Question about HP Media Center m7060n PC Desktop
Monitor will not boot up stays in sleep mode
When i boot up system moniter will come on it stays in sleep mode. Indicates not recieving signal. New cable and new moniter to no avail.
    Genius:
  • 1,226 Answers
Is your pc got beeps, if yes then try to remove and clean the memory and also the video card if it is add on card. and then insert it again test. if encounter still the same error then try to replace the memory.
please tell me more if ever what you encounter about the issues.
may this help,
melnavz
Posted on Oct 04, 2008
Power switch is staying in sleep mode. will not turn on or when it does turn on the moniter stays in sleep mode
use external monitor and go to control panel - power setings - here you can set up all you need
Nov 10, 2012 | E-Machines eMachines Desktop PC
Computer starts but moniter stays in sleep mode .. moniter works on different comp .. will adding a vid card to my comp fix this problem ??
Actually, Yes. It seems like you have answered your own question... Especially considering the monitor works on another computer.
Do you have another monitor to test on this computer?
Although another consideration could be if you recently installed or downloaded a program which may have changed your video output range to a setting your video monitor wont handle. If this is the case and you can start the computer in safe mode, this will allow you to go into your properties settings and change it back. This way, a new vid card is not req.
Good Luck
Sep 14, 2012 | HP Compaq dx2300 Microtower - RT950UTABA...
Monitor stays in sleep mode?
when you disconnect the monitor from the PC do you see the self test appear on the screen? if you do then the monitor is working fine.
the issue is most likely that the computer's screen resolution is too high and your monitor cannot output that resolution , so it stays a blank screen or in 'sleep' mode as you described.
youd need to go into either Safe Mode when booting the system or find another monitor preferably a newer model to connect your computer to and decrease the resolution before connecting your monitor.
Apr 24, 2011 | Compaq Computers & Internet
Everytime I turn on moniter it goes into sleep mode and won't wake up!!
If there was something wrong with the monitor itself it wouldn't go to sleep it would just turn off. It sounds to be as if there is an issue with the signal going to the monitor itself, try restarting your PC and ensure that the connection on the back of the monitor and the connection on the back of your PC are secure.
Mar 07, 2011 | HP f2105 21" LCD Monitor
I've got a HP w1907v monitor and latly it has been going into sleep mode without warning while i'm using it. All my power saver settings are set to off.
If this monitor is going into sleep mode the normally blue power led will change to yellow. This indicates loss of video signal or possible out of range resolution. If the picture goes dark and the power lite stays blue, you have a backlight malfunction. It can be an inverter power fault but this model mostly has worn out backlights causing a shutdown condition.
Monitor Mike
Aug 18, 2010 | HP w1907 LCD Monitor
Monitor goes to sleep when computor is turned on no input signal
If the monitor is going into sleep mode the normal power led will change to another color. This indicates loss of video signal or possible out of range resolution. If the picture goes dark and the power lite stays on, you have a backlight malfunction. It can be bad capacitors causing an inverter power fault or it may have worn out backlights causing a shutdown condition.
Monitor Mike
Aug 17, 2010 | HP w1907 LCD Monitor
The monitor will turn on but only stays on for about 3 seconds
Maybe you guys should make sure the moniter is on the right input, because if moniters are on a wrong input then they go into sleep mode. If that doesn't work make sure that the cables are fully inserted! Hope I Helped!
Jan 20, 2009 | HP Pavilion F1703 17" LCD Monitor
Moniter is black but has power
It's your video card! No Doubt! that happened to mine once and my friends and it was the same thing!
Dec 19, 2008 | HP Compaq FP5315 15" LCD Monitor
Need help monitor stays in sleep mode... :(
power down, everything, leave it off for a few minutes, turn it back on.. when it gets booted, disable sleep mode option in advanced power features.
Mar 19, 2008 | Computers & Internet
HP Media Center m7060n PC Desktop Logo
199 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
