Question about Kitchen Ranges
I have a Electrolux EUEE63AS duo oven. I cannot find how to keep the interior lights on. SOmetimes i turn the oven on and the upper light will stay on, but if i try to keep the lower light on after eight seconds they both turn off
  • pharring Mar 25, 2009
    I dont have a solution but am considering buying one, however I have read some bad reviews. What is you opinion on the oven. Does it hold its temperature at the chosen setting. ?
    Philip WA
huuum
  • 750 Answers
SOURCE: maytag electric gemini,model mer6755aaw
Hello bigboy1666,
Welcome to Fixya,
You said, Oven does not show any displace and does not work. When you try to turn on the top oven, the displace shows h3 132 and the clock shows 12:00 .
You try to turn the upper and lower oven, none of them work. The light in the oven comes on okay.
Lets try to reset the system.
trun off the range.
Now trhow the breaker in the electric box off for 5 minutes.
after waiting 5 minutes turn the power on and try the range!
Let me know how she works.
Huuum at your service.
Please remember to leave a rating!
Posted on Oct 06, 2008
huuum
  • 750 Answers
SOURCE: oven lights will not turn off, Maytag gas double oven range Prec. touch 750
Hello bohlke75,
Welcome
You said, After cooking in the upper oven today, my wife noticed that both oven lights were on. I tried to turn them off but the oven light button just beeps when activated. I individually tried the plunger switches on both doors but that did not work either. You also unplugged the stove with the hope it would cancel the lights but they came right back on when i plugged it back in. You assume it is something in the touch pad since both lower and upper lights are affected.
Did you leave the plug out for 5 minutes or just do it quickly?
if it only happens on one door then the plunger switch is bad!
if it's both doors then you have a button or control problem. Service can give you a true diagnoses with out the cost of swapping parts randomly!
If it was the plunger you may have been able to get away with a do it your self repair!
Let me know how you do
Thank You,
Huuum
Posted on Oct 16, 2008
SOURCE: Oven igniters, are both suppose to be on during preheat or bake?
good choice,sounds like the bake igniter is bad
Posted on Nov 29, 2008
SOURCE: changing oven light bulb
The manual states to turn the cover counter clockwise. I was able to turn it about an inch and then it stopped turning. You really have to apply pressure, but it will turn more. It is similar to a tight light fixture. I was worried about breaking it, but it did finally loosen. I believe the replacement bulb is a 40 watt mini oven bulb also...
Hope this helps!
ndguy2481
  • 251 Answers
SOURCE: How to clean lower oven of 30" electric range by electrolux
try a lemon heated and the acid will eat away the food
Posted on Dec 01, 2008
EUEE63AS 80l HOW TO REMOVE OVEN DOOR
remove cover on the door ( inner) to expose screws.
Jul 26, 2014 | Ovens
GE JKP28 oven light is always on
It is possible the relay for the light on the control board has welded points. A door switch could be bypassing the control. keeping the light on when the door is closed. Hope this helps.
Feb 10, 2014 | GE JKP28 Electric Double Oven
My new oven electrolux EUEE63CS WILL NOT TURN OFF. display lights turn off but oven still going
My oven seems to turn off but the fan keeps working! Takes about 1hr for the fan to turn off after l have turned oven off. Is this normal? Im quite concerned. Will be calling help line monday morning......
Jul 28, 2011 | Electrolux 30" Built-In Double Electric...
I have an electrolux gas oven and it lights but then keeps going out, sometimes we have to re-light it 10 times to cook
I have the same problem. I replaced the flame safety valve and the problem still exist. I see you've been waiting since June for an answer so I'm buying another oven instead of waiting around.
Jun 25, 2011 | Electrolux Ovens
My electrolux EOD 3360 bottom oven is getting too hot. The oven temperature light stays on even at the lowest setting or defrost setting. The inside of the oven is literally roasting hot, and anything I...
1 . If your ELECTROLUXfan oven is getting warm but takes a very long time to cook or is burning thefood more on one side than the other, then you need to check if your oven fan motor isworking you will see the blade turning fast if it is ok. if the element isheating but the fan motor is notblowing the heat into the oven then you need To replace the oven fan motor is alittle more expensive and a bit more involved.
2 . If you have the opposite problem i.e. your ovenis over heating and burning everything then you will need to replace your ELECTROLUXoven thermostat
3. A quite common and easily overlooked answer isif your ELECTROLUX oven is not working at all i.e. noheat and no fan then the chances are that someone has put the oven timer into AUTOmode, simply put oven back to MANUAL mode and all should be working again.
Mar 22, 2011 | Electrolux Ovens
I have a whirlpool accubake duo, super capacity 465 and when I try to bake something the oven wont stay on...how do I get the oven to stay on
What do you mean that it wont stay on? Does it turn off and on during cooking? Does it just go off and wont come back on? The oven thermostat regulates the heat in the oven and the oven element and the oven indicator light will turn off and on during cooking. If it stayed on constantly on full oven element power everything would burn.
Mar 01, 2011 | Whirlpool Ovens
Interior bulb needs to be replaced. What needs to be removed to gain access? Thanks
Advantium - Interior Light Operation While Microwaving
The Advantium 240 oven interior (cavity) light will illuminate anytime the door is open. However, due to the dark tint on the oven door, there is not a light on while cooking since the food would not be visible using the interior lamp.
Food may be viewed during a microwave cycle by pressing the Microwave/Oven Light pad.
One of the Upper Level Speedcook lamps will come on for 5 seconds. The Microwave/Oven Light pad can be pressed up to 5 times during a microwave cooking cycle. The limit of 5 times is to prevent excessive heat on microwave cookware from the Speedcook lamp.
The Advantium 120 oven cavity is illuminated anytime the door is opened and while the unit is in the microwave only mode. As a result it will not have the Microwave/Oven Light pad.
If the light is not operating properly, you will want to have it checked by an authorized service technician. To obtain in or out of warranty repair on Major Appliances, you may call 1-800-GE-CARES (800-432-2737) or schedule service online.
Check here
http://www.geappliances.com/search/fast/infobase/10000007.htm
Aug 25, 2010 | GE Advantium 120 Convection/Microwave Oven
After light cleaning-Electrolux Ew30ES65 upper oven won't heat now! The bottom oven works fine, the lights are all on, the convection fan works in the upper over but the heating elements don't heat now....
I had the same issue with my EW30EW55GS. This is the second time! The dirst time, the technician replaced all the circuit boards (took a month to get the parts). I figured, I would try a light cleaning again. SAME THING! Again, I'm without an oven for no telling how long. The oven looks great, but don't be fooled - it's a piece of junk!
Apr 04, 2010 | Electrolux ICON Designer E30SO75ESS Oven
Kitchen Ranges Logo
166 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
