Question about Genius ColorPage HR7X Slim Flatbed Scanner
Why installation is not successful because of missing file .INF
An error comes out and says missing INF file, installation not successful.
I have no driver.
Posted on Jan 03, 2009
Missing .INF file on install
I'm trying to connect to our network printer (Konica Minolta) but with no success....I'm then getting an error saying that the "*.INF file is needed"....I don't know what to do further.
May 11, 2012 | Office Equipment & Supplies
I am using windows xp. for the past three weeks i am getting ordinal 120 missing in iertutill.dll error. While nothing takes place when i close the pop up window, it is irritating when i am in the middle...
Try to find "ie.inf" file on your computer than right click on that file and click on the option "Install". You should restart the computer after completing the installation process.
Here is how it should be done.
Start>Search (type in ie.inf then hit enter)>After it comes up in the search results window right click the ie.inf file>Install>Wait till done>Reboot computer. Done!!
Oct 06, 2010 | Computers & Internet
.INF missing?
The .INF file is the driver.
You have to browse to where you downloaded the drivers and select the correct file.
Mar 25, 2010 | Lexmark E240 Laser Printer
An error occcurred during the installtion of my HP 7280 photosmart printer. The parameter in incorrect.
Microsoft Windows 2000 and XP require files named printupg.inf and printupg.PNF to be found in the Windows .inf folder. If these files are missing or damaged, no printer can be installed and the error of incorrect parameter will come, and the existing files need to be removed if present, and a fresh copy of printupg.inf restored from the Windows backup archive. Kindly Do the following steps:--------
  • Double-click My Computer on the first screen or in Start menu.
  • On the Menu bar, click Tools , then Folder Options
  • Click the View tab.
  • Under Hidden Files And Folders, select Show hidden files and folders
  • Deselect Hide extensions for known file types and Hide protected operating system files .
  • After the above steps, you will be sure that the Computer is showing all files. After it >..............
  • Close the other applications. Double-click the hard drive icon that Windows is installed in, the name usually ends with C: .
  • Double-click the Windows or WINNT folder icon.
  • Double-click the .inf folder icon
  • On the Menu bar, click View , then Details .
  • Click the word Name above the list of folder and file icons until the list is in alphabetical order.
  • Scroll down the list to the section where files starting with the word print are located.
  • If files are found named printupg.inf or printupg.PNF , rename them using the following procedure:----
  1. Right-click on one of the files, then click Rename
  2. Click at the right edge of the file name to remove the highlight from the name.
  3. Press the Backspace key on the keyboard three times to remove the inf or PNF letters
  4. Type the reverse of the three letters, then press the Enter key on the keyboard. For example, inf would be replaced with fni, and PNF would be replaced by FNP.
  5. If the other file is present, Repeat Steps as through in step 4.
  • Insert a new copy of printupg.inf into the inf folder using the following procedure:
  1. Determine where the correct i386 folder is by double-clicking My Computer on the first screen or in the Start menu, then double-clicking the icon that ends with C: If the i386 folder is not displayed, click the Up or Back arrow at the top of the window, then try any other icons that look exactly like the one already tried, one at a time. If the i386 folder is still not found, insert the Windows or computer manufacturer recovery CD-ROM disc and double-click each icon that looks like a CD-ROM disc one at a time.
  2. Make a note of the path where the folder is found, including the drive letter at the end of the icon name. If folder icons were double-clicked during the search, do not use the i386 folder found after double-clicking the Driver Cache folder. For example, if the i386 folder was found on the recovery CD-ROM disc in drive G: , in folder Archive, the path would beG:\Archive\i386. If the folder was found in the computer's hard drive, the path will probably be C:\i386 . If it was found on the Windows CD-ROM disc inserted in the drive icon ending in M: , the path would be M:\i386
  3. Click Start , then Run
  4. In the Run box, type CMD , then click OK
  5. At the blinking cursor in the black box, type the following statement, where PATH is the actual path determined in step a above and _ is the underscore key, which requires holding the Shift key while pressing the Dash key: EXPAND PATH\printupg.in_ C:\XXX\inf\printupg.inf .
  6. The text that Windows displays in the black box will now indicate if the file was found and expanded or not. If the text includes an error message, type the statement above again at the blinking cursor, checking for accuracy. Ensure that all backslashes and the single blank spacebar key after the underscore (Shift+Dash) are included, and that a full colon is typed after each drive letter.
  7. If another error is displayed, verify that the PATH being typed is correct by referring to step a above, then type the statement again
After the file has been successfully expanded, close the black box. The missing printupg.PNF file will be created by Windows when it is needed.
  • Uninstall and reinstall the printer software by using the procedure recommended in the documentation that came with the printer.
Thank you, Have a nice day.
Sep 28, 2009 | HP Photosmart C7180 All-In-One InkJet...
