Question about Car Audio & Video
I touched the positive wire from the stereo to the frame of the car and now there is no power at all
  • 97 Answers
Ok what you have done is blown the fuse make sure you replace it and always when you hook up a stereo disconnect the negative battery terminal so that way there is no power running to it
Posted on Oct 04, 2008
I HAVE POWER TO TO MY SWITCH ON MY DEH150MP BUT NOT TO THE FACE PLATE
so you have 3 wires that make the stereo turn on red is trigger from when you turn the key whatever wire turns active on the cars wire harness that needs to be conneced to the red wire on the head unit. yellow wire need to be connected to the cars wire harness that has constant power on even when the cars key is in the off position. Last connection should always be the ground connection should be made when connecting a stereo unit. You can use the ground off the cars wire harness or you can make your own ground using a sheet metal screw and tapping into the cars sub framing behind the unit with a loop connector at the screw end and a barrel connector to the stereo end. Them 3 wires red ,yellow,and black are the only 3 wires that need to be connect to turn the unit on and off. If your stereo doesn't hold its memory on the settings everytime you turn the car off you have the red and yellow wire crossed and you would need to swap them. goodluck
Mar 27, 2018 | Car Audio & Video
I have a 1991 chevy 1500 and am hooking up stereo system. But there are some wirtes loose that I dont know their place. For instance, the yellow and black one
The yellow wire from the truck attaches to the red wire of the stereo. The black wire goes to the black wire. If the truck doesn't have a black wire, connect the black wire from the stereo to a bolt on the frame of the dash. The orange wire from the truck goes to the yellow wire of the stereo. Please let me know if you have more questions.
1991 Chevrolet Silverado C1500 Car Audio Wiring Schematic
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Oct 27, 2011 | 1991 Chevrolet K1500
Radio wiring code for 1987 mercedes benz 300. With aftermarket radio the windows switch ligths blinks and have no instrument ligths.
Hi, the aftermarket stereo does not use the illumination wire. You must tape that wire off (purple/gray). That wire is either connected to the wrong place or is touching chassis ground and causing your instrument lights to dim.
Connect the stereo's red wire to the car's black/yellow wire; and connect the stereo's yellow wire to the car's red/white wire.
1987 Mercedes 300E Car Stereo Wiring Chart
Car Radio Battery Constant 12v+ Wire: Red/White
Car Radio Accessory Switched 12v+ Wire: Black/Yellow
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Purple/Gray
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: White
Car Audio Front Speakers Size: 4? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre Dash
Left Front Speaker Positive Wire (+): Yellow
Left Front Speaker Negative Wire (-): Black
Right Front Speaker Positive Wire (+): White
Right Front Speaker Negative Wire (-): Black
Car Audio Rear Speakers Size: 5 1/4? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Red
Left Rear Speaker Negative Wire (-): Black
Right Rear Speaker Positive Wire (+): Green
Right Rear Speaker Negative Wire (-): Black
Sep 13, 2011 | 1987 Mercedes-Benz 300-Class
What color wire is the power to the pump is it red /pink or yellow
Power to which pump? What type and year of vehicle? In most cases you can use a multimeter to locate this and a thumb tack. Push the thumb tack into the wire to puncture the insulation and then touch that with the positive test wire while you touch the car frame with the negative. The ignition will need to be on for this test.
Jun 17, 2010 | Cars & Trucks
Factory stereo wiring
Right here!
1986 Ford Ranger Car Radio Wiring Chart
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Blue/Red
Car Audio Front Speakers Size: 4′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): White/Green
Right Front Speaker Negative Wire (-): Black/White
Car Audio Rear Speakers Size: 5′ x 7′
Car Audio Rear Speakers Location: Rear Corners
Left Rear Speaker Positive Wire (+): Pink/Green
Left Rear Speaker Negative Wire (-): Pink/Blue
Right Rear Speaker Positive Wire (+): Pink/Blue
Right Rear Speaker Negative Wire (-): Green/Orange
Mar 04, 2010 | 1986 Ford Ranger 2WD
My car stereo plays for awhile then shuts off and comes on again, and so on and so forth. Before it was because my inline amp fuse was not screwed on tight enough, but now it is. Also, when it shuts off,...
hi
sounds like you have a short in your wiring, you will have to trace back the wiring and check that the battery positive and the ignition positive arnt touching any earths (be sure no wires are trapped between the radio frame and the radio cage in the dash, as all metal parts of the radio are EARTH
Dec 21, 2009 | Alpine CDA-9884 Car CD/ MP3 Player
BUTCHERED WIRING.
