Question about Philips GOGEAR SA6045 MP3 Player
File System Error!?
I have had a Philips 4Gb Go Gear player for about 3 months. It's been working great until about 4 days ago. I try to turn on my player and it stays on the Go Gear screen for about 10 seconds than shows a white screen that says File System Error and then shuts off. When I plug it into the computer it charges, and my computer makes a noise like it recognized it,but my computer will not recognize it. Please Help, I'm only 12 and I spent all of my money on this player! It's driving me nuts!
  • 9 more comments
  • Anonymous Oct 28, 2008
    I have this same problem can anybody help us! i m gonna hate philips
  • Stephie14
    Stephie14 Oct 30, 2008
    I charged my player last night, and when I tried to turn it on this morning it went to the philips white screen, then cut to file system error. What do I do??? I only got it a month ago...
  • Stormqueller Nov 14, 2008
    I have the File system error problem but no drive D: or any other removable drive that is not normally there shows up.
    So with no drive shown in Explorer, how do I format my player?
  • blair01 Nov 17, 2008
    I ALSO HAVE THE SAME PROBLEM IT SAY'S "FILE SYSTEM ERROR"... DOES ANYONE HAVE THE SOLUTION? BECAUSE I DID NOT SEE ANY REMOVABLE DISK (D:) EITHER.
  • walkr21 Nov 20, 2008
    Ive had the sae MP3 player and just purchased it a few onths ago, worked fine, until I disconnected it from my PC,and the only screen that will come on is "File System Error", and then turns off, unable to ven be used, Im on disability and saved for a while before I could afford this MP3, and its basically useless as it will show no screen, or even regisyer on my computer as it always did ,offering me choices as to what Id likke to do. I plug it in, the cnnection sound is heard, but no screen comes up.Id like a refund or replacement after the problem has been solved as to why this happened
  • Anonymous Nov 22, 2008
    same promblem
  • Jenny Aldrich
    Jenny Aldrich Dec 29, 2008
    I have the same problem and so far none of the solutions have been
    helpful. This happened to me once before and I simply did the same
    thing as Stephie14 suggested. but THAT was when my computer was recognizing the device. This time my computer is completely ignoring my MP3 player when I plug it in. I can't get to it's file under "computer" to delete everything because it's not there! I've tried restarting the computer, hitting the reset button on the device, etc... I'm at a loss.
  • galexyoneta Jan 09, 2009
    I charged my player for a few hours and when I tried to turn it on it reads, File system error, the player is only a few weeks old. Please help me with this problem, thanks.
  • Stormqueller Mar 11, 2009
    I posted earlier and have been trying every posted "solution" but to no avail. It appears my MP3 player is completely useless.
    But I did solve the problem by going out and getting an iPod Nano.
    It cost me twice what I paid for the Phillips, but it's working like a charm. So I guess you really do get what you pay for.
    -=Storm=-
  • memonicad May 11, 2010
    Stephie14, thought I was going to have to buy my daughter another MP3 player :( or watch her go out of her mind without one. Great solution, quick fast and very helpful. THANK YOU :)
  • Viktorija Zh
    Viktorija Zh Dec 24, 2015
    I had same error and fixed it.
    Error description:
    On Philips GoGear Ariaz was an error : File system error.
    When I connected it to my PC (windows 7, 10), it was not recognized correctly. Device manager saw MTP device, but could not find correct driver.
    Solution:
    Connected device to PC, where was installed Ubuntu (in my case Linux Mint 17). On PC: menu -> USB stick formatter -> format as Fat32.
    After formatting, device will be recognized on Windows and will work again.
Ok, so what you need to do is plug your player into the computer. Then, in the go to my computer in your start area.
In your computer folder, you should have a removable disk (D:), this is your player.
Right click on the tab and go to Format, click on quick format and then start.
The next window that should pop up will say that it will may erase all the files on the device. That is ok. It will erase all the music you had on there, but that is easy enough to load back on.
Wait for it to finish, unplugg it, turn it on, and you should be good. All you have to do now is reload the music!
I had to figure this out for myself just a few minutes ago because I was having this same problem. Good Luck!
Posted on Oct 30, 2008
  • 5 more comments
  • Stephie14
    Stephie14 Mar 11, 2009
    Thanks you guys! I am glad everything worked out for you!
  • Stephie14
    Thanks you guys! I am happy it worked out for you!
  • mighthunter1 Oct 23, 2010
    but what if it dont connect to the computer to click on removable disk(D:) ? my will charge but it wont turn on or connect to the computer. what should i do?
  • AZ Skipper Dec 02, 2010
    Same problem here. Soooooo I plugged the player into my Macbook, went to Disk Utilities, ran the "repair" option ............ it worked !!!!!!!!! Went back to the Windows XP partition that I also run on the Mac, loaded my songs onto the player from a folder titled "GoGear"where I have all of my songs backed up. It took about 15 minutes to load. I now have 2304 songs back on my 4GB GoGear. Still have 1.6 GB of free space on the player. Moral of the story ........ backup your files,and get a Mac. Windows SUCKS !!!!!!!!!!!
