Question about HP LaserJet 3600n Printer
PCL XL error on HP color laserjet 3600n
We just moved offices and now one of our HP Color Laserjet 3600n printers will not properly process any print commands. We just keep getting the message: "PCL XL error" Subsystem: KERNEL Error: IllegalDataValue Operation: VendorUnique Position: 14 Any help is appreciated...
  • HP Master
  • 1,121 Answers
Verify printer functionalityTo verify printer functionality, use the following steps:
  1. Turn off the printer and then unplug the Parallel, Serial, or Network data cable from the back of the printer. This will ensure that the information is not being received from the computer or network.
  2. Turn on the printer and verify that the word Ready appears on the printer display.
  3. Print a self-test on the printer by performing the following steps:
    1. Go to the on the printer.
    2. Press the MENU key until INFORMATION MENU appears on the printer display.
    3. Press the Item key until PRINT MENU MAP appears on the printer display.
    4. Press the SELECT button. The printer should generate a print job.
Try to print a page using the software application or a document in question after attempting each item of the following workaround. This will help determine if the changes made have caused the desired results to occur.
  1. Connect the printer directly to the computer. Use an IEEE/1284-compliant cable.
  2. Print a Test Page by completing the following steps:
    1. Click Start and then Settings and Printers .
    2. Right-click the appropriate printer driver.
    3. Select Properties .
    4. Click the General tab and click the button in the lower right-hand corner that is labeledPrint Test Page .
If the error is not resolved, try a different IEEE 1284-compliant cable. If there is no possibility to direct connect, use a different network cable, or network port, on the hub. Simplify communication options depending on the specific printer. Use the Control Panel on the printer to turn off High Speed andAdvanced Functions . To turn off High Speed and Advanced Functions complete the following steps:
  1. Press the MENU key.
  2. Select CONFIGURE DEVICE .
  3. Press I/O MENU and disable Parallel High Speed .
  4. Press I/O MENU and disable Advanced Functions .
  5. Connect the printer to a different location, change parallel/USB/network cables. Bypass switch/hub (if there is any).
For problems with certain applications or documents, try modifying the HP LaserJet printer series PCL6 driver settings, such as:
  • Use lower resolution, such as 600 dpi.
  • Enable or disable Send True Type as Bitmaps .
  • Disable the Print Optimization under Printer Properties => Advanced => Document Option .
Some more steps:
  • Try changing the personality type to Auto/PCL/PS in printer Control Panel.
  • If changing personality does not make any difference, remove the current driver completely (from Server Properties ), restart the system, and install PostScript (PS) driver.
  • While installing the printer driver, select the standard TCP/IP port if the default is HP Port , and vice-versa.
General troubleshooting tipsContinue to isolate the error by printing the job in question after applying each of the following suggestions:
  1. Remove any additional memory that has been added to the printer after being purchased. Refer to the User's Manual that was supplied with the printer for memory removal instructions.
  2. Try using a different Font within the application or document in question.
  3. Try to print using the PCL5e driver that came with the HP LaserJet Printing System.
Posted on Dec 21, 2011
HP L7680 Error
GOOGLE IS YOUR FRIEND IN SUCH CASES :) Excuse Caps. Your Drivers need updating, but you are seriously hampered because all support for XP ended ages ago. Why are you still running Windows XP leaving your computers open to security breaches? You should be on Windows 8 Pro at the least or Windows 10. What I would do is go to the HP Website and download and install the drivers and software again.
Search Results PCL XL Error. The PCL XL error is most commonly associated with HP LaserJet printers. The error occurs when several pages are sent from a document to the printer's print queue. ... HP has identified the problem printer drivers for most of their printers that display the PCL XL error.Mar 11, 2016
PCL XL Error - The Tech-FAQ
www.tech-faq.com/pcl-xl-error.html Feedback
About this result
How to Fix PCL XL Error ' Techwalla.com
https://www.techwalla.com/articles/how-to-fix-pcl-xl-error Mar 31, 2015 - When attempting to print certain documents on a Hewlett-Packard LaserJet all-in-one printer, you might sometimes end up with a piece of paper with a "PCL XL" error code printed on it. This is due to the printer's inability to process certain parts of the document, such as embedded fonts or images.
