Question about RCA F27650 27" TV
RCA F27650 32" TV Problem
Our RCA F27650 32" TV was working this afternoon. When we got home this evening and tried to turn it on, the TV would not turn on and the power light blinked green several times then stopped. We also heard a clicking sound each time it blinked. We tried unplugging everything and turning on the TV manually as well as with the remote, but that did not work. The toll free RCA troubleshoot department has been no help either. We would greatly appreciate any assistance on this.
Many thanks,
David
  • ddw7321 Oct 05, 2008
    Thank you, Shuttle83! I greatly appreciate your thorough response. It sounds like fixing this problem may be expensive. Do you have any idea how much this will cost?
    Genius:
  • 1,139 Answers
Hello ddw7321,
This sounds like it could be a malfunction in the High Voltage section of the TV. The shutdown circuit is switching on and preventing the TV from turning on. This might be due to an excessive amount of current flow possibly caused by a shorted turn in the Integrated High Voltage Transformer (IHVT), or a shorted Horizontal Output Transistor (HOT). To test this you will have to unplug the TV set, and with a multimeter set to resistance, measure the resistance from the collector of the HOT to ground, If it reads 0 ohms then that is the problem (a shorted HOT). The next test which is of the IHVT is a little difficult because it requires removing the IHVT and doing a ring test. At this point I would like to suggest that you take the TV to a repair shop, because these next test might be difficult for someone who does not know electronics, and if you have no knowledge of electronics you may do more damage then good.
With that being said:
Remove the HV anode of the IHVT connected to the CRT by first using a large flathead screwdriver connected with a clip lead to the ground of the TV, by sliding the screwdriver under the rubber cap and releasing the clips. Then unsolder the pins on the bottom of the IHVT using a soldering iron and a suction type desoldering pump. when the solder is removed , pull the IHVT from the circuit board. locating the main primary winding connect it to the device that you are using to perform your ring test (I use a Sencore LC-102), when it is connected do the ring test and it should have at least 10 rings to be considered good, any less then 10 and the IHVT is to be considered as bad.
I hope this helps.
Thank you,
Shuttle83
Posted on Oct 04, 2008
  • Henry McKelvey
    Henry McKelvey Oct 06, 2008
    Hello ddw7321
    The cost may be between $100 - $250 including parts and labor, depending on the shop.
    Thank you,
Set won't turn on. Was working fine last evening. Now nothing.
Reciever RCA RT2500 ' Techlore
www.techlore.com/forum/thread/11889/reciever-rca-rt2500
Aug 20, 2005 - 31 posts - ‎23 authors
hey ive got the rca RT2500 home theater system. .... won't power up) regardless of number of times I try to simulate a 120 V power flash (pulling plug .... My RCA receiverturns on but there is no sound...what can this mean?
Trouble getting sound from home theatre system with my ...
www.tomsguide.com/.../trouble-sound-home-theatre-system-appreciated....
Mar 27, 2013 - TV: Sony Bravia KDL-60EX645 Home Theatre System:RCA RT2906 ...-I've set the television, per the manual's instruction, to "Audio System" and "Audio Out: Fixed." This should allow the TV to turn off its internal speakers and switch .... SolvedI have F & D home theatre system, my rear speakers won't work.
Problems connecting surround sound to LCD TV... - Forums - CNET
www.cnet.com > Forums > TVs & Home Theaters
CNETJul 30, 2006 - Hey I have a 26" LCD TV from Polaroid and a Philips DVD home theatersystem. ... the Audio setup on the tv and TELL it to output the sound via the RCAcables ... However, you would normally turn off the TV speakers with a menu ... I just can't figure out why the TV audio won't play on the surround sound. Anynet+ - Home theater won't turn on with tv
Jun 11, 2015
TV won't turn on
Jun 10, 2015
Audio Return Channel Problem
Aug 23, 2011
rca tv no sound?????
Jan 1, 2006
More results from www.cnet.com
Jan 19, 2016 | RCA Audio Players & Recorders
Try to turn on via remote or button on set. Only a green flash on front. Nothing else. Can I fix it?
About 435,000 results (0.80 seconds) Search Results
    3 Ways to Program an RCA Universal Remote - wikiHow
    www.wikihow.com > ... > TV and Home Audio > Television
    wikiHow... Universal Remote. Are you tired of juggling three or four different remotes just to control your home theater setup? ... Log in via ... Turn on the device you want to control. ... Press and hold the button on the remote that corresponds with the device.... You will need to try another method in this article to program the remote.
    How to Program an RCA RCR312W Remote: 15 Steps ...
    wikiHowHow to Program an RCA RCR312W Remote. ... Log in via ... Press the PLAY buttonevery five seconds until the component turns off. ... If component does not respond or has limited functionality, codes in a different block list can be tried until you find the code that allows the remote to .... Set Up a Home Theater System.
    Your remote reprogramming woes solved - Rogers RedBoard
    redboard.rogers.com/.../your-remote-reprogram...
    Rogers CommunicationsJun 18, 2014 - Once the TV turns off, press the SETUP button once to lock the code.... You can always contact us via our Facebook page or tweet us ... Hi my TV is anRCA model # RLDED3258A-B I have tried 73 codes from Universal .... I have tried toset up my tv and home theatre with the Rogers remote but no luck...