    Ed in Arizona
  • paulaguirre Feb 02, 2011
    how do you keep it on
  • claia smith Jun 14, 2013
    can you take something sharp stick it the hole on the bottom that says reset after tht wat do u do
  • palebunnyinf
    palebunnyinf Oct 29, 2013
    Wow, this is from 2008 and it's almost 2014 but people are still having the same problem. How can I open the 'removable disk' when that is NOT where the philips gogear is reflected. The problem is that it isn't showing up under 'my computer' AT ALL & the 'removable disk' drives all show empty. Normally the gogear shows up in whatever USB hub I plug it into and is called 'phlips gogear' and shows total memory space/used/available, etc. like every other drive - now it doesn't show up AT ALL. The USB hubs show that nothing is plugged in, my 'eject hardware & media devices' does not indicate the MP3 player is plugged in either. It's a BLANK. Also it is NOT easy to reload the music files and many people do not have backup files for those, it doesn't matter anyway because the computer doesn't read the MP3 player PERIOD.
I have been looking for a fix for 8 months. Have tried every fix suggested. Still cannot repair or update firmware. Philips has been no help whatsoever.
Warranty issued with device, useless.
My personal solution is to never purchase another Philips product.
Julie Keller
Ellijay GA
Posted on Nov 15, 2008
  • Mikitiale Jan 14, 2011
    I tried this but it didn't work im only 11 and i can't figure this one out on my own.
If your computer is not recognizing the device and you DON'T have the software on your computer, you need to go to the philips.com - click on "Customer products" - then "product support" - then find your device and download all the software for it (Device/Filmware Manager especially)
Once you have all the software on your computer- open it and plug your device back into the computer while holding down the "back" button the entire time until the computer recognizes it. It should start repairing your device automatically. It WILL delete everything on your Mp3 player.
I had this problem because I got a new computer and forgot to put the philips gogear software on it. If you don't have the correct software on your computer, you WILL have problems.
Posted on Jan 09, 2009
  • louisbharnab May 18, 2011
    thanks so much..
  • szija Aug 20, 2011
    The product I bought in the UK is 8 GB, yet it is not among the products on Philips official website, only the 4 GB model. Device manager link never worked, not even dowloading, after 8 month my device is actually garbage, I will never ever buy any Philips again. The website is stupid, among ten thousands of miniature photos of mp4 players yet mine is not among them.....holy ****...this is not professional at all!!!
Ok, so i figured out the BEST WAY TO SOLVE THIS PROBLEM!!!
Connect your player to your PC, and go to my computer.
Find where the player is connected (e.g REMOVABLE DISK E:)
Right Click it, and click FORMAT
This will erase all of your files, but WILL MAKE YOUR PLAYER WORK AGAIN!!!!
Posted on Apr 15, 2009
  • nb_ashok Sep 29, 2010
    my systemm is nt recognizing it
    New Friend:
Plug usb cable, push (10 sec) reset button (left) and wait. Later, GoGear was turn on, in transfer mode, wait.
The Phillips Device Manager must be opened. Eject mp4 on my computer, release the usb cable.
Press button "+" , plug usb cable and wait the Device Manager.
Just Fix in Device Manager.
No NOT format the device. NOT forget eject before unpluged usb cable.
Sorry for my english.
Att
Posted on Nov 11, 2010
  • palebunnyinf
    My Gogear is not reflected in device manager, my computer, 'eject hardware' or any other place on my PC, therefore these options are useless.
Ok, here's another piece of the puzzle.
I just tried connecting my GoGear to my wife's XP netbook and it came up just as sweet as you please.
It appears the issue may be with Microsoft VISTA. (What a shock, huh?)
Try connecting to an XP machine and you may be able to resurrect your dead unit.
Since I went and bought myself an iPod in the interim, I'm giving the GoGear to the wife. And she's ever so grateful. <wink>
Cheers!
-=Storm=-
Posted on Mar 11, 2009
I have the problem that my system says the device is working properly, Philips Device Manager doesn't see it connected, no device listed in my Computer bu tin device manager (system) it sees it. Without being able to access it in any way, I cant do anything. I am so P'd off with this product. I am technically able, but nothing I do can get this **** working. Why doesn't Philips respond to emails about support? I am sick of companies not backing up their product. I have had this problem since I purchased it. One day computer recognizes it, next time, it doesn't. I have had the MP3 plugged into the system for 2 weeks, praying it will fix itself at this point. It is a piece of ****!!!!!
Posted on Jun 29, 2009
    New Friend:
Note: if the player still recognized as removable: disk but cannot access the drive. if the player doesnt recognized by the computer,the solution stated wont work ok..
Solution:go to disk management under windows XP, wait until the utility recognize ur drive, in the event it did show up right click on the drive and format (FAT) it will take a little long just wait and Kaboom ur player has been resurrected..
thank you hope it helps.
