Dryer works fine, washer fills up, then does nothing more
The washer just fill up, then the water just sits there. It won't drain, it won't spin...just sits there. I've tried every setting. What could possibly be wrong with it? And what caused it not to work?
-Thank you for your solutions
  • Smashleigh Oct 04, 2008
    LTE5243DQ3 by Whirl Pool "Twin Twin"
  • Anonymous Mar 02, 2009
    i have two kenmore washer that did this exact same thing. one i wish to fix tonight, now that i"vwe seen this website, the other i didnt know what it was and assumed it was the pump and destroyed the washer. dont be an idiot like me. research a problem before u scrap the unit.
  • 5,911 Answers
The symptoms you describe are typical of a lid switch malfunction. The lid switch is usually located on the right hand side under the top cabinet. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the right side of the wash tub opening. Make sure the lid strike is still on the lid and intact, first. Then, check the mounting screws that hold the lid switch in place (along the right hand side tub rim). Often all that is required is to tighten up the mounting screws and this will realign the lid switch where it can be properly activated by the lid strike. If the lid switch is broken, you can find a replacement at searspartsdirect.com. Just type in your COMPLETE model number and look under the "Washer Top and Lid" heading. The lid switch is listed as item number 22 (part #3355806) and the lid strike will be listed as item number 16 (part #358684). If you do not wish to order online, take the part numbers provided by Sears and go to your nearest appliance parts retailer. These are common parts that most will carry in their store inventory.
This is a very inexpensive repair that you can easily accomplish on your own. I hope you find this information helpful. If you require additional assistance, please let me know. You should be able to access the lid switch on your model washer by the following steps:
1. Unplug the appliance.
2. Insert a putty knife into the seam where the top of the washer meets the front panel, about 2 inches in from each side.
3. Push in on the release tabs while lifting on the washer top. The top panel and lid should lift up. The lid switch should be mounted under the top panel on the right hand side.
4. Locate the lid switch connector and unplug it.
5. Remove the the mounting screws that hold the switch in place, and remove the wiring harness from the mounting clips.
6. Reinstall new switch using the above steps in reverse order.
I hope you find this information helpful. Let me know if you require additional assistance.
PS This is a common problem experienced by this line of washing machines. To prevent future failures, do not slam the washer lid or place anything heavy on the lid. Repeatedly slamming the lid to get it to work, or manipulating the timer can also cause more potential problems.
Posted on Oct 04, 2008
My kenmore 29822800 won't fill with water, it works on spin and drain
The last time I moved, my washer/dryer combo (Frigidaire) had the same issue for approximately 7 months before finding out all I needed to do was level the washer, and of course, make sure the faucet connected to the washer is turned to on position. Hope this is helpful.
Praysemema.
Mar 13, 2013 | Kenmore Washing Machines
Washer won"t fill with water
check your lid switch if its a top load
May 18, 2009 | Maytag LSE7806A Top Load Stacked...
Won't fill
check to see if the water is turned on? do you hear a light buzzing or humm noise?
Jul 26, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 4314220
It sounds like you could have a couple of issues going on here. First of all, to answer the question about stacking the units; there is a mounting kit that you are supposed to use to place the dryer on top of the washer. The top is supposed to come off the washer to accomplish this. There are a couple of brackets to install and the dryer is supposed to mount to the washer with a couple of screws. Your local appliance store should be able to provide this for you. All you need is the model number of the washer and dryer. If the timer is only working on one cycle then you may have a bad timer. But...before we go jumping on that bandwagon...you mentioned that the washer is not filling and the water just keeps running out. This sounds like a problem known as "siphoning". If you have placed your drain hose in the standpipe in a manner that does not provide an air gap for drainage, the washer will not fill and will continue to "siphon" water from the machine as it tries to fill. If the washer cannot fill, the pressure switch will not shut off, and the timer will not advance any further. Double check your drain line to make sure you do not have it shoved too far down in the standpipe (3" to 4" should be sufficient). If the drain hose is sitting in the drain trap where the water sits, there's no air gap. Also, make sure you do not have the top of the standpipe sealed for any reason. Once again, you need an air gap in order for the water to drain properly. Let me know if this helps you.
Sep 08, 2007 | Kenmore 43142 Front Load Washer
Washer fills up but won't agitate
get your screw driver and lets start.. first unplug the machine from the outlet, you have to access the water level sitch so remove the tab and there is the bandidt, knock him with the screw driver and if this not funcion replace it..good luck I dont tell you to check the thin hose in the water level sitch becouse you said its fill all right.
Aug 06, 2006 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
118 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
