Question about JVC AV-20820 20" TV
TV Turns on then turns off after a few seconds, then on timer comes on
I turn on the TV and in about 10 seconds or so the picture get a little blue with a couple like interference lines the shuts off, the the "on timer" light starts blinking and it won't turn back on till I unplug it and turn it on again and the same process starts again, HELP, I really like this TV and would like to fix it, any help would be appreciated, John
  • t_homasd Mar 26, 2009
    Same here. I don't even get any picture at all. After 10 seconds, the light starts blinking.
    Help us, Obi-Wan. You're our only hope.
  • 3130 Answers
SOURCE: TV turn off itself and won't turn on
Sounds almost like you have a voltage missing on the power supply board. if its a missing voltage a service manual and a multi meter should help ya find whats missing But a shop repair on a set like this could cost a bit as anything over 27" is a little costoly to fix these days. Only way to see is call and say to your self How old is the set? is it the set you really like do you wanna spend 150 to 225 to repair? it up to you. Good Luck
Posted on Jun 04, 2006
  • 5568 Answers
SOURCE: JVC tv i'art blinking timer
It is protecting you and itself with high probability.
Power supplies in modern electronic devices are designed to cycle if there is a fault in circuitry they are servicing and because of the design, also will not turn on completely if they are failing.
The older style of power supply was 'dumb' and unable to do this so could cause fires if the failure wasn't teh 'right' kind to blow the main fuse.
I agree with the manual; this is a job for a tech.
Posted on Aug 23, 2008
  • 92 Answers
SOURCE: JVC TV crisis.....HELP
yes... i actually work at verizon the tv is to old for fios because fios is so advanced we run off ot 720 to 1080 depending on areas. what kind of box is it? is it the hd box or stb>
Posted on Dec 19, 2008
  • 106 Answers
SOURCE: The tv turns on and back off and the on timer light blinks on
Try to reset everything in the menu section to reset the timer for tv some how was activated and needs to be turned off.that might help!!
Posted on Mar 24, 2009
  • 3037 Answers
SOURCE: TV turns on for about
I assume the light is blinking red, generally this may stand for a trouble code depending on the number of flashes.
I am thinking that since these tvs have had problems in the video circuitry, I think vertical amplifier for the picture or a similar part went bad and is just causing the tv to shut down. Unfortunately due to the age and type of the tv, it is definitely not worth fixing. A part replacement would cost about half of a new LCD tv of this size alone if it is what I am thinking. Sorry for the bad news, but this tv is done unless you want to stick more money into a tv that isn't worth fixing rather than buying a new one.
Let me know how this works out for you. Benjamin
Posted on Aug 26, 2010
It could be your power supply board.
Jul 23, 2013 | Televison & Video
No display or audio
I had the same problem after replacing several things and still having same problem, it ended up being a capacitor.
Jul 03, 2010 | Toshiba TP55H60 55" Rear Projection...
Tv comes on for 10 seconds then fades to a green tint then turns completely green for a few seconds than turns off
Symptom shows tv got problem with green picture tube that need to be replaced.
Rear projection tv has 3 picture tubes, red-green-blue to make color picture.
Since its an old model so spare parts would hardly be available and local tv repair shop will help you to arrange required part, if they can.
Apr 16, 2010 | Sony KP-57HW40 57" Rear Projection...
On/off green light flashes. Picture comes on for
the timer is set for a short time, try to get to the menu quick and turn off the timer it may take several tries.
Mar 06, 2010 | Televison & Video
Samsung HL5067W power cycling
It's simple. Your TV does not like you. Perhaps you need to speak kindly to it before you force it to watch BBC for hours. Buy it a scone.
Sep 29, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
Hitachi 53UDX10B 53 in
the picture turns blue because the blue crt stop working you 'll need a tech
Aug 02, 2008 | Hitachi 53UDX10B 53" Rear Projection...
No picture sound is fine
tv comes on then turns blue at that time it shuts down. The power is on and then it blinks 5 times!!!
Apr 27, 2008 | Sony KP-65WS500 65" Rear Projection...
Samsung HLR5067W
Faulty lamp could be, there is also a little blue switch behind the lamp door that needs to be in the down position.
Nov 16, 2007 | Samsung HLR5067WX 50" Rear Projection HDTV
Sony KP-51WS500
does it have blue video image?
Sep 29, 2007 | Sony KP-51WS500 51" Rear Projection...
Televison & Video Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
