Question about YOBO Fc Twin Console
DC adapter issues
Our game was working quite well and I was totally pleased. Then The DC adapter started just slipping out of the little hole- thingy and I noticed around the end of the adapter, some green lstuff and the metallic enamel had corroded away leaving the green ..stuff underneath. I bought a replacemet DC adapter, but thaty too will not power on my FC Twin and the adapter, that even says for FCTwin will not stay in the system...: ( I'm stuck and sad ...
  • sariepoo Apr 02, 2010
    I bought the same exact adapter that came with it, but the issue remained, and I wasted my money :( maybe i need a new adapter hole thingy?
  • 3 Answers
Make sure the dc adapter is the same voltage and everything if it isnt DONT PUT IT IN it could wreck the system
Posted on Mar 09, 2010
How to replace charging port
Gateway Nv57h73u notebook jack issue check:
1) more common issue is changer ( ac adapter) DC core broken inside, please change a adapter to fix. also you can repair adapter DC core wire. if still no charging that could be DC jack issue inside notebook.
2) disassembly keyboard and top cover of your laptop looking for a wire it connect to the DC jack, check is the wire broken close to the jack soldering pot. you can soldering it to fix, or other issue is jack damaged, you can order and change the DC jack with wire easily, the parts see picture
Oct 20, 2014 | Gateway Nv57h73u With Autodesk Maya...
Gateway id49c notebook power issues
http://support.gateway.com/s/notebook/2010/gateway/id/id49C/ID49Cnv.shtml
1) Test the AC adapter (Charger) first.
http://www.itsbattery.com/gateway-ac-adapter/Gateway-ID49C-AC-Adapter.html
Test with a multimeter.
(An economical multimeter can be purchased for as little as $5 to $12. Available in a multitude of stores. An auto parts store is but one example. Checkout aisles of major discount stores, may have them on the rack)
Function knob set to DC Voltage.
(If just a symbol the symbol is a dotted line over a solid line)
If more than one DC Voltage scale set it to the 0 - 50 Volt scale.
Positive (Red) probe lead of multimeter goes to the Center Hole, of the plug end that plugs into the laptop.
Negative (Black) probe lead touches the cylindrical metal shell, on the outside of the plug end.
You should be reading 19 Volts DC.
Also have an assistant gently wiggle the cable from AC adapter to laptop, and power cable to AC adapter (Charger)
Fluctuation in the reading means you have broken wires.
AC adapter checks out OK?
2) DC Power Jack:
The DC Power Jack is the jack on the laptop, that you plug the AC adapter (Charger) into. (DC_IN)
Battery removed, (And AC adapter, 'natch), use a No.2 pencil, and with the eraser, gently see if you can move the Center Pin around.
ANY perceptible movement means damage to the DC Power Jack, and replacement.
3) AC adapter and DC Power Jack checks out?
Problems with the Power MOSFETs used in the power section, on the motherboard, or possibly Ceramic Capacitor failure.
(Multi-Layer Ceramic Capacitor, and they are Surface Mount Devices)
Using the HP Pavilion dv6000 series, and Pavilion dv9000 series of Notebook PC's, as an example,
http://mayohardware.blogspot.com/2010/04/important-parts-on-dv6000-and-dv9000.html
Looking down at the second photo with the Alpha and Omega Semiconductor - AO4407 - Power MOSFET circled in Yellow, look at the small rectangular shaped object to it's Right. Has a wide dark band on it.
This is a Ceramic Capacitor.
There is one above it of the same size, one above that one, and one to the right of the top one.
If any one of these, or the Power MOSFETs are blistered, blackened, or bubbled, they need to be replaced.
Due to issues that could arise by replacing, and having more components be bad, or go bad; the logical choice by most tech's is to simply replace the motherboard.
(Also puts more dinero in their pockets)
[ Your user name reminds me of Hee-Haw. "If it wasn't for bad luck I wouldn't have any at all." Lol!
Hey...........it's going to get BETTER! ]
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 16, 2012 | Gateway mb.wq502.001 - Id49c Intel Laptop...
AC adapter power connection LED blinks but not charging
This suggests to me that you need to check out the AC adapter, and see if there is an intermittent short. In otherwords a break in the wires.
AC adapter unplugged from laptop, and power, remove the AC power cord from the body of the AC adapter.
Use a multimeter set to OHM's, (1K), and connect the Positive (Red) probe lead to one of the flat bladed prongs, in the power plug that plugs into the surge protector.
Touch the Negative (Black) probe lead to one of the holes in the plug, that goes into the AC adapter 'body'.
Keep going from hole to hole, until you get a reading.
Now have an assistant gently wiggle the power cable, and see if you get an intermittent reading.
Do the same for the other plug's flat bladed prong.
Intermittent reading means replace the power cable, or if more feasible, the entire AC adapter.
Power cable proves to be fine, move on.
Plug the power cable back into the AC adapter. Plug the AC adapter into power.