Solved: PCL XL Error and other weirdness - Customer Support Forum
forum.support.xerox.com/t5/Printing/PCL-XL-Error-and-other-weirdness/td.../164 Sep 17, 2010 - 10 posts
Hi all,. We have a WorkCentre 7655 that has been working fine for ages but is now causing some issues. A user who is running Windows 7 32 ...
PCL XL error in printer - Microsoft Community
https://answers.microsoft.com/.../pcl-xl-error.../124223ac-bd82-4758-8d7f-7efe95a04... Nov 11, 2013 - I have a HP LaserJet 4250 PCL6. I was trying to print and all of a sudden I am getting an error message. ... c:\ windows\system32\spool\printer\X64\3 rename the file relating to your printer with the .gpd extension - call it anything you wish and then reboot your pc and it re-creates ... PCL XL error: IllegalOperatorSequence
3 Dec 2016
PCL XL error - Subsystem: IMAGE - Error: IllegalAttributeValue ...
13 Jul 2016
Getting PCL XL error when trying to print.
30 Dec 2012
When trying to print, get a page that has message PCL XL Error ...
28 Dec 2012
More results from answers.microsoft.com
Troubleshooting: PCL XL Error - Customer Support
https://stamps.custhelp.com/app/answers/detail/a.../troubleshooting%3A-pcl-xl-error Next, you will need to install the "PCL" or "PCL 5" version of your printer's driver. This driver should already be available on your computer or the CD that came with your printer. It can also be downloaded from the HP website.
www.tech-faq.com/pcl-xl-error.html Rating: 4 - ‎4 votes
Mar 11, 2016 - The PCL XL error is most commonly associated with HP LaserJet printers. The error occurs when several pages are sent from a document to ...
PCL XL error Google Search
Jul 25, 2017 | Office Equipment & Supplies
My hp color laserjet cp2025 has the pcl xl error subsystem: Kernel error: Illelgaloperatorsequence operator beginpage position: 14 What can I do to fix this?
A Hewlett-Packard LaserJet printing language, PCL 6 is optimized for printing from graphical user interfaces (GUIs) like Microsoft Windows.
The Enhanced PCL XL, or PCL 6, driver that is included with the HP LaserJet printers provides enhanced WYSIWYG and enhanced performance with application support over the Standard (PCL5e) driver. PCL XL is a new page description language by HP, that is part of PCL 6 and is closer to GDI, which many applications use. Less translation takes place by the driver, which means increased WYSIWYG capabilities, and better performance with applications that support escapes implemented by the Enhanced driver.
While printing using the PCL 6 driver it is possible to encounter a PCL XL error. This error will print out at the LaserJet device, and will look like something similar to the following:
PCL XL error
Subsystem: KERNEL
Error: IllegalOperatorSequence
Operator: EndSession
Position: 15
These type of errors can be PCL interpreter errors, firmware related, tied to communication, driver, driver dependency, and application specific. Additional troubleshooting will be required to further isolate to root cause.
Troubleshooting:
I. Verify printer functionality
To verify printer functionality, perform the following:
1.Power the printer Off.
2.Disconnect the parallel, USB, or network cable.
3.Power the printer On.
4.Once the printer display reports Ready, verify device functionality by printing a Configuration Page from the device.
Note: should the internal printer test not print as expected, and/or a PCL XL error occur, you have then isolated the issue to the printer device, and any network connectivity or driver / application troubleshooting can be ruled out.
