Question about Mitsubishi WS-65809 65" Rear Projection Television
Shuts off and has problems comming on
Tv shuts off if it gets to cold and i have to put a space heater behind lt to come back on.some times it takes hours and the all it does is flash the green light
  • 2,071 Answers
TV shuts off if it gets cold,this is the symptom of "cold solder" in power supply section and also in DM board section.needs to reworks or resolder the solder joint.
The constant blinking green light means that the TV is not booting up. This is a common problem on this set.You need to remove the shield from the DM board (standing upright on the left where the DTV RF connector is)and inside you will see the four leaky capacitors (1000 MFD 16 VOLT)replace them,plug the TV in and wait 70 seconds for the blinking light to stop,then turn on the TV.The hard part will be removing the board from the TV(lots of screws and connectors,takes time)
shuts off and has problems comming on - a3d2d2a.jpg You must do some checks first:LED does not stop blinking after plug in. Verify the standby supplies, 12-volts at connector KA pin 17, 6-volts at KA pin 18 and the 28-volts at KA pin 19, if the supplies are present suspect the DM PCB part # 934C067001 LED does not stop blinking after plug in. Check C9B01, C9B02, C9B10, and C9B11 (1000 UFD 16) on the DM PCB, if they are bad replace them with part # 181P734030 (680 UFD 16 V). LED stops blinking after 70 seconds of plug in but will not power on. This model is equipped with a keyboard lock feature; this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds . LED stops blinking after 70 seconds of plug in but will not power on. Check for 3.2 volts DC at connector RF pin 4 and 5 on the Signal PCB if low suspect problems with the switches/buttons on the Control PCB part # 935D736001. LED stops blinking after 70 seconds of plug in but will not power on. Keyboard is not locked and key inputs at connector RF pin 4 and 5 check good suspect the E2P PCB part # 934C061001.
Just click below for more information.; http://www.fixya.com/support/t838883-mitsubishi_wd_52825_tv_wont
Hope it may help you ;
Regards,
VOTIT
Posted on Oct 08, 2008
How do I cast on in knitting
Hi I am not a great knitter but I do know how to cast on stitches.
OK here goes, Get your two knitting needles and wrap the wool around both loosely and tie a knot, holding one needle in your Lt. hand and one in your Rt. hand (Rt. needle point is under the Lt. needle point and loop of wool is around both needles)
**take the loose end of wool in right hand and put it around the point of the Rt. needle towards you while holding every thing firmly, with your Lt. middle finger push the point of the Rt. needle back towards you and at the same time twist the Rt. needle up with your Rt. hand, catching the wool you just looped around the point of the Rt. needle, return Rt. needle back behind Lt. (you now have 1 loop on both the Rt. & Lt. needle) Still holding both needles bring the Lt. needle to the front of the loop on the Rt. needle and slip the loop over onto the Lt. needle
YOU HAVE JUST CAST ON 1 STITCH.
Insert the Rt. needle into the stitch you just made and positioned under the Lt. needle***.
Repeat from ** to *** until you have enough stitches.
NOTE to make a firmer row after the first stitch put the Rt. needle behind the complete loop not just the front of the loop.
**taking loose end of the the wool in your Rt. hand , loop it around the point of the Rt. needle towards you while holding every thing firmly, with your Lt. middle finger push the point of the Rt. needle back towards you and at the same time twist the Rt. needle up with your Rt. hand, catching the wool you just looped around the point of the Rt. needle, return Rt. needle back behind Lt. (you now have 1 loop on both the Rt. & Lt. needle) Still holding both needles bring the Lt. needle to the front of the loop on the Rt. needle and slip the loop over onto the Lt. needle ***
Same as previous instructions and keep repeating until you have enough stitches.
Jan 03, 2016 | Crafts & Hobbies
How to fix fan cold/hot system toyota avensis 2007 2.0 lt
Perhaps the Avensis has a brittle cable like in the Highlander.
Please see
http://www.tundrasolutions.com/forums/highlander/32217-heater-quit-sort-of/
It's usually broken solder joints on a cable behind, and feeding, the temperature knob.
I repaired my 2002 Highlander yesterday thanks to this site.
Dec 09, 2015 | 2007 Toyota Avensis 2.0
I have very low hot water pressure in may home....cold water pressure is ok....
You have clog in hot water line or inside water heater.
Use Brady BTG100 pressure gauge to assist.
http://www.ronshomeandhardware.com/BTG-100-100-PSI-Water-Pressure-Gauge-p/405357.htm
Put gauge on outdoor spigot and then turn on hot water to get baseline.
Put gauge on water heater drain, and then turn on hot water. If pressure stays high, then clog is in hot water nipple or inside pipes after water heater.
If pressure drops, then clog is in cold water nipple, shut off valve above tank, or somewhere in line between main cold water and water heater.
Water heater nipples, shut off to water heater, and elbows are good suspect.
Any galvanized and copper connection is good suspect.
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Apr 05, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
My ge profile regrigerator is not cold in the refrigerator section, ice breezes on the back wall of the freezer and it will make ice at times. I think it is a defrost issue as I will shut off for a while...
Pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire2 , and the other into wire3 . Plug the refrig back in . After about 3 min , look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a shorted defrost heater WR51X10101 . It is also advisable to replace the defrost thermostat ( pt. number WR50X10068 ) when replacing the heater . To access these parts , you will have to remove the inside rear wall of the freezer . The heater , is at the bottom of the coils , held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire going to it , clipped on the top left of the coils .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp and when to cycle off due to selected temperature .
Jul 18, 2010 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
Electric baseboard heater
this is a tough call but with 2000 watts in each room there should be more than enough heat .the rooms should maintain a average temp of 73 to 78 degrees temp without weatherazation and that is of course there is no drafts coming from any windows or near a front or back door that opens and closes alot . Basiclly you have it covered but definatley get the house winterize/insulated real good.I would keep 1 or 2 space heaters on hand just incase the person in house feels there cold just to cover yourself ,usually it the female complaining its cold if its not warm enough but there have been some males that need that temp to be 80 degrees all the time.good luck but im sure it will be ok!!
Sep 29, 2009 | Fahrenheat Electric Convector Baseboard...
My freezer is not cold
Three should be the coldest.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 03, 2009 | Refrigerators
Compressor on sxd20tw wont shut off. just cleaned
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Aug 25, 2009 | Refrigerators
After instillation, the washer runs several times-then we noticed my hot water heater is shutting the pilot light off. Back pressure possibly on the Hot water side? Was purchased as floor model and N
what kind of water heater do you have?? as far as the washer it has a mxing valve inside the unit that mixes the hot and cold water to get the proper tempreture, write me gary1121@aol.com let me know about the water heatrer,, that is what you are asking about
May 19, 2009 | GE Profile WPRE6100G Top Load Washer
JVC model LT-37xm57 will not stay on
I believe it is an overheating problem...
Short term fix...place a small fan behind your TV on bottom right hand corner and your TV will not shut down
Mar 24, 2009 | Televison & Video
Rinnai 1001FA Energy Saver - Green Light Goes Out!
It is time to replace it. You cannot get some components like the main board.
Dec 15, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Mitsubishi WS-65809 65" Rear Projection Television Logo
73 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
