On flat screan hp vs17x, when it go in sleep mode, it not return, i ear a little sound in speakers and the screan remain blank, after a time it's ok , i speak french but i try to speak english, thank you for a response :-)
  • djgrimey Nov 21, 2008
    Same issue here, a poping sound and the screen remains blank.
No sound im computer
Posted on Oct 13, 2008
How can i set up the sleep mode pls?
A little more info would be helpful. Does your TV even have a sleep mode. I assume you are looking for the off timer? It will allow the TV to remain on for a set time?
Aug 26, 2014 | Televison & Video
How do i change sleep mode
Sleep Timer Mode
The Sleep Timer mode is an energy-saving feature that enables you to set a time for the monitor to
power on and off at the same time every day. This also extends the life of the backlight bulbs in the
monitor. The Sleep Timer has five settings:
? Set Current Time
? Set Sleep Time
? Set On Time
? Timer: On/Off
? Sleep Now
To set the timer:
1. Press the Menu button on the monitor front panel to display the OSD Menu.
2. Scroll down and highlight Management.
3. Press the OK button to select Management.
4. Scroll down and highlight and select Sleep Timer > Set Current Time.
NOTE: You must set the current local time before you reset the time for Sleep Time or On Time. Note that the time is displayed in a 24-hour clock format. For example, 1:15 p.m. is displayed as 13 hours 15 minutes. A power failure or loss of power to the monitor will cause the timer to reset to 00:00. If this occurs, you will need to reset the sleep timer mode.
5. Press the OK button once to enter the adjustment mode for hours.
6. Press the - (Minus) or + (Plus) button to adjust the hour.
7. Press the OK button again to enter the time for minutes.
8. Press the - (Minus) or + (Plus) button to adjust the minutes.
9. Press the OK button to lock in the time chosen.
10. After setting the current time, the highlight automatically skips to Set Sleep Time. Repeat steps 6 through 9 to set Sleep Time.
11. If you do not want to set Sleep Time, press the OK button twice, then select Save and Return to exit the menu.
12. After setting Sleep Time, the highlight automatically skips to Set On Time. Repeat steps 6 through 9 to set On Time.
13. Set the Timer mode to On to activate the Sleep Timer settings.
14. When you are finished, select Save and Return to exit the menu.
The fifth selection, Sleep Now, turns the monitor backlights off immediately and stays in sleep mode
until the next On Time activates or a monitor button is pressed.
May 27, 2014 | HP Pavilion 22bw Black 21.5" LED Monitor...
Loss treble using THX mode with BOSE acoustic mass speaker
What you are hearing is a combination of the programmed signal processing and equalization of THX mode plus performance limitations of the speakers.
Your only options would be to be either change your listening positions or the positions of the speakers, so that there is a direct and unobstructed line that is on axis from your ears to the speaker drivers. Or, you can disable THX mode.
Jan 03, 2012 | Onkyo TX-SR703 Receiver
TV powers on screan comes and then powers off after a few seconds
Pls look on your remote control, select the "sleep mode" to off. Sleep mode might be on. Or adjust the time whrere what time you want it off automatically. Just simplt turn ot off the Sleep mode. Check timer of your Tv.
Jan 18, 2011 | RCA HD61W66 61" Projection HDTV
Windows update disconnected my Altec Lansing BX2 speakers sound.What should I do?
I had a similar problem with my Altec Lansing BX2 speakers. When bringing my HP PC out of "Sleep Mode" (Windows 7), I either had a blank screen with only a cursor or a desktop with no start menu, desktop icons or any means to operate the computer. After unplugging the speakers and hard booting the computer, the PC returned to normal operation. I'm looking for a solution myself.
Aug 13, 2010 | Altec Lansing MX5021 Computer Speakers
My HP 2009m goes into sleep mode & shuts down
hmmm is it your monitor going to sleep..or the machine? might the computer still be running?
if it's the computer go to power setting and change to your pref
Feb 15, 2010 | Computers & Internet
Went into sleep mode and will not awake, gives message of not being able ti find vga source, but all connections are good and secure, then returns to sleep mode
Sounds like there could be a short in your video cable. I had this problem occur where i would boot up my pc and after about 5 seconds the screen would go blank. Also give your monitor a reset manually after starting up your box. Just unplug the power cable to it for about 10 secs and see if that helps. Good Luck
Dec 09, 2009 | HP vs17c 17" LCD Monitor
Blank screen on return/sleep modes when pushing return/sleep
the stat is probably configured for 2 time changes a day. You need to get into the configuration mode of the stat to change this to 4. You will need the installation manual to do this or I will need the model # of the stat.
Aug 26, 2009 | Honeywell Programmable Thermostat Heater
Compaq 1701 Flat Panel Monitor Powers Up but screen is blank
no when u power up the system press F8 key then u got safe mofde menu.
then go to enable vga mode then change resolutioin to 800 *600 or 1024*768
then apply and ok.
thats it.
Nov 11, 2008 | HP Compaq 1701 17" Flat Panel LCD Monitor
HP Pavilion F1503 1503 15in Flat. screen blanks out constantly
THis is a problem of the invertor board.If you are technically able you need to disasseble the monitor and resolder components around the red or yellow inverter transformers.
Samir
Mar 04, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Computers & Internet Logo
116 people viewed this question
David Payne
David Payne