II. Verify communication w/ the device
To verify communication with the device, perform the following:
2.Reconnect any communication device cable previously removed
4.Once the printer display reports Ready, perform the following:
a.From the client machine or print server that had previously encountered the PCL XL error open the Printers and Faxes folder.
b.Right click the PCL 6 driver in question and select Properties.
c.From the General Tab select Print Test Page
d.Verify the driver test page successfully printed
Should the test page successfully print, continue with the next troubleshooting section entitled Isolate user, application and/or file.
Should the PCL XL error manifest itself as a result of the driver test page, perform the following:
1.At the print server, or client machine, open the Printers and Faxes folder
2.Click on Add Printer
3.Go through the Window’s driver install process installing the appropriate PCL 6 driver for the device in question, with the following characteristics: printing directly to the device (IP_Address, USB, Parallel, etc), creating a new print queue, selecting to Replace Existing Driver.
4.If the issue persists see section entitled: Microsoft Unidrv driver dependencies.
Note: If using an HP LaserJet PCL 6 device specific driver (discrete), try installing the latest HP Universal Print Driver PCL 6. Available at the hp.com website under support & drivers. Select product cb534a and also select your operating system, download a universal print driver Post Script would be the best selection.
You can also adjust a few settings under printing preferences:
under the advanced tab:
Raster compression:
Set it to max
III. Isolate user, application and/or file
If in fact the printers internal test pages and driver test page have printed successfully, further fault isolation must be performed to correlate the PCL XL error with a specific user, application, and or file. This information is most often easily gathered by speaking with the customer, investigating which user is printing when the PCL XL error manifests itself. Once the user is identified, the application the client was printing from can be isolated, and quite possibly the application file itself.
If an application file consistently causes a PCL XL error when sent to the device, it could be a problem only with the file.
IV. Microsoft Unidrv driver dependencies
The issue was identified to be related to Microsoft unicore files: unidrv.dll, unires.dll, and unidrvui.dll, that were not compatible with the available PCL 6 drivers at that time. Microsoft has developed a hotfix to address the symptomatic PCL XL errors – the Microsoft Hotfix can be reviewed here:
Microsoft Windows 2003 and XP: http://support.microsoft.com/kb/948046/en-us
Microsoft Windows 2008 and Vista: http://support.microsoft.com/kb/948349/en-us
Microsoft Windows 2000: NA
HP LaserJet – PCL XL Error
If anything else let me know,
Al
eliteprintersolutions@gmail.com
May 27, 2010 | HP Laserjet Cp2025n Printer
Hp laserjet 3600 PCL XL error when printing a PDF
This is a known issue with 'host-based' printers like the 3600. You need the PCL5 driver, which this printer will not work with. You need a different printer, such as the HP 3520.
This page will explain it all.
Aug 25, 2009 | HP LaserJet 3600n Printer
My hp laserjet 2300 keeps printing an error message. It began after I installed another all in one printer. the message is pcl xl error subsystem: kernael error: illegal operator...
Try updating the printers firmware.
You can download firmware here http://bit.ly/13kZ7i
If the problem remains, try replacing the driver with a PostScript-driver. That should help you out.
Jul 29, 2009 | HP LaserJet 2300 Printer
Pcl xl error warning: Illegal media source
Some people have issues with the PCL6 driver this causes pcl xl error like this to print. Change your driver from the PCL6 driver to the PCL5 driver. If you don't have the software you can down load it from HP at: http://welcome.hp.com/country/us/en/support.html
Thanks...V
Sep 19, 2008 | HP LaserJet color laser printer
Hp color LaserJet 4650
I had a similar problem with the PCL driver. I fixed it by installing the "HP Universal Printing PS" driver instead.
Sep 10, 2008 | HP LaserJet 4600 Printer
Printer error
Hi there guys reinstall the driver using PCL 5e as the program you are using may not understand the PCL 6 newer driver. Try this
Hope it helps
Thanks J
Nov 14, 2007 | HP Color LaserJet 3500 Printer
HP LaserJet 3600n Printer Logo
1,781 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