I have a toshiba satellite a105-s4114. Did a fresh install and can't get the SD card reader to show up. I have gone to the Toshiba website and installed what should be the correct drivers. For the Texas...
INF error usually occurs if the inf file is missing or the auto run .inf extension file is missing. INF is used to load the auto run of the application that made it possible to be used to any specified application that serves its purpose. So therefore your SD card reader won't show up due to the face that its INF file that is responsible in loading it application is missing. So i recommend that you have to reinstall completely the driver of SD Card reader in order to be able to use the application.
Thanks
Aug 06, 2009 | Toshiba Satellite A105 Notebook
INF error with crystal eye webcam on vista premium.
you're crazy installing vista on that netbook. acer doesn't have vista drivers for that model.
Apr 26, 2009 | Acer Aspire One PC Notebook
Troubleshooting
Restore missing Help and Support Files 1. Click Start, Run and type %windir%\INF
2. Locate the file pchealth.inf, right-click and choose Install
pchealth1.jpg There will be two files namely PCHealth.INF and PCHealth.PNF. You'll need to right-click on the INF file (identified by a text pad and Gear icon in it) and choose Install.
3. In the next step, you'll be asked for the Windows XP CD (to extract dataspec.xml and many other files). Insert your Windows XP CD and point to the i386 folder in the CD.
pchealth2.png 4. Click OK. This restores missing Help and Support files.
note: The PCHealth.INF installation routine is not complete, as it does not register Help and Support completely, nor does it create the helpsvc service and other registry keys. At this point of time, nothing may happen when you start Help and Support, or it exhibits an error message mentioning the Help and Support service is missing.
Step II - End the Help and Support services Click Start, click Run and type Taskmgr and click OK. This opens Task Manager. Click the Process tab. Terminate the following processes if running:
  • helpsvc.exe
  • helphost.exe
  • helpctr.exe
Reinstall Help and Support
Click Start, click Run and type cmd.exe, and click OK.
In Command Prompt, type the following commands one by one and press {ENTER} after each line. Alternately, you can copy the commands below to Notepad, save the file with .bat extension (e.g. helpfix.bat) and run it.
net stop helpsvc
cd /d %windir%\pchealth\helpctr\binaries
start /w helpsvc /svchost netsvcs /regserver /install
start /w helpsvc /register
start /w helpctr /regserver
Sep 21, 2008 | Microsoft Computers & Internet
Editing text
Windows
» HP Scanjet Scanners Supported and not Supported in Microsoft(R) Windows XP s.gif » Resolving 'Missing MSIEXEC.EXE File is Linked to Missing Export: MSI.DLL.222' Error Message During Installation of the HP Director Software s.gif » Resolving 'Scanner not supported' or 'Unsupported operating system' Error Messages s.gif » Resolving Image Zone Install Error 1402, 1406, 1714, 1904, 1935, 2203, or Unknown Error s.gif » Error 'The System Cannot Find the File Specified' While Attempting to Install the HP Photo & Imaging Software in Windows 98, 98se, or Me s.gif » 'Cannot Install This Hardware - The Required Section Was Not Found in the INF' Error Message in Windows XP s.gif » 'Error Install Failure' Message for the hpznfx01.exe Software Module Displays on the Computer When Installing HP Image Zone s.gif » The message 'Fatal error during installation' or 'Error Install Failure' Occurs When Installing HP Image Zone s.gif » A 'Fatal Error' or 'Error_Install_Failure' Error Message Displays on the Computer When Installing the Image Zone Software s.gif » The Error Message 'Error_Install_Failure' or 'Fatal Error' Occurs when Installing Image Zone Software s.gif s.gif
Macintosh
» Mac OS: Software Driver Install Causes Error, "Interface Lib Get Component Resource Could not be Found" s.gif » 'Cannot Install This Hardware - The Required Section Was Not Found in the INF' Error Message in Windows XP s.gif » 'Scanner could not be initialized' Message Displays in Mac OS X when the All-in-One Software is Installed s.gif » Mac OS: Software Driver Install Causes Error, "Interface Lib Get Component Resource Could not be Found" s.gif s.gifs.gif
Jun 13, 2008 | HP 4570C Flatbed Scanner
Missing INF file?
here are instructions on using the Mcafee Removal tool.
http://service.mcafee.com/FAQDocument.aspx?id=107083&lc=1033
May 31, 2008 | Mcafee WebShield 3100 (EPL310ANA300)...
Failed Web Camera Installtion
Encountered error during installation of the device. The driver installation file for this device is missing a necessary entry.
Apr 04, 2008 | Cameras
Genius ColorPage HR7X Slim Flatbed Scanner Logo
112 people viewed this question
Top Genius Office Equipment & Supplies Experts
Ricky Ostrom
Ricky Ostrom
Martin Murray
Are you a Genius Office Equipment and Supply Expert? Answer questions, earn points and help others
