Yamaha HTR-5460 Reciever Cinema DSP
Help My reciever was working fine until a power shortage. Now nothing comes on. power thru the cords, changed fuses but still only a clicking noise when first turn it on and off but no lites or nothing. I really like this unit and need it for my home studio. Am I out of luck? or maybe you know whats wrong. How much to fix it! Thanx desperate Deb
  • 12 Answers
SOURCE: Yamaha HTR-5990 Audio no longer works
Hi everyone:
You may reset your unit, to do so here is the procedure.
1. Depress the MASTER little Button so it has to be in the OFF position
2. press simuntaneously the A/B/C/D/E and TUNNING/CH > buttons and the press MASTER again
3. Keep the two buttons pressed until the SLEEP blinks on th display, at this point you will see a message that last for maybe 3 seconds,
4. after the message you will see the number 1 and a series of numbers on the first row and the word MARGIN on the second row.
5. Turn the PROGRAM knob until you reach tothe number 11 FAC PRESET on the first row and PRESET INH on the second row
6. press the TUNNING/CH > button once, and the message on the second row will display PRESET RSRV
7. Press the MASTER again and your unit will have the factory settings.
I Hope this solve your problem
Miguel
Posted on Feb 16, 2008
  • 11 Answers
SOURCE: htr-5730 yamaha reciever
try another outlet sounds like you may have a short in either your power cord/supply or your outlet is acting up with the wiring
Posted on Apr 30, 2008
  • 21 Answers
SOURCE: my yamaha reciever htr-6130 quit powering up and
Maybe the power supply have that checked.
Posted on Oct 27, 2009
smarthome2
  • 1114 Answers
SOURCE: htr 6130 yamaha reciever has blown the power
Your problem is either in a speaker or a wire. This is a tip I wrote that may help you in your quest for a solution. If you need any further help, post a comment and I can help you dig further.
Receiver say's "Protect" or turns on then off posted on Dec 13, 2009
MessageRate.ThreadID = 3632423; MessageRate.ProductID = 0; c81ea4d.jpg smarthome2
Rank: Guru
Rating: 88%, 432 votes
The most common problem found on FixYa for Audio Video2_bing.gif Receiver's is:
My receiver say's "Protect" or turns on then off. What's wrong? Seven times out of ten it is a shorted speaker or speaker wire2_bing.gif. To determine your exact problem, the first step is to disconnect all speaker wires "at your receiver" Next: Turn the receiver back on. If your receiver still says "protect" or turns off, it needs to be serviced. If your receiver stays on; reconnect your speakers2_bing.gif one at a time and power back up after each speaker. You may find that after reconnecting all speaker wires it works! Most commonly the small braids of wire from the + to the - have touched and have caused the problem. In some instances, you noticed the problem only when turning the volume up. either way, make sure the exposed wires to your receiver are no longer than 1/2" long and are completely under the screw down terminal or slide in. When you've found the wire or speaker with the problem, your receiver will go back into "protect" At this point, disconnect the wire from the speaker at the speaker that may be causing the problem then test again.* Note* Make sure speaker wires do Not touch each other as this Will cause a short! If you turn the receiver back on and it stays on, you now know the problem is in your speaker itself. To test your speaker, you will need a multimeter. Set it to ohms resistance and touch the speaker terminals, if there is a short internally the meter will read "1......" If it's an analog meter, it will peg to the right. There's your problem. Now, within any speaker there are quite a few possibilities as to what could be causing the problem. Most common is a blown coil and the speaker needs to be replaced. Some speakers have internal crossovers (usually floor standing speakers2_bing.gif) and may have a shorted or burnt board (usually very visible brown burn marks on the board) and can possibly be repaired if your handy with a soldering iron. Now, if you disconnect the speaker wire at the speaker and it still says "protect" Check your wire for the obvious cut or nail thru the wire if possible. If your system has wiring that runs behind walls, you may need to use your meter again. Disconnect the wire at both ends, keep the ends separated, put your meter on ohms resistance and touch probes to the + and - wires at one side. If the meter pegs to the right or reads "1...." the wire is shorted and needs to be replaced or repaired at the short. Hope this helps.