Dont know what year you have but one of these will work. Ground is usually separate in Dodges:
1990 Dodge Caravan Car Stereo Wiring Diagram
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: Orange/White
Car Stereo Antenna Trigger Wire: Yellow
Car Audio Front Speakers Size: 5 1/4′
Left Front Speaker Positive Wire (+): Green
Left Front Speaker Negative Wire (-): Green/Yellow
Right Front Speaker Positive Wire (+): Purple
Right Front Speaker Negative Wire (-): Purple/Yellow
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Tail Gate
Left Rear Speaker Negative Wire (-): Brown/Yellow
Right Rear Speaker Positive Wire (+): Blue/Red
Right Rear Speaker Negative Wire (-): Blue/White
1997 Dodge Caravan Car Radio Stereo Audio Wiring Diagram
Car Radio Constant 12v+ Wire: Pink
Car Radio Switched 12v+ Wire: Red/White
Car Radio Illumination Wire: Black/Yellow
Car Stereo Antenna Trigger: N/A
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Blue/Red
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Blue/Orange
2003 Dodge Caravan Car Radio Stereo Audio Wiring Diagram
Car Radio Constant 12v+ Wire: Gray/Red
Car Radio Switched 12v+ Wire: Black/Pink
Car Radio Ground Wire: Chassis Or Metal Strap
Car Radio Illumination Wire: Orange/Tan
Car Stereo Amp Trigger Wire: Gray/Green
Left Front Speaker Negative Wire (-): Green/Black
Right Front Speaker Positive Wire (+): Gray
Right Front Speaker Negative Wire (-): Gray/Black
Left Rear Speaker Positive Wire (+): Green/Black
Left Rear Speaker Negative Wire (-): Green/Orange
Right Rear Speaker Positive Wire (+): Gray/Black
Right Rear Speaker Negative Wire (-): Gray/Pink
Jun 02, 2009 | Car Audio & Video
Wiring diagram for audio system replacement? First time replacing a car audio system. I'm OK with wires connections but color codes does'nt match at all.... No diagram found in manual nether on actual...
2003 Mitsubishi Galant Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Red/Black
Car Radio Switched 12v+ Wire: Blue
Car Radio Illumination Wire: Green/White
Car Stereo Dimmer Wire: Black/Yellow
Left Front Speaker Positive Wire (+): White/Blue
Left Front Speaker Negative Wire (-): Black/Blue
Right Front Speaker Positive Wire (+): White/Red
Right Front Speaker Negative Wire (-): Black/Red
Left Rear Speaker Positive Wire (+): Yellow/Blue
Left Rear Speaker Negative Wire (-): Gray/Blue
Right Rear Speaker Positive Wire (+): Yellow/Red
Right Rear Speaker Negative Wire (-): Gray/Red
pls rate
Mar 15, 2009 | 2003 Mitsubishi Galant
No sound from car stereo
it sounds like some sort of overload causing the stereo to switch off to stop damage. Have you checked that you have the correct amp fuse installed in your fusebox?. Is there an in-line fuse on the live feed wire of the stereo? I suspect either too much power is going to it or that the unit itself has developed a fault.
phil
Oct 24, 2008 | Car Audio & Video
1996 chevy 1500
with the ignition in the "off" position get a test light and touch one wire at a time while cycling the ignition switch to the "on" position, When you see that the test light goes off when the ignition switch is in the off position then you found the hot wire, make sure you dont hook it up to the "alway hot " wire or you might drain the battery hope this helps.
Oct 18, 2008 | 1996 Chevrolet Express
Car Audio & Video Logo
48 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
