Question about Car Audio & Video
Cd player on my fxd-785gd is not working, it takes the cd in then says loading, half ejects it and then takes it back to load again then ejects fully having not played...
  • 97 Answers
Ok does it do that for every cd
Posted on Oct 04, 2008
Kia sedona cd won't play or eject
Loading mechanism fault. Contact any service technician. The set shoud have to take out, and the loading mechanism should be troubleshoted. Gopakumar Gopalan Google
Feb 23, 2014 | Cars & Trucks
Qx56 2004= trying to load a disc but when inserting about 1" of disc in, system said push eject. I pushed eject but then system switched to FM mode. Now I cant switch to CD mode when push CD button....
Sounds like that the cd is jammed inside the players so you could either take the player out the dash and open it up yourself or take it to a dealership/repair shop for them to fix it for you.
Also there might be a small holes located under the cd slot big enough for a pin to release the cd manually?
Jul 29, 2011 | 2004 Infiniti QX56
Half an hour ago the player was still working fine. Now it's impossible to eject cd's and the player itself gets confused cause the cue goes on and off by itself and playback skips. HELP
The CD drive in your CDJ is hunting for the disc, i.e it has become difficult for the player to read the disc. Keep your ears next to the loading slot after inserting a CD, you will hear a motor spin up then slow down then spin up again and if this continues the system will lock out the eject function. Or else the disc will come flying out!!. Either you need lens cleaning ( try a cleaning kit ) or replacement ( If the player has crossed over 500 hours of use )
Mar 09, 2011 | Pioneer CDJ-100S CD Player
I have a 2008 ford fusion. i just loaded a cd into in dash cd player and it now comes up with a "load error". i tried to eject it as well and it tells me "eject error'. it took my cd but it...
See if the cd is not fully inserted, take another cd and gently try to put it into the cd player to push any stuck cds back in. If this does not work you will need to replace the radio.
Feb 28, 2011 | Car Audio & Video
Dvd in in player and won't eject. screen reads "loading".
Try unplugging the unit and plugging it back in after a couple of minutes, if cd still won't come out you can unplug the unit and manually remove the cd by taking the outer casing off.
Sep 07, 2009 | Alpine DHA-S680 6-Disc CD/DVD Changer
CD STUCK IN CD PLAYER
The case needs unscrewing to reveal more of the internals. Go carefully and peer inside wherever you can to fiddle the CD back into place or out of the box. It's in there somewhere, removing panels will get there.
Sep 07, 2009 | 2007 Chevrolet Avalanche LTZ
Stanton C303 wont eject CD
Remove the power completely replug and then quickly turn it on press eject emediatly..... this should work
Jan 01, 2009 | Stanton C-303 Single Top Loading CD Player...
How do I operate the multi CD player on a 2004 Honda Accord LX?
there should be a load button some where on the head unit
what for it to indicate that it is OK to insert another **** then press load again
to change disk there should be a disk button
to eject the cd just choose what disk to eject eg cd 4 then press eject
Dec 27, 2008 | 2004 Honda Accord
Cd's are stuck inside
Hi there!
It may have misloaded the first attempt, so ejected. Doing this may have settled it on the centre, and corrected the problem.
Try ejecting everything in there. If you hear a motor straining or other malfunction, disconnect, then start up after 2 minutes again. Eject it the first opportunity you have.
Jun 20, 2008 | Pioneer PD-F805 CD Player
The cd player will not load cds.
i've had cdj-100s for a while and i am familiar with cd loading issues... flip the turntable, on the underside there's a sort of key, it's ur CD eject pin, u take that and poke it in the hole in the front... that should take care of the stcuk cd, now the problem i'm having is, IMO, a derailement in the ejection system.... basically what's happening to us is that the 100s is in CD in mode... I've tried the key method, i think mine is totally all over the place, i've pressed eject and kinda pushed the cd in, i got it to run, play music (so lazer's not broke) and it would eject fine but then automatically go back to CD in mode and lock the drive.
i'm gonna take it completely apart and rebuild it... i'll post back with answers, if any!
Dec 06, 2007 | Pioneer CDJ-100S CD Player
Car Audio & Video Logo
87 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