Posted on Feb 28, 2010
palaboy
  • 5807 Answers
SOURCE: yamaha htr-5460 receiver; unit will
I just hope you have read my earlier post if not I will post again
Posted on Sep 24, 2010
Yamaha receiver HTR-3064 turn on but go to protection mode no sound
Htr-3064 reset power on - Fixya
www.fixya.com/support/t22761844-htr_3064_reset_power
Jan 8, 2014 - htr-3064 reset power on My Yamaha HTR-3064 will not turn on at all. ... 'straight' button as you power up to go into "advanced" menu (under DILLIGAF's post.) ... Not sure if I needed to unplug everything, but I was about to .... How do I turn ofprotection mode on my optimus sta 3200 receiver digital No sound.
Turns on but no sound - Fixya
Yamaha HTR-5460 Repair Brief.mpg - YouTube? 15:04https://www.youtube.com/watch?v=keaq2F4LrU4Feb 5, 2011 - Uploaded by Mark ZachariasThe Multimeter Junkie fixes an HTR-5460 with protectionproblems. ... Yamaha RX-V459DAB - Not powering ...Missing: 3064Yamaha HTR-5640 AV-Recei
Dec 21, 2015 | Yamaha Audio Players & Recorders
How do I connect my 901 equalizer /speakers to the yamaha rx-v633 receiver?
Sorry, it doesnt look like you can hook up an external EQ while still using the amplifier section of the yamaha. Instead, You would have to use the preamp out to go to 901 EQ, out of the EQ into another stereo amplifier, then to the 901 speakers. Personally, to power the 901's properly, I'd use another external amplifier. You will barley get 75watts per channel out of the receiver to power the 901's
Jan 03, 2015 | Yamaha Av Reciever Rx-v793 Cinema Dsp...
How to reset a yamaha 5440 reciever back to factory settings
Hold 'fm/am' and 'input mode' and press power button. Then cycle through menus using 'program' button until you come to the selection that says "preset inhibit". Then press 'preset/tuning' button to change it to "preset reservd". Then press power button to turn it off. When you turn it back on, it should be back to factory settings.
Dec 30, 2012 | Yamaha HTR-5440 Receiver
Schematic diagram for 5630 yamaha reciever
http://www.eserviceinfo.com/downloadsm/36410/Yamaha_HTR-5630.html
Mar 04, 2010 | Yamaha HTR-5630 Receiver
Plug in reciever and it shuts down nothing hooked up into it yet
Have seen regulated voltages drop a volt on two causing this problem . the regulator with the low output needs changing. Voltages can be checked pretty easy at the one large connector coming from the regulator sectionto the dsp board.
Jul 16, 2009 | Yamaha HTR-5860 Receiver
I have the same problem
try to drop the 3 when programming that remote
Jun 12, 2009 | Yamaha HTR-6130 Receiver
Htr-5730 yamaha reciever
Feb 22, 2008 | Yamaha HTR-5730 Receiver
6050 yamaha receiver issues
the problem is how you wired it, guess you plugged the ps3 directly to the tv. to hear the ps3 through surround sound, you would have to wire it through the reciever like everything else...
Jan 28, 2008 | Yamaha HTR-6030 Receiver
Remote will not work on my reciever
I am wondering if it a preprogrammed remote controller or not. If not, you have to reprogram it.
Jul 03, 2007 | Yamaha HTR-5440 Receiver
No sound coming from reciever from tv
Make sure connections are going-audio out from tv to d-tv/cbl in on back of reciever. Then turn on tv and turn reciever input to d-tv/cbl and make sure the input mode is on auto. Hope this helps you.
Jan 24, 2007 | Yamaha HTR-5440 Receiver
 Grubhead
Grubhead