(based on my personal experience....)
Posted on Jun 30, 2011
  • palebunnyinf
    Mine isn't recognized as removable, it isn't recognized as even being plugged in.
  • 4 Answers
FORMAT WITH MACINTOSH ¡¡¡¡SOLVE!!!!
By: Jaime Mora
Posted on Sep 07, 2009
  • jrmora33 Sep 07, 2009
    Formatealo con un Macintosh, porq en Windows no lo reconoce.
    In Windows is not recognized
    By: Jaime Mora
    New Friend:
Error description:
Solution:
Posted on Dec 24, 2015
    New Friend:
I loose all my data , but my mp4 player works! try formating its works! ( perdon por mi ingles , y gracias infinitas)
Posted on Feb 12, 2012
    New Friend:
Meu sa3245 não funciona aparece mensagem " file sistem error, preciso de ajuda urgente.
obrigado
Posted on Aug 19, 2011
    New Friend:
Format it using windows xp. file system FAT32.
never format you device using vista. It works....
Posted on Jan 20, 2010
Thanks Stephie it worked for me too. Mine was removable disk drive (f:). Had to reload all the music but it is way better than having to buy a new player!! And saves me from my 13yr old daughter's complaining! lol
Posted on Mar 10, 2009
Open in explorer, format (3.6gig). remove from computer. worked great
Posted on Dec 27, 2008
Esque no funciona mi mp4 marca error mandenme el controlador para componerlo
Posted on Apr 17, 2009
Stephie14's solution worked for my player, but my computer is brand new with more then one disk drive, the one that worked for me was removable disk drive(G):, all the music is gone but, it works now.Thanks.
File system error
Posted on Sep 14, 2009
SOURCE:
My philips go gear 4GB wont turn on even though it is charged
There is a small hole on the side of the player through which you need to use a small office pin to reset. press it for some 5 secs and release. the playerr would have hung up earlier and is now reset. you can now switch it on. Hope this clears. Good day
Jul 02, 2010 | Philips Electronics - Others
Phillips go gear vibe 4gb mp3 says drm license expired owned it for only one month
Philips gogear vibe 4gb says its full then it says to delete some content. I deleted every thing and it still says that.
Mar 07, 2010 | Philips GOGEAR SA6045 MP3 Player
For some reason my phillips 4gb just quit working and I can't return it to walmart because it was purchased as a fathers day gift and it has been over two weeks. Walmart said I would have to deal with the...
hi,
the problem could be that the philips 4gb player is not charging properly.
the jack could be loose, try connecting the jack with the charge chord and confirm that it goes all the way.
also try resetting the philips 4gb player. this should solve the problem.
cheers
Jul 22, 2009 | Philips Audio Players & Recorders
Philips gogear 8g is frozen.
My mp3 player (philips) power come on then freezes up @ go gear.
Jul 17, 2009 | Philips GOGEAR SA6045 MP3 Player
My gogear freezes every couple of minutes!
Update the firmware first
It could be a hardware issue requiring replacement, but here are the things you can try to narrow it down:
1. Make sure the hold/lock is not engaged
2. Reset the player
3. Run an Updated using the latest version of the Philips Device Manager from Philips website
4. Run a Repair in Philips Device Manager
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
If these methods fail, call Philips to see if you are still in-warranty.
-Tha Mp3 Doctor
Mar 11, 2009 | Philips GOGEAR SA6045 MP3 Player
I have a Philips Gogear Mp3 player. suddenly I'm not able to switch on the power supply and i tried charging it for 4-5 hrs.no Use. It's just 4 months old. can u help me?
It's dead. The HDD models are basically obsolete - you may have purchased it 4 months ago, but it was manufactured 3 years ago. Here is the basic troubleshooting to be sure, but it won't work:
-Tha Mp3 Doctor
Dec 12, 2008 | Philips GoGear HDD1830 MP3 Player
Any help??
-Tha Mp3 Doctor
Oct 05, 2008 | Philips SA5125/37 MP3 Player
Philips 4gb (Go Gear) mp3 player
Runa repair in Philips Device Manager
Sep 21, 2008 | Philips GOGEAR SA6045 MP3 Player
27 in Magnavox Smart TV
problem in vertical circuit 100uf 35 volt cap also could have poor solder connections on vertical ic
May 02, 2008 | Philips Magnavox 20MS233S 20" TV
HDD082/17 player stops working at the "Phillips" screen
http://www.p4c.philips.com/cgi-bin/dcbint/faqview?list=aa12_list_partial.html&view=aa12_view_full.html&desc=Micro%20jukebox&session=20070817194242_74.13.46.70&slg=ENG&refnr=0008264&refdisplay=PI_C48_HDD082_010&dct=QAC&ctn=HDD082/17 Just re-posting the link so this problem will show as having a solution :)
Aug 18, 2007 | Philips HDD082 MP3 Player
Philips GOGEAR SA6045 MP3 Player Logo
18,797 people viewed this question
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
