Question about JVC Audio Players & Recorders
Hi there would you please advise me on a problem with a jvc compact ca-d4t, it will play some cd's some of the time and some cd's none of the time including many it use to play consistantly ,thanks
  • ianton71 Oct 04, 2008
    hi reguarding jvc ca-d4t stereo, i checked the lense ; looked clean, cleaned it again, lense is concaved i don't think a plastic cover has fallen off as was suggested, it is a 3 stacker, i can put a cd in tray 3 it won't work i then put it in tray one it works , i can then put another one in tray 3 and it works, then after that swap it 4 the original 1 and it starts working, i have watched this proccess with unit open and when it doesn't play some times it will spin slowly then stop and other times it won't spin at all, is is a location problem with the stack unit when it goes up and down? i hope u can help,,, thanks
  • 1,800 Answers
Try to use a cleaner Disk that comes with a special liquid cleaner for lenses
ur lens is not clean or might be no original disk u r using!!
plz do arte my post
thnx
Posted on Oct 04, 2008
  • 171 Answers
To locate the laser lens, look around the door or drawer of the CD player and you will see a small circular disc, which is often called the turntable or disc platter. Right off the edge of the platter you should see a small clear lens. There are some manufacturers that have had problems with the lens, depending on the age of the unit. In these problem players, moving the unit to a different location, turning the unit upside down or sometimes even without moving the unit, the lens can become detached from the laser assembly and floats around inside the unit. You can re-glue it back with a little crazy glue, BUT it must be perfectly centered, and without getting any glue on it. So, if you don’t see the plastic lens, but instead see the laser pick-up assembly, look around for the lens inside the unit and glue it back on.
To clean the lens you must use very little pressure. Take a cotton swab and barely moisten it with plain, non-scented, or oily type alcohol. In a swirling motion, very gently rub the lens until you’ve covered it entirely. Then repeat using the dry end.
  • Todd Gale
    Todd Gale Oct 05, 2008
    If this is a rack alignment problem, then it is going to require a service center repair. This is more than likely one of the gear drives and they are not available in the aftermarket. As a matter of fact, not many of the component parts are available. You may want to pull the chassis screws off and make sure nothing os bind the gears, but otherwise there is no way to adjust this so it will need to go to the service center.
  • JVC Master
  • 19,396 Answers
This is probably a problem with the lens, thry cleaning the lens with a cleaner kit.
JVC CA-D661T compact home stereo stopped playing burned CDs (it used to play these same CDs, now it doesn't recognize them). Everything else works, including playing of original CDs. Any ideas?
You can try cleaning the laser lens. You can do this using qtips and rubbing alcohol. Be sure you are very gentle though or you could risk scratching the lens which would completely ruin the laser assembly.
Mar 21, 2012 | Car Audio & Video
CD CHANGER SAYS NO DISK.
Hi it could be one of two problems it could just be that the laser lense is dirty and you can by a lense cleaning cd for this but dint buy cheap ones as they tend not to work.
If after doing this the same message comes up then the chances are that the laser has failed and would need replacing. The problem with this is it is going to be expensive to get done as its impossible to do yourself as it needs special tools. As for the cost it would be cheaper to replace the whole unit than get the laser repaired.
Try the lense cleaner first as this is the cheapest option usually 9 out of 10 of the times this solves the problem.
Let me know how you get on and if you need further assistance ok..
Aug 11, 2009 | Audio Players & Recorders
RESET 2 compact disc charger CH-X350 JVC.
I have no solution but the same problem and wish to solve it asap.
Anyone would you please help
If anyone has a JVC 12 cd's changer CH-X350 and also had the same problem (radio says when you wish to hear cd's : Reset 2), would you please tell.
thanks.
Mar 13, 2009 | JVC CH-X350RF 12 CD Changer
Will not play CD's ,press play and the drawer opens
darkie u need to clean your lazer i had seem problem with same model jake here
Dec 08, 2008 | Audio Players & Recorders
My JVC stereo receiver :CA-D4T has 3 cd changers and they don't seem to work most of the time
This is an indication that either the lens is dirty or that the optics are failing. Try opening up the unit and cleaning the lens using a cotton swab and alcohol. If that does not resolve the problem, the optics will need to be replaced.
Dan
Jul 30, 2008 | Audio Players & Recorders
Stereo Reciever model CA-D4T:cd changer won't "read cd" and sometimes says "no disc" when thereis one in there! Sometimes out of the blue it will work but mostly not! Any help would...
Dan
Jul 30, 2008 | JVC Audio Players & Recorders
Does not play from the speakers
hi, check if mute is on,select proper channel(aux/cd/phono ..etc), or check spkr cables.
Dec 28, 2007 | JVC MX-J900 CD Shelf System
Boombox on standby
i have a jvc compact component system ca-hxd7 an when you trun it on it pop real loud an then read PROTECT then goes off what can we do
Dec 03, 2006 | JVC RC-BX530 Cassette/CD Boombox
50 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
