Question about Magic Chef Kitchen Ranges
How to lite the gas oven polit - Magic Chef Kitchen Ranges
  • 104 Answers
When you turn the thermostat on the pilot light goes to secondary flame. The flame kicks on to the oven safety valve thermocouple. When it gets hot enough it generates millivolts and opens the safety valve. Here's how to check it; Make sure the flame kicks down and covers the bulb of the thermocouple. You can use a lighter if you're not sure. If no gas comes out It might be the valve that's bad. Now, some of the older models used a flame switch. It looks like a dryer thermostat with two wires on it and the thermocouple coming out of the middle. To check it, short the two wires together or use a ohm meter to see if it's closed.
Posted on Oct 04, 2008
Hi my stove is gas and the burners work on the surface but the inside of my oven does not hea
check to see if thermal coupling is on the polite. if electric lite see if it is sparking. (thermal coupling is small round tube at back of burner copper), if electric burner inspect element for white or black spots. if found clean, if hole in it replace. most electric stoves have two elements one on top and one on bottom. inspect all electric plugs , may have bad connection in plug hole. If it has lite element, see if it glows if not replace.
Sep 05, 2017 | Kitchen Ranges
How do I adjust polite lite on a natural gas stove just tryna convert to natural gas was propane are what do i do?? Just changed that piece on regulator..N that's about it??
no-
the conversion requires the changing of jet sizes for all the units and an adjustment of the air shrouds near the jets
because gas is more dangerous than power , it should only be done by an accredited gas appliance fitter
Nov 07, 2015 | Kitchen Ranges
Polit lite burning but furance wont ingite theromsat ok
flame sensor (ex. thermocouple) is not sensing pilot flame so it will not allow main gas valve to open
Nov 24, 2013 | Sterling Heating & Cooling
My gas hot water tank polite wont lite
Maybe bad gas control valve?
Copy following link from troubleshoot by type of gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Replace heater for $385
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Post question on pro water heater forum.label located on side of tank has model, brand etc.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Mar 23, 2013 | Water Heaters
Lower oven will not heat up
if its gas is the polit light lite and if its new call them so they can send a repair person
Sep 28, 2012 | Ovens
MY SUBURBAN OVEN PILOT LITES, BUT WHEN i RELEASE KNOB PILOT GOES OUT AND OVEN WONT LITE. i REPLACED SAFETY VALVE BUT STILL SAME PROBLEM.
the polit light lights but when you let the nob go for the oven burner to come on the polit light goes out
Sep 22, 2011 | Ovens
I have a GE XL44 gas stove the oven will not stay lite why?
That's bad. Sounds like the burner is dirty.
and the gas belive it or not is blowing the polit out it hit it so fast. The gas can't go in the burner. There should be two screws that hold it in place take it off and clean. See if that will work. Let me know.
Ken
Sep 20, 2009 | GE Spectra JGBP35 Gas Kitchen Range
GE XL44 gas range, oven dial doesn't have "lite"?
Set the oven for the desired temperature. It will cycle on and off at that temperature.
It will lite automatically.
Feb 27, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven will not lite
Unplug the unit, change the igniter maybe it does not draw enough ampage.
or check the gas control knob if somebody mistakenly turned it to off position. the ON position should be inline with the gas pipe.
Dec 18, 2008 | Frigidaire FGB24S5A Gas Single Oven
Oven will not lite
Replace the oven ignitor. IT probably still gets red but it has to draw enough current to open the gas valve and yours isnt. Replace the ignitor and it should fix you up.
Nov 18, 2008 | KitchenAid KGSI901PBS Gas Kitchen Range
Kitchen Ranges Logo
128 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