    RCA TV: input channel/s-video - ecoustics.com
Tv will not come on
  • check to see if tv has sound when you turn on, then check menu for color, check if tv might be on timer. this might help!!!
Mar 19, 2009 | Sanyo DS27510 27" TV
RCA F32649 32" guide plus TV
you need to check the fuse ,maybe it's busted.
Sep 04, 2008 | RCA F32649 32" TV
Tv wil not turn on
The horizontal output transistor is most likely shorted, it's a 2sc5588 Rca Part # 259899 and there are a couple of subs available for that too.
The slight squealing you hear is the feedback voltage on the hot transformer as the B+ tries to increase and the s/d circuit cuts it off. Not an expensive repair...
Good Luck!
Bill
Feb 10, 2008 | RCA D52W19 52" Rear Projection Television
TV turns on and off by itself
you need change memory ic 24C08 near microprosessor.
Oct 10, 2007 | RCA 27F530T 27" TV
Black and white lines
Good afternoon your tv could have some lose solder have a tech look at it.the problem is in the video circuit and related circuit.checkd should be made in the IF circuit.good luck.
Apr 05, 2007 | RCA 27V530T 27" TV
RCA 27 inch TruFlat TV/ Walmart Feature Item "Defective!"
I AM SORRY ABOUT YOUR PROBLEMS WITH YOUR TV... AS IT IS YOU BOUGHT YOURS AT APPROXIMATELY THE SAME TIME THAT I BOUGHT MINE. I STARTED HAVING PROBLEMS WITH THE SAME THING YOU DID ABOUT 6 MONTHS AFTER I PURCHASED IT. BUT THEN I THOUGHT IT WAS DUE TO SOMETHING MY NIECES HAD DONE TO THE TV. MY DAD TRIED TO FIX IT AND IT WORKED FOR A WHILE AND THEN ON CHRISTMAS EVE 2006 IT WENT COMPLETELY BISERK!!! NOW I DONT EVEN KNOW WHERE TO GET THE CONTROL PANEL.
Jan 07, 2007 | RCA 27F530T 27" TV
Open Questions:
Letterboxing: The top and bottom of the screen are cut off I originally obtained this TV from my Bro who passed away from cancer at age 31 a few years ago & I was never able to find out what he did with the manual. However, I was able to find a manual online but after viewing it, I still wasn't able to find the info. that I am trying to obtain for the correct settings to get rid of these black margins at the top & bottom of the screen. I am trying to find out what video output format is supported by this TV model, as far as the resolution and output format, specifically for a Cisco or AKA Scientific Atlanta 500GB HD-DVR through Cox cable? My available settings with Cox cable & the DVR I have( Cisco or Scientific Atlanta 500GB model)are the following-Resolution:480i, with output format of either:Zoom 16:9 Pic or Letterbox 16:9 Resolution:480p standard, with output format of either:Zoom 16:9 Pic. or Letterbox 16:9 Resolution:480wide, with either output format of:Stretch 4:3 Pic, Preserve 4:3 Pic or Sidebar 4:3 Pic Resolution:720p wide, with output format of:Stretch 4:3 Pic, Preserve 4:3 Pic or Sidebar 4:3 Pic and finally, resolution:1080i wide with output format of:Stretch 4.3 Pic, Preserve 4:3 Pic or Sidebar 4:3 Pic? Everything worked fine with the screen size when I had a 160GB Motorola HD-DVR with Cox under the video output settings of:resolution:480i and video output of:Zoom 16:9 Pic until, I grew tired of constantly running out of space & had them switch me to a 500GB HD-DVR. They were supposed to install another Motorola HD-DVR but just with 500GB version but when the Cox maintenance employee showed up to swap them out and install the 500GD HD-DVR, he only had a Cisco/Scientific Atlanta 500GB available on his truck, which is I guess what they use for the Contour service but he attached a filter to the back of the coxial cable to make it a regular HD-DVR without Contour(even though they tried charging me extra for contour for 3 months before I finally got that straightened out since the maintenance workers & billing dept. are often not on the same page as I found out at Cox. I have tried calling Cox for support & they say that I need to find out & know my TV's video output settings. I explained to them that it worked perfectly fine just weeks ago with 480i resolution and output format of Zoom 16.9 Pic before they switched to the Cisco/Scientific Atlanta HD-DVR from the Motorola DVR and that I didn't have the manual and I stated why and they basically said, too bad, figure it out yourself. Can someone please help me out? I have the TV set up for the correct zip code, cable box-Yes, the cable box output channel-video 1/Aux (since that is what the TV manual I read online said to use if you are using the 3-color coded cables instead of the coxial cables to plug in from the TV to the HD-DVR) & I have the Cable box remote control code set to code 008 (Scientific Atlanta) that I verified to be correct by checking it through the TV's automated code search. The serial # for the TV is:C306B2084 and the Chassis # is:ATC113BB1 and its the 27" RCA Entertainment Series Guide Plus Gold Gemstar that is X-Box ready. Thanks so much, Todd
Feb 26, 2017 | RCA F27650 27" TV
RCA F27650 27" TV Logo
262 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
