Question about Motorola Mobility RAZR V3
Buttons don't light up when phone is on
When the phone is first turned on, the numbered buttons light up; however, just a short time later they are not lit. It makes it hard to see in the dark! usually the keypad lights up at least once you hit a number but it doesn't. Any suggestions?
    Brigadier General:
  • 7,752 Answers
The flexcable on the phone need to be replaced
Posted on Oct 05, 2008
How do i turn off the brake warning light on range rover 2004
You can reset this fault code using the buttons on your dash - you don't need a dealer to do this. As you already know, you need to replace your pads and the brake wear sensor - this is a sacrifical item. Once this is done, do the following:-
Using the buttons on your dash - there are 2 - one on the LHS (Trip reset) and one on the RHS (In between Tacho and temp gauge)
*Press and hold Right button and turn ignition to first position (I or Accessory)Display should show "Check Control OK" then a short time later "Test Nr.01"*Press the Left button and you should see the car info in the display. Add the last FIVE digits of the car identity number together (NOT all 6!) to get a unique ID for your car.*Press the Right button repeatedly until you see "Test Nr.19"*Press and hold the Left button until you see the number matching the unique ID you calculated, then release.*Press the Right button to select this.*Press the Left button repeatedly until you see "Test Nr.21" - Reset All Defect Codes*Press Right button to reset the codes.Done!
Mar 26, 2012 | 2004 Land Rover Range Rover
I need red light phone number of dussledorf
Hello, First, don't turn on this Night Owl NODS3 during the day...Bright lights will destroy the image intensifier tube in mill-seconds. It used on during the dark hours of the night and look at bright city lights on the poles on homes.
You have two button; one with have o/1 (on/off) then the second but would be the IR light and it will have the IR on and some time there will be another button mark A and this button is used to enhance the image.
To turn on the button--all you have to do is to push it. Only in a dark room with IR button on. and only in the dark of the night. If it doesn't work then let me know send me a message. GB...stewbison
Sep 14, 2011 | Night Owl Optics Optics
Hi I would like to change the Flexible Buttons on our Panosonic KX-DT333 can you please help? Thanks
To what? There's a complete table in the Operations Manual (OM) or can you remember 0, 1 and 2? 0 assigns single lines....don't touch them. 1 plus ext assigns intercom numbers, and 2+access code and number is used to set personal speed dials (you also have 30 under the touch pad). Other commands set up Transfer to VM, VM record, CID display, Headset mode, etc. etc.
If you don't have a copy of the OM, here's one. Please rate this solution because as soon as you do, or after a short time, this manual will be gone.
Jun 16, 2011 | Panasonic KXDT333 Phone
My 88 Tracer started having problems with all dash lights being on. Then a day or two later over heated lost all antifreeze except small amt in overflow. Let it cool added some to radiator and overflow....
OK, first, I think it may be the alternator. If you charge the battery overnight, the engine should run for about an hour before it discharges again.
I don't think the coolant should affect the wiring.
There may be a fuse panel for the high current fuses in the engine compartment. It should be 30 amp or higher.
Does the generator/alternator/battery light come on when the key is in ON position?
What engine? 1.9L or 1.8L?
VIN Number?
May 17, 2011 | 1988 Mercury Tracer
I have a mitsubishi model #ws-a65 when you turn it on it turns off after 20 seconds and then later it turns on but no picture ever comes up
This model should have the self-check feature.
when it shuts off and the green light on the front goes out:
Press and hold both the menu and input (device)buttons at the same time and hold them for at least five seconds and release both buttons.
The power light should blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat several times.
The error code will point to what the problem may be; 1,2 is no error found, 2,2 is short protection etc.
May 05, 2011 | Mitsubishi Televison & Video
HI I hope I have reached Sea Breeze because I see someone had the same or similar problem as we are having from our GE GSS25... side by side refrigerator. this person wrote: "Water now comes out but only...
You have a bad main control board . Located behind the refrig , behind an 8 X 10 " panel . Easily replaceable . Sorry , not Seabreeze . You can reach him at seabreeze appliance parts . com , I think .
Sep 08, 2010 | Refrigerators
Water was splashed on cell phone, didn't notice for 15 mins. dried off phone and later that day phone kept turning off and on. took battery out and let dry for 2 weeks. it turns on but the lower two...
no sorry- it is replacement time.but itis covered under the insurance if you have it under water damage as long as it stopped working in the last month.
Aug 18, 2009 | Motorola Mobility RAZR V3
Motorola H500 bluetooth won't turn on!
Hold the phone button down for about 4 seconds.. The light should blink 2 times and then stay on to add device to your phone once connected light will go out...Hold button down again light will blink 3 times and go off...........
Aug 07, 2009 | Motorola Mobility H500 Wireless Headset
Whirlpool DWF B00 W
Hunca, We would like to inquire further about your post with you. Please respond back to this email address with your name, user id (Hunca), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 24, 2017 | Whirlpool Duet GHW9150P Front Load Washer
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
