Microwave Oven
Turns on with door open
It's likely that it's only the fan and light coming on when the door is open. But even so, it's not normal, and it should be fixed. It's not a reset issue. It's likely a broken door switch mount caused by a door slam or by inferior material, or a defective door switch caused by opening the door while the oven is cooking instead of hitting the "STOP" key first. You can do a Google search for my text file "doorsw.txt" which will give safety info and help in checking the door switches. Also, the plastic pieces on which the door switches are mounted should be checked, as well as the door alignment. It's usually the upper door switch or mount that causes this, but occasioanlly it's a problem on the control circuit board. Post again if more help is needed.
Oct 25, 2006 | Panasonic NN-S933BF Microwave Oven
Shuts Off after 22 seconds
Time to buy a new microwave as it sounds as if the control panel is defective. A new control panel for this micro will run about 95 to 120 bucks + labor depending on where you buy it. I happen to like slightly burnt popcorn as well!! Nothing wrong with thats, as they say great minds think alike.
Aug 25, 2006 | Panasonic NN-S933BF Microwave Oven
Panasonic NN-T990SA Microwave Oven Logo
1,663 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