Using a multimeter set to DC Voltage, touch the Positive (Red) probe lead of the multimeter, to the center hole of the plug that goes into the laptop.
(If just a symbol, the DC Voltage symbol is a dotted line over a solid line)
The Negative (Black) probe lead, touches the outside cylindrical metal shell, of the plug.
Have an assistant gently wiggle the cable, and see if there is an intermittent reading on the multimeter.
(Reading should be 18.5 Volts DC)
[There are Analog multimeters which have a scale, and a needle, and Digital multimeters that just have a digital readout.
If using an Analog multimeter the needle will drop towards 0.
If using a Digital multimeter the readout will drop to smaller numbers, or 0 ]
AC adapter checks out? Go on.
The port on your laptop where the AC adapter plugs in, is the DC Power Jack.
AC adapter unplugged from laptop, Battery removed.
Take a pencil, and gently use the eraser end to see if you can wiggle, the center pin of the DC Power Jack.
ANY perceptible movement means a problem with the DC Power Jack.
The GOOD news is that the DC Power Jack, is NOT soldered directly to the motherboard.
It slides down in a Channel on the outside edge of the Base Enclosure, and has a wiring harness coming from it.
The end of the wiring harness has a plug, that plugs into the motherboard.
The HP part number for this DC Power Harness is HP 600630-001
A) http://www.dectrader.com/600630-001-New-HP-DC-input-power-socket-connector-With-cable.html#.UD0_w6B0k9Q
B) http://www.ebay.com/itm/HP-Compaq-600630-001-DC-Power-Input-Jack-Cable-CQ42-G42-Notebook-Series-/180932154005?_trksid=p4340.m1850&_trkparms=aid%3D222002%26algo%3DSIC.FIT%26ao%3D1%26asc%3D11%26meid%3D1653940420718665976%26pid%3D100011%26prg%3D1005%26rk%3D1%26
This is a link to a free Service Manual from HP Support,
http://h10032.www1.hp.com/ctg/Manual/c02627955.pdf
Page 73 is for the Power Connector Cable.
No damage to the DC Power Jack, and the harness is not slightly unplugged?
Now you have real problems.
You have a bad Power MOSFET,
A) MOSFET:
http://en.wikipedia.org/wiki/MOSFET
B) Power MOSFET:
http://en.wikipedia.org/wiki/Power_MOSFET
C) http://mayohardware.blogspot.com/2010/04/important-parts-on-dv6000-and-dv9000.html
However it doesn't take a rocket scientist to replace. (Sorry Gort)
These SMD's use a J-lead contact. Simple unsoldering, and soldering.
(Better be fast though as you don't want to overheat a power transistor. Better be good, because you don't want any cold solder joints)
Regards,
joecoolvette
Aug 28, 2012 | HP Computers & Internet
I just used my laptop at work and when I got home with it and connected it, I can't get the power on, and I hear a little sound from the powercord (or the transformator - the thingy between powercord and...
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad.
6. The motherboard could be defective & needs to be replaced.
Sep 11, 2010 | HP Compaq nc6000 Notebook
The little green light on charger goes off when i plug it into Dell Inspiron 6400, the charger works fine
Unplug the battery from the laptop and then plug the AC adaptor into the laptop. If the green light still goes off then your motherboard is shorting out the adaptor and the motherboard needs to be replaced.
May 17, 2009 | Dell Inspiron 6400 Notebook
Game randomly quits, disc doesn't read
buy a new layser i did it i think if you want a high tek layser get hggh25 layser
May 04, 2009 | Sega Dreamcast Console
Gateway lap top is not getting any power, the power light is off any solutions?
1. First of all, go to http://is.gd/scG3/gateway/support and enter your serial number to make sure you still have warranty (just in case you need to order parts or send in your lappy) 2. You can open a chat window with gateway to describe to them your issue 3. Possibly order a new part, or fix the solution via gateway support.
ps. My suggestion is either a bad power cable, or bad battery. They will probably send you a new one of either for free if you still have time left on your warranty. Otherwise you'll have to pay, but it'll fix the issue. If you have any further questions, reply to turner.micah@gmail.com.
Apr 13, 2009 | Gateway Computers & Internet
Dvd drive wont open
Its a common problem. There is a very tiny hole on the dvd-rom, try to find it.
Then get something that would get into that hole, and push that something into the hole and apply pressure, it should open.
Also slamming the dvd-drive after clicking the open button would work, I do that myself, but it would totally break after time, so just use the hole thingy :)
cheers.
Jul 04, 2008 | Computers & Internet
Evo 610c won't turn on
see may be your battery is completly discharge everything is ok just charge it completly it will work
Oct 08, 2007 | HP Compaq Evo n610c Notebook
YOBO Fc Twin Console Logo
314 people viewed this question
Top YOBO Video Game Consoles & Games Experts
octanetoys
Level 1 Expert
SuicideNinja
SuicideNinja
Level 1 Expert
Are you a YOBO Video Game Console and Game Expert? Answer questions, earn points and help others
