Question about Kensington (K33348) Bluetooth Wireless Adapter
Can i connect my blackberry and jawbone to pc with kensington 33348
I dont remember the key to the kensington 33348 and it will not even see my jawbone. i want to connect both to my computer at same time. i played with the comm stuff a while back (1yr or so) and dont know if that is part of the problem.
  • tush81 Dec 19, 2008
    driver vista please
Oooo is the code
Posted on Feb 20, 2009
Jawbone won't pair with iphone
Hi, you need to plug the jawbone to a computer in order to connect it for the first time to your phone, it can also be an issue with your phone bluetooth, restart might solve it.
Feb 17, 2014 | Apple iPhone Cell Phones
I can't get my jawbone to pair with my palm centro any idea's
With the jawbone turned off, press at the same time the turn on button and the noise reduction button. The jawbone should blink white and red for three minutes, in that time you shoul be able to find it as a bluetooth device in the free hnd configuration of the palm centro. than yu complete the conection by inserting the code. The next time you turn on the jawbone it will connect with te palm.
Aug 09, 2009 | Palm Treo 500 Centro
Cannot pair lg voyager with jawbone bluetooth.
Mine wouldn't pair either so I went to the jawbone site and I did this and it worked the first time.
For Jawbone ICON, while the power is off, press and hold down the Talk button and slide the power switch on. When the LED starts to flash red and white alternately, release the Talk button.
1. Press the OK Key.
2. Highlight SETTINGS & TOOLS and press the OK Key.
3. Select Bluetooth Menu.
4. Select Add New Device. (If Bluetooth power is set to off, you will be prompted to turn power on. Select Yes and press the OK key.)
5. Highlight Jawbone and press the OK Key.
Enter the PIN "0000" (be sure to enter four zeroes and not the letter "O") and press the OK Key.
Mar 22, 2009 | LG VOYAGER VX10000 Cellular Phone
Nokia Supernova 7610
are you connected to to the computer by pc suite. If so try deleting the tunes via nokia phone browser in my computer. if you once played the tunes and closed them in between the music player remembers that and every time you touch the music player key on the right side the tunes may start even in silent mode.Check the music player if one of the tunes is still in the playing menu. Once listen to the tunes completely and then close the music player. Removing them from the playlist may also help.
Jan 12, 2009 | Nokia 7610
How to get a Canon MX310 series Printer working with bluetooth connection
u need a bluteooth adapter dongle, but pick the right one because some dont work.. I have the half moon shaped mini usb dongle, it practically got stuck in the front USB port, but i wiggled it out. It didnt work!! The screen showed 'incompatible camera'.. Im trying some other dongles soon, starting with the kensington 33348 bluetooth adpater. Ill post back with some news soon..
If anyone has any input on this particular device, and which bluetooth dongle is working, please put the info into the Solve this problem box!! Lets go experts!!
Apr 15, 2008 | Office Equipment & Supplies
Uninstall Mouseworks
check the net to see if there is a removal tool for Kensington Mouseworks ,or try going into safe mode then un install it.
if not ,it can be done in the registry but you need to be very careful, it is not for the faint hearted.
do not use the quotation marks " " shown ,when typing.
  • go to start button select "run",
  • type "regedit" in box
  • click on "edit"
  • then "find"
  • type in "Kensington Mouseworks "
  • any line with Kensington Mouseworks in it will be highlighted
  • check the line before hitting delete key
  • then hit enter(ok) to confirm delete
  • hit F3 to continue search
  • then follow the same procedure to the end
continue this till you get to the end of the registry it may take a long time.
again i stress you have to be very careful when playing around in the registry as it can give you a real headache if you delete something you should not have,even requiring you to re install windows
good luck
Mar 18, 2008 | Computers & Internet
Iphone and headset
Is this the first time you're pairing iPhone and jawbone or it's been working before?
If this is the first time,
1. Go to settings-general-bluetooth and turn on the bluetooth on your iPhone 2. Press and hold the button above the LED light until the LED light flashes Red and White 3. Go to your iPhone and click on Jawbone and it should connect.
If it's been working before:
1. Make sure Jawbone is fully charged. 2. Press and hold the button below the LED until white light blinks 3. Go to iPhone make sure bluetooth is on press Jawbone to connect
If this procedure fails try the to follow the First Time Pairing Instruction
Hope this works for you.
Nov 21, 2007 | Apple iPhone Smartphone
Link devices
i have a blackberry 8310 curve and a jawbone II (the newest jawbone headset) and really have a two part question. 1st is that i have had the kensington 33348 usb bluetooth adapter for a couple of years and don't remember the key (password, etc.). 2nd it will not see my jawbone headset even in pairing mode. i have played around with these comm ports and may have messed them up. i also tried to update my driver for the kensington and it said no updates needed at this time. please help.
Nov 13, 2007 | Kensington (K33348) Bluetooth Wireless...
Kensington (K33348) Bluetooth Wireless Adapter Logo
230 people viewed this question
Top Kensington Computers & Internet Experts
Level 1 Expert
Alun Cox
Are you a Kensington Computer and Internet Expert? Answer questions, earn points and help others
